jessejenks(at)hotmail.com Guest
Posted: Thu Jan 07, 2010 1:20 pm Post subject: planning |
To: jessejenks(at)hotmail.com
Subject: RE: AeroElectric-List Digest: 27 Msgs - 01/06/10
Date: Thu C 7 Jan 2010 12:58:03 -0800
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;}
| Quote: | Time: 10:17:27 AM PST US
From: "Robert L. Nuckolls C III" <nuckolls.bob(at)aeroelectric.com>
Subject: AeroElectric-List: Electrical System Planning
At 11:45 AM 1/6/2010 C you wrote:
I'm planning to use Z-11 and have an occasional-IFR panel with a
Grmin 430 and Dynon EFIS. I'm still at the very basic planning phase.
Do you plan to have vacuum driven instruments?
If not why not Z13/8?
No C I won't have a vacuum pump. I will reconsider Z13/8 C but I had deemed it overkill for my mostly VFR bushplane.
I do want to have a "get home" IFR capability C but as one who has spent many hours inside clouds in well equipped
airplanes and being scared occasionally C mostly by icing C I view a single engine piston airplane without anti-ice systems as a not-very-good IFR platform. Also I like
your philosophy that using a properly maintained RG battery is the simplest way to add reliability to the
electrical system. I also have Slick mags C and with backup batteries in the EFIS and a handheld gps/radio C
I don't see the electrical system as the most critical system for the guarantee of a safe landing. I am definitely
willing to change my mind though.
1)With the P.P. alternator I will obviously not have the separate
voltage regulator C but do I still need the crowbar over voltage protection?
Plane Power INCLUDES crowbar OV protection on their OBAM
aircraft alternators.
Thank you. Sure enough C the schematic that came with my alternator says right at the top;
"12 volt 60 amp experimental alternator w/internal voltage regulator and over voltage protection".
Do you think this system is as good as C not as good C or better than using an alternator with external regulator
and OV protection? I think I remember you saying in the past that you tested the Plane Power alternator.
| Quote: | 2)The Skytec starter has it's own contactor to engage the gear C and
apply power to the motor. According to Skytec C I don't need a
separate contactor for the starter if I use a 20+amp starter switch C
which I plan to do (toggle mag switches and separate starter switch)
Are there any cautions for not using a separate starter contactor?
No.
I like the simple "NO" answer C however now after doing some more reading I have a couple more questions;
I came across your Z-22 C fix for run on starters with PM motors C which the Skytec is. You suggest a relay to replace
the contactor. Further Skytec suggests on their website that if wiring the starter without a seperate contactor C to put
a diode at the start switch to lengthen service life of the switch. This all leaves me a little confused. What is the main
issue here C protecting the start switch C or preventing possible damage to the starter or flywheel gears C or both C or
something else? Should I use a diode or a relay C or both C or neither?
| Quote: | | And another question; I saw your link to the article below. I found the philosophical discussion very interesting C I also noticed that in that article you reccomend a 70 or 80 amp fuse in the alternator B-lead which is different than the Z-figures where an ANL 60 curret limiter is shown. Reading note 10 I see that the current limiter is a modern upgrade to the fuse or breaker C but is 60 amps still the reccomended rating (not 70 or 80)? Thanks. Have you read . . . http://www.aeroelectric.com/articles/fusvbkr2.html |
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. Hotmail: Free C trusted and rich email service. [quote][b]
Posted: Fri Jan 08, 2010 3:06 pm Post subject: planning |
electrical system. I also have Slick mags, and with backup batteries
in the EFIS and a handheld gps/radio,
If you're comfy, so be it. The neat thing about Z-13/8 is that
it's an easy step up from Z-11 at any later time giving you
unlimited 8-10A of e-bus loads for a weight penalty that's
a small fraction of the vacuum system that came out (or wasn't
there in the first place).
Thank you. Sure enough, the schematic that came with my alternator
Do you think this system is as good as, not as good, or better than
I have not tested any PP products. However I did
talk to one of the techno-wienies there right after
I was made aware of their offering. I confirmed that
they had adopted a crowbar ov protection technique
and avoided the b-lead contactor by going inside
the alternator to bring out the field excitation
supply line. All in all, an elegant solution.
The design goal for the AEC9004 IR alternator controller
is to achieve any time, any conditions, zero-risk pilot
control of an UNMODIFIED internally regulated alternator.
Aside from differences in design goals, I'd judge the
PP products to be entirely suited to the task.
2)The Skytec starter has it's own contactor to engage the gear, and
apply power to the motor. According to Skytec, I don't need a
separate contactor for the starter if I use a 20+amp starter switch,
No.
I like the simple "NO" answer, however now after doing some more
reading I have a
couple more questions; I came across your Z-22, fix for run on starters with PM
motors, which the Skytec is. You suggest a relay to replace the
contactor. Further
separate contactor,
to put a diode at the start switch to lengthen service life of the
switch. This all
leaves me a little confused. What is the main issue here, protecting the start
switch, or preventing possible damage to the starter or flywheel
gears, or both, or
something else? Should I use a diode or a relay, or both, or neither?
We're getting several issues tangled together here. First,
unless the builder is going to use a robust starter pushbutton
designed for abuse by two-stage contactor/solenoids then
some sort of "buffering" is worth considering.
Assuming you still wish to control the Skytec contactor
directly, then adding a relay per Z-22 is the way to
go about it. Assuming you already have or wish to use
the single stage starter contactor, then you don't want
to "jumper" the Skytec solenoid coil to the main terminal.
This gives rise to the "run on" phenomenon described. In
this case, you take the "I" terminal from the external
single stage contactor over to the Skytec's coil
terminal as suggested by
http://aeroelectric.com/Pictures/Schematics/Vans_Starter_Wiring_Lg.jpg
This has the advantage of (1) reducing stress on the
starter push-button or switch and (2) preventing
delayed disengagement during spin down on a PM
starter. Kinda slick. Wish I'd thought of it.
Now with most contactors, a diode across the
coil is a good thing to contemplate. On Van's drawing
cathode would go to "S" and anode to ground (case).
You could also consider a diode from the Skytec
coil terminal (cathode) to ground (anode).
interesting, I also noticed that in that article you recommend a 70
breaker, but is 60 amps still the
recommended rating (not 70 or 80)?
Yes, there was a bit of a kerfuffle here on the List
about 13 years ago. See:
Early on we were pretty stoked up about using
JJN/JSS fuses as lower cost, bolt-on b-lead
protection. That idea proved less than ideal
when a number of builders reported opening their
60A fuse on a 60A alternator (so we up-sized to
70A . . . probably should have jumped to 100A).
Other builder noted that these fuses were not
very robust mechanically . . . they reported
end caps pulling off the fuse body. Sooooooo . . .
the ANL limiters came to the rescue. Their
electrical robustness. See:
http://www.aeroelectric.com/articles/anl/anlvsjjs.html
Note that a 35A ANL would probably take good
care of the b-lead on a 60A alternator . . .
but a 60A is good too. This is NOT a finely tuned
protection task. Fault currents in the b-lead
will be hundreds to perhaps over 1000 amps!
Posted: Mon Jan 11, 2010 8:45 am Post subject: planning |
Bob wrote:
We're getting several issues tangled together here. First C
directly C then adding a relay per Z-22 is the way to
the single stage starter contactor C then you don't want
this case C you take the "I" terminal from the external
Thanks Bob. I am really struggling to absorb as much as I can from this discussion while also readying everything else I can find from your website and other sources C while also trying to learn Aeroelectric 101... My B-lead is about to smoke. So C I guess the jumper is what causes the run-on C and whatever I do I don't want it in there. I don't already have a separate contactor C so the way I understand it my options are; 1) use Z-22 with a relay C 2) just use a push button rated for 30 amps and no relay.
Can you explain why run-on is a problem if it only lasts a couple seconds?
Jesse
Hotmail: Powerful Free email with set/01/' target='_new'>Get it now. [quote][b]
Posted: Tue Jan 12, 2010 6:36 am Post subject: planning |
| Quote: | So, I guess the jumper is what causes the run-on, and whatever I do
I don't want it in there. I don't already have a separate contactor,
so the way I understand it my options are; 1) use Z-22 with a relay,
Yes.
| Quote: | Can you explain why run-on is a problem if it only lasts a couple seconds?
The design goal for engagement solenoids with
integral contactors is to effect immediate retraction
of the pinion gear when the starter button is
released. There ARE over-run clutches in the starter
gearing that prevents the engine from back-driving
the starter. These are VERY important . . .
For a small starter to be efficient, the armature
is highly geared down to crank the engine at 150
to 300 rpm. when the engine starts, it's suddenly
running at 4x that speed. Were it not for over-run
clutches, this would immediately spin the armature
up to 4x it's operating speed and probably throw
windings, commutator bars, or strip gear teeth.
The run-on phenomenon simply exercises the over-run
mechanism and increases pinion wear for reasons that
do not add value . . . and would not happen except
for an unintended consequence of using the solenoid/
contactor in a manner contrary to original design
goals.
Posted: Thu Jan 21, 2010 11:35 am Post subject: Planning |
| Quote: | | Hopefully this is a dumb question:With an aft battery installation C does the main bus feed wire come from the starter? | Also C does the crankcase ground strap connect to the firewall forest of tabs ground bus through bolt C or does it need its own more substantial bracket to bolt to?
Hotmail: Free C trusted and rich' target='_new'>Get it now. [quote][b]
Posted: Thu Jan 21, 2010 7:42 pm Post subject: Planning |
At 01:32 PM 1/21/2010, you wrote:
| Quote: | | Quote: |
With an aft battery installation, does the main bus feed wire come from
the starter?
[/b] |
Battery side of the starter contactor. Or if the
contactor is built into the starter, yes, right
from the starter.
| Quote: | | Also, does the crankcase ground strap connect to the firewall forest of tabs ground bus through bolt, or does it need its own more substantial bracket to bolt to? |
To the bolt.
Bob . . . [quote][b]
Posted: Fri Jan 22, 2010 9:59 am Post subject: Planning |
Thanks Bob C
yeah C I forgot to mention I decided to omit the starter contactor and will use the built in one.
Jesse
Date: Thu C 21 Jan 2010 21:40:13 -0600
Subject: Re: AeroElectric-List: Planning
At 01:32 PM 1/21/2010 C you wrote:
| Quote: | | Quote: | | Hopefully this is a dumb question:With an aft battery installation C does the main bus feed wire come fromthe starter? |
contactor is built into the starter C yes C right
from the starter.
| Quote: | | Also C does the crankcase ground strap connect to the firewall forest of tabs ground bus through bolt C or does it need its own more substantial bracket to bolt to? |
To the bolt.
Bob . . . | Quote: | | <===================== | Hotmail: Trusted email with Microsoft’6/direct/01/' target='_new'>Sign up now. [quote][b]
Posted: Fri Jan 22, 2010 11:16 am Post subject: Planning |
At 11:55 AM 1/22/2010, you wrote:
| Quote: | Thanks Bob,
yeah, I forgot to mention I decided to omit the starter contactor
Understand. Then the BAT terminal on your starter becomes
the forward power distribution point. Your alternator b-lead
would tie in there too.
Consider an ANL current limiter for the alternator B-lead
where the BAT end of the limiter base could become the
distribution point. This would prevent piling all those
wires on one terminal out on the engine.
Posted: Fri Jan 22, 2010 1:41 pm Post subject: Planning |
Great!
Thanks again. I had been visualizing the ANL setup that you suggest as one possibility. It makes a lot of sense C especially since the ANL seems to be you're preferred method of protecting the b-lead. What the other option has going for it is a real short b-lead wire directly from alt. to starter. Of course then I'm forced to use an inline fuse.
I'm leaning toward an ANL on the firewall.
| Quote: | Date: Fri C 22 Jan 2010 13:14:44 -0600
Subject: RE: Planning
--> AeroElectric-List message posted by: "Robert L. Nuckolls C III" <nuckolls.bob(at)aeroelectric.com>
At 11:55 AM 1/22/2010 C you wrote:
>Thanks Bob C
Hotmail: Free C trusted and rich email service. Get it now.
Posted: Fri Jan 22, 2010 4:03 pm Post subject: Planning |
At 03:05 PM 1/22/2010, you wrote:
| Quote: | Great!
as one possibility. It makes a lot of sense, especially since the
I think that would be my choice as it
handles logistics for a power distribution
point nicely.
