david steade
Posted: Sun Jan 24, 2010 3:41 pm Post subject: Material for Instrument Panel |
I'm just about ready to order the material for the sub panels to carry the instruments in the panel molding. Any guidance on material specification and thickness would be helpful
David
_________________ David Steade |
topglock(at)cox.net Guest
Posted: Sun Jan 24, 2010 3:52 pm Post subject: Material for Instrument Panel |
My panel is built from .063" aluminum. Very ridged and light weight.
Available at sign suppliers.
Jeff - Baby Blue
Steade wrote:
| Quote: | I'm just about ready to order the material for the sub panels to carry
David
Checked by AVG - www.avg.com
houlihan(at)blueyonder.co Guest
Posted: Mon Jan 25, 2010 1:45 am Post subject: Material for Instrument Panel |
Don't forget that pre shaped panels are available on the Europa factory
web site.
Tim
Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Mon Jan 25, 2010 3:53 am Post subject: Re: Material for Instrument Panel |
What about Carbon fiber sheeting. You will have a ready made finish if you like the carbon fiber look.
Richard Wheelwright
DanBish
Posted: Mon Jan 25, 2010 7:26 am Post subject: Re: Material for Instrument Panel |
This might not help if you're in the UK, but for US or Canadian builders it might be helpful.
I got my aluminum sheet at
http://www.onlinemetals.com/merchant.cfm?id=239&step=2&top_cat=60
I plan to cover it in the carbon fiber vinyl wrap material, forget what it's called but it gives a CF look and comes in lots of colors.
Dan
bmoorhouse
Joined: 29 Apr 2009 Posts: 12 Location: SW England - Somerset to be precise
Posted: Tue Jan 26, 2010 1:34 am Post subject: Re: Material for Instrument Panel |
| flying farmer wrote: | What about Carbon fiber sheeting. You will have a ready made finish if you like the carbon fiber look.
Richard Wheelwright |
Mine is carbon fibre sheet - as a "sub panel" that holds all the instruments and can be removed without taking the whole panel assembly off. Looks very good with its almost holographic weave effect, is very light and very strong. Also have carbon fibre sheet on the panel cover between the seats (I do not have finger brakes).
I would recommend it if you can get some with a good polished finish.
12.51 KB |
18874 Time(s) |
10.9 KB |
18872 Time(s) |
_________________ _______________
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL |
david steade
Posted: Tue Jan 26, 2010 7:26 am Post subject: Material for Instrument Panel |
Hi
Thanks for all the information regarding the instrument panel and brake fluid. Not finally made my mind up which way to go yet but a least I am better informed.
David Steade
