Cliff.Coy
Posted: Mon Jan 18, 2010 12:22 pm Post subject: Fuel System Schematic for M14 engines. |
Good afternoon all,
I've attached a schematic for the M14 series engine.
If there are any questions, feel free to give me a shout!
Best regards,
Cliff
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
| | - The Matronics MurphyMoose-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?MurphyMoose-List |
FUEL_SYSTEM_SCHEMATIC.pdf |
19.79 KB |
1197 Time(s) |
n223rv(at)wolflakeairport Guest
Posted: Mon Jan 18, 2010 5:22 pm Post subject: Fuel System Schematic for M14 engines. |
One question, why would you not put the electric fuel pump inline with the mechanical fuel pump? Inline is typically what the RV guys are doing with Lycoming engines.....
-Mike
On Jan 18, 2010, at 3:10 PM, Cliff Coy <[url=mailto:cliff.coy(at)gmail.com]cliff.coy(at)gmail.com (cliff.coy(at)gmail.com)[/url]> wrote:
| Quote: | Good afternoon all,
Best regards,
Cliff
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
<FUEL SYSTEM SCHEMATIC.pdf>
HBaker
Posted: Sun Mar 06, 2016 7:28 am Post subject: Re: Fuel System Schematic for M14 engines. |
Hello Cliff
We have purchased the Airflow Performance Fuel injection for the moose and they recommend the debubbler to prevent vapour lock . Their kit came with an electric fuel pump and it has the check valve built in with it , it runs on 35-45 psi. I like the way you done it with the gasolator, Do you think it will still work with the increased fuel pressure , or if I'll need a restrictor in the return line . I would prefer to go your way If you could help me.
Thanks Henry
_________________ Currently building a Murphy Moose - any help would be appreciated. |
HBaker
Posted: Wed Mar 09, 2016 3:13 pm Post subject: Re: Fuel System Schematic for M14 engines. |
Because the debubbler is on the pressure side of the pumps do I need anything on the vent line? example ; restrictor valve or anything? What would stop the fuel from flowing through on the 1\4 ' vent back up in the tank, Wouldn't this prevent her from reaching full fuel pressure ?
Could you please clear this up for me?
Thanks again
Henry
GeorgeCoy
Posted: Thu Mar 10, 2016 6:51 am Post subject: Fuel System Schematic for M14 engines. |
Yes, usually a .040 hole in the line. Take a steel fitting , fill it with
solder and drill a hole.
George
HBaker
Posted: Fri Mar 11, 2016 3:24 pm Post subject: Re: Fuel System Schematic for M14 engines. |
Thanks for your help George as always.
Henry
