Phil.Perry(at)netapp.com Guest
Posted: Tue Jan 19, 2010 8:43 am Post subject: Conduit abrasion |
This morning I shot a quick video describing some of my questions regarding abrasion protection of conduit.
http://www.youtube.com/watch?v=saRUrF2vtMI
In 1990, we used text and thought it was great. In 2000, it was the cherry on top if you could send digital photos. Now it’s 2010 and video is where we are. On a side note, what’s 2020?
Phil
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Jan 19, 2010 9:20 am Post subject: Re: Conduit abrasion |
Here are some pics of mine. I did a similar setup but used two on each side instead of three. I cut my holes close tolerance under the seats and wrapped caterpillar grommets around them. The exiting holes are so tight they can't move. I stuffed two lines in one hole wrapped again with the grommet.
Maybe I will abrasion tape around the step where they contact the conduit like you stated.
561.22 KB |
3460 Time(s) |
604.89 KB |
3460 Time(s) |
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Tue Jan 19, 2010 1:09 pm Post subject: Conduit abrasion |
Hey Sean,
I'm planning to add the tape to the conduit and not to the step...
As tight as those steps are, I can only imagine how hard it will be to
pull the step and tape through the mount.
Phil
Strasnuts
Posted: Tue Jan 19, 2010 1:15 pm Post subject: Conduit abrasion |
Good point. That would kind of take away the reason to make the plate to
make the step removable.
780 Hours
