		ogdenk
				 Posted: Thu Jan 21, 2010 8:08 am    Post subject: Wing Wiring and Conduit |
				Hi all,
  I am working on my wing ribs, and realize I have to start thinking about what all will need wiring in the wing.  Without knowing exactly what will be out there, I want to leave as much room for wiring as reasonable and was wondering what other people have done at this point.  I see the conduit that Vans sells, and it mentions that it has been used for wing wiring.  Has anyone done this?  Is this the blue ribbed conduit shown in the recent conduit abrasion thread?  The plans call for enlarging the wiring hole to 5/8" (0.625") for the grommet, but the conduit is 0.810" according to Van's.  Is this too much of an enlargement of the hole?  The plans say that enlarging to 5/8" will create a notch in the angle on the inboard rib, I don't want that any larger than necessary.
  Also, if installing AOA, do the lines get run through the wiring run?  I would like to finalize at least the pitot line.  Looks like the bottom skins shouldn't be put on until all of these details are worked out.
  Thanks . . .
  Kent Ogden
  #40710 Wings
		john(at)trollingers.com Guest
				 Posted: Thu Jan 21, 2010 9:04 am    Post subject: Wing Wiring and Conduit |
				I installed vans conduit, enlarged the holes to 3/4" and pulled it through the ribs.  I have 5 wire pull stings running through it now so I na pull the wires when needed.
 On Thu, Jan 21, 2010 at 11:05 AM, Kent Ogden <OgdenK(at)upstate.edu (OgdenK(at)upstate.edu)> wrote:
  [quote]    Hi all,
  Thanks . . .
  Kent Ogden
  #40710 Wings
		jeff(at)westcottpress.com Guest
				 Posted: Thu Jan 21, 2010 9:23 am    Post subject: Wing Wiring and Conduit |
				The Vans conduit will fit nicely in a 3/4" hole, which, as I recall, is the hole size Vans does not want you to exceed.
 Jeff Carpenter
 40304
 On Jan 21, 2010, at 8:05 AM, Kent Ogden wrote:
 [quote] Hi all,
  Thanks . . .
  Kent Ogden
  #40710 Wings
  | 	  [b]
		drfred(at)suddenlinkmail. Guest
				 Posted: Thu Jan 21, 2010 10:13 am    Post subject: Wing Wiring and Conduit |
				Kent Ogden wrote:
 Kent;
 Few things to think about;
 AOA.  I ran my plastic tubing lines thru the same conduit.  Plastic one
 worked well.  As mentioned, Make sure you have an extra pull string.
 Other things to think about:
 Wingtip lighting  (position /strobe/led/whelen)
 Will your pitot tube have a heating element for ice?  Will need power
 and indicator lights.
 VOR /marker beacon antennae?  Some people put theirs in the wingtip.
 Temp probe? I put mine in an accessible area  inboard of the innermost
 inspection plate.
 Do you want a landing light (like duckworks) or go with the wing tip
 landing lights?
 Start getting a spread sheet of what you want in the wings before you
 rivet up the lower skin.
 Dr Fred
 515FW
		johngoodman
				 Posted: Fri Jan 22, 2010 5:02 am    Post subject: Re: Wing Wiring and Conduit |
				Kent,
 I used Vans conduit through 3/4" holes like the others have mentioned. For the AoA, I enlarged the tooling hole near the pitot line hole for the second plastic tube.
 John
  _________________ #40572 Phase One complete in 2011 |
		ogdenk
				 Posted: Mon Jan 25, 2010 7:55 am    Post subject: Wing Wiring and Conduit |
				Thanks for the replies.  I decided to go ahead and order all of the accessories I will put in the wings (lights, servos, AOA etc.) so there will be no surprises down the road.  It's surprising how much extra you can spend on accessories  .  I have been mulling the Safeair tip tanks as well, but at this point the budget won't bear it.  Also, after reading all the great trip reports and thinking about the reality of sitting in the plane for that long, I don't think I will really need them.
  Kent
  #40710 Wings
  	  | Quote: | 	 		  >> "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> 1/21/2010 1:11 PM >>>
 --> RV10-List message posted by: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
 Kent Ogden wrote:
 Kent;
 inspection plate.
 landing lights?
 Dr Fred
 515FW
 _-============================================================
 _-=          - The RV10-List Email Forum -
 _-= Use the Matronics List Features Navigator to browse
 _-= the many List utilities such as List Un/Subscription,
 _-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
 _-= Photoshare, and much much more:
 _-=
 _-=   --> http://www.matronics.com/Navigator?RV10-List
 _-=
 _-=               - MATRONICS WEB FORUMS -
 _-= Same great content also available via the Web Forums!
 _-=
 _-=   --> http://forums.matronics.com
 _-=
 _-=             - List Contribution Web Site -
 _-=  Thank you for your generous support!
 _-=                              -Matt Dralle, List Admin.
 _-=   --> http://www.matronics.com/contribution
		Kelly McMullen
				 Posted: Mon Jan 25, 2010 8:30 am    Post subject: Wing Wiring and Conduit |
				I don't know if that makes sense. The market of available items keeps
 changing. I don't plan to rivet the bottom skin on until I am just
 about ready to mount the wings to the fuselage. Pitot selection
 depends on EFIS selection, as does AOA. Servos depend on autopilot
 selection..True track and Dyon are supposed to physically interchange,
 but not electronically. I don't think the market is mature on LED
 lights, nor HID lights. Given that from the wings completion to wing
 mounting is at least 6 months or more work, I want at least 1 more OSH
 to go by before I finalize any of that.
 Kelly
 40866
 Wings about complete, except for wiring and accessories.
 On Mon, Jan 25, 2010 at 8:30 AM, Kent Ogden <OgdenK(at)upstate.edu> wrote:
  	  | Quote: | 	 		   Thanks for the replies.  I decided to go ahead and order all of the
  Kent
  #40710 Wings
  Kent Ogden wrote:
  Kent;
  inspection plate.
  landing lights?
  Dr Fred
  515FW
A&P/IA, EAA Tech Counselor
KCHD |
		rene(at)felker.com Guest
				 Posted: Mon Jan 25, 2010 8:50 am    Post subject: Wing Wiring and Conduit |
				My view on the tip tanks……
 Wife and kids don’t fly legs more than 2.5hr legs…
 Weight.  I have my airplane at 2800 and with people in the back seats I hit the limit.
 60 gallons at reasonable fuel burn rates (12.2 rich of peak, 10.5 lean of peak (or better)), always provides for at least 4 hours of flight time…..
 So for me it does not really work out to be a good deal.  Just think of how many flights you will have where you will need the fuel………….
 Rene
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kent Ogden
  Sent: Monday, January 25, 2010 8:31 AM
  Subject: Re: Wing Wiring and Conduit
 Kent
 #40710 Wings
  Kent Ogden wrote:
  Kent;
  inspection plate.
  landing lights?
  Dr Fred
  515FW
  href="http://www.matronics.com/Navigator?RV10">http://www.matronics.com/Navigator?RV10-List
  bsp;   - MATRONICS WEB FORUMS -
  bsp; - List Contribution Web Site -
  bsp;                  -Matt Dralle, List Admin.
 ¦·~‰²,    g–ÓÓ
