Fuel Check Valve & Gascolator
rv10free2fly(at)yahoo.com
PostPosted: Tue Jan 26, 2010 2:41 pm    Post subject: Fuel Check Valve & Gascolator Reply with quote
I purchased an Andair fuel check valve (non return valve)and gascolator with my finishing kit, however I am yet to decide where to position both items.
My initial thought is to install the check valve after (down stream) the Floscan fuel flow transducer in the tunnel?
Could anyone please tell me where the ideal placement for the check valve would be?
For those of you out there that have installed a gascolator (I have the Andair version), could you please indicate where you positioned the gascolator on the firewall and the location of the drain line.
Any pictures for either the fuel check valve or gascolator installations would be very much appreciated please.
Many thanks in anticipation.
Kind regards
Patrick Pulis
#40299   (VH-XPP reserved)
Adelaide, South Australia
See what's on at the movies in your area. [url=http://au.rd.yahoo.com/movies/mailtagline/*http://au.movies.yahoo.com/session-times/]Find out now[/url].
robin1(at)mrmoisture.com
PostPosted: Tue Jan 26, 2010 3:01 pm    Post subject: Fuel Check Valve & Gascolator Reply with quote
Ta da!
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis
Sent: Tuesday, January 26, 2010 2:41 PM
Subject: Fuel Check Valve & Gascolator
Kind regards
Patrick Pulis
See what's on at the movies in your area. [url=http://au.rd.yahoo.com/movies/mailtagline/*http:/au.movies.yahoo.com/session-times/]Find out now[/url].
 Filesize:  535.25 KB
 Viewed:  3627 Time(s)
coop85(at)verizon.net
PostPosted: Tue Jan 26, 2010 4:50 pm    Post subject: Fuel Check Valve & Gascolator Reply with quote
Robin,
Real nice installation FWF! What muffler and heat muff are you using?
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Tuesday, January 26, 2010 6:01 PM
Subject: RE: Fuel Check Valve & Gascolator
Ta da!
Robin
Kind regards
Patrick Pulis
See what's on at the movies in your area. [url=http://au.rd.yahoo.com/movies/mailtagline/*http:/au.movies.yahoo.com/session-times/]Find out now[/url]. [quote]  http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution [b]
PostPosted: Tue Jan 26, 2010 5:39 pm    Post subject: Fuel Check Valve & Gascolator Reply with quote
No muffler. The exhaust is a Forsling exhaust with megaphone type collector area. Looks great, sounds great. Mine happen to be ceramic coated inside and out which I would not do again.
Better view of exhaust. Photo attached.
The heat muff is a standard heat muff cut down (slightly) to fit a flat area of the exhaust on co-pilot side. Pilots side untouched as you can see from the photo.
If you want a muffler I think others are using the Vetterman system. I have seen a few and they are beautiful units too. Others can surely comment better than me on those systems.
Of note… as nice as these photos are, I am REALLY happy to be past this stage and burning 100LL and not fingertips.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Tuesday, January 26, 2010 4:48 PM
Robin,
Marcus
40286
Ta da!
Robin
Kind regards
Patrick Pulis
 Filesize:  693.66 KB
 Viewed:  3615 Time(s)
