ceengland(at)bellsouth.ne Guest
Posted: Sun Jan 17, 2010 5:06 pm Post subject: Fwd: steel PC680 battery tray?? |
IIRC, the es-pc680 battery install kit for the -6/7/9 includes a steel
battery tray. It would seem that a frame of aluminum angle would be
strong enough & lighter. Does anyone know if steel is really needed, or
am I wrong about the weight issue?
Charlie
bobbyhester(at)newwavecom Guest
Posted: Sun Jan 17, 2010 6:03 pm Post subject: Fwd: steel PC680 battery tray?? |
It is very thin and does not weight much. Van's directions are to cut 8
large lightening holes in it.
Surfing the web from Hopkinsville, KY
Visit my web site:
http://home.newwavecomm.net/bobbyhester/RVSite.htm
Charlie England wrote:
or am I wrong about the weight issue?
Charlie
sbuc(at)hiwaay.net Guest
Posted: Sun Jan 17, 2010 6:52 pm Post subject: Fwd: steel PC680 battery tray?? |
There was some discussion on the VAF forum a while back describing why
it might be better not to cut the holes. Seems that have been some
instances of a PC680 expanding just enough to protrude into the holes
enough to make the battery very difficult to remove. Saving an ounce or
two might not be worth the hassle.
Sam Buchanan
On 1/17/2010 8:01 PM, Bobby Hester wrote:
Visit my web site:
> Thanks,
> Charlie
Posted: Sun Jan 17, 2010 7:10 pm Post subject: Fwd: steel PC680 battery tray?? |
Makes sense. But is there a pressing reason to use steel? I don't mind
fabricating an aluminum frame, & that's $50 I could spend somewhere else.
Charlie
On 1/17/2010 8:51 PM, Sam Buchanan wrote:
or two might not be worth the hassle.
Sam Buchanan
> <bobbyhester(at)newwavecomm.net>
> Visit my web site:
>> <ceengland(at)bellsouth.net>
>> Thanks,
>> Charlie
yenduc(at)me.com Guest
Posted: Sun Jan 17, 2010 7:49 pm Post subject: Fwd: steel PC680 battery tray?? |
I just replaced my PC680. I found that with the help of the holes I
was able to remove and install the new battery easily by poking my
fingers through the holes to help lift the battery out. Also I was
able to do it with only the top cowling removed --love those
lightening holes!!
dave
On Jan 17, 2010, at 6:51 PM, Sam Buchanan wrote:
why it might be better not to cut the holes. Seems that have been
some instances of a PC680 expanding just enough to protrude into the
holes enough to make the battery very difficult to remove. Saving an
ounce or two might not be worth the hassle.
Sam Buchanan
> cut 8
> Visit my web site:
>> steel
>> Thanks,
>> Charlie
rv6n(at)optonline.net Guest
Posted: Sun Jan 17, 2010 7:53 pm Post subject: Fwd: steel PC680 battery tray?? |
I did the steel tray with the lightening holes and have had no problems with it. The battery is not large but does have a lot of weight, so I am comfortable having the steel. You may make one of aluminum but I question how much weight you are going to save. I have tried to attach a picture of my installation.
Good luck.
Bob Bales RV6
Do not archive.
1.43 MB |
4869 Time(s) |
at6c(at)bellsouth.net Guest
Posted: Mon Jan 18, 2010 5:36 am Post subject: Fwd: steel PC680 battery tray?? |
Charlie,
Weight is not a problem. I don't recall which one I used but next time you
come down to this end of the runway you can look at mine.
George
Posted: Tue Jan 19, 2010 3:46 pm Post subject: Fwd: steel PC680 battery tray?? |
Thanks; I'll head down when I get the chance. I'm actually more
concerned with the $50 cost for the kit. I need to look a what the
individual components cost.
Charlie
On 1/18/2010 7:15 AM, George Steube wrote:
Charlie,
George
