Dick Maddux
Posted: Sun Jan 17, 2010 9:01 am Post subject: Northstar F210 Fuel flow gauge |
Well, I have had it with this unit. The transducer has failed again and it is less than 2 months old and less than 8 hrs ! My first one lasted almost a year. This unit is coming out of my panel and a plug installed in its place until I find something nice to put in that hole.
I removed the transducer to see what the problem was. The impeller is stuck and I could not get it to move with compressed air or Kroil. I had thought seriously of the the method of getting my prior transducer to turn (a 5 LB sledge hammer) but decided otherwise.
In any case, this piece of c--p is free to anyone that wants it, just pay shipping to my PayPal account.
Yes, I did install it correctly in the vertical position, right above my gascolator on the firewall. It was a beautiful installation. Anyone know of a nice instrument of about the same size (2 inch) that gives OAT, flight time,etc. I would then be able to remove some unsightly stuff I have stuck to my panel.
Dick Maddux
Fox 4
Milton,Fl
349.06 KB |
14389 Time(s) |
akflyer
Posted: Sun Jan 17, 2010 12:12 pm Post subject: Re: Northstar F210 Fuel flow gauge |
I wonder if you are getting it hot if it is on the front side of the firewall? Or gunk out of the tank getting into it? Do you have the filter just before the transducer?
Just wondering cause I have several of them installed on my stuff and have never had a glitch, but mine is behind the seat in the plane just under the header tank.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Paul A. Franz, P.E.
Posted: Sun Jan 17, 2010 8:38 pm Post subject: Northstar F210 Fuel flow gauge |
On Sun, January 17, 2010 12:13 pm, akflyer wrote:
transducer?
Lenny - Thanks for this thoughtful contribution. You've definitely come up with a
plausible explanation. After Dick Maddux said:
"Well, I have had it with this unit. The transducer has failed again and it is less
the method of getting my prior transducer to turn (a 5 LB sledge hammer) ...."
I made a mental note that I guess I won't be using one of those Northstar units but
now I think you're on to something. It can't be so bad that it has 100% failure rate.
It must be failing due to some configuration or usage problem. Hopefully Dick will do
a little more experimenting before pronouncing the product dead and useless.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"The powers delegated by the proposed Constitution to the federal government
are few and defined. Those which are to remain in the State governments are
numerous and indefinite."
--James Madison, Federalist No. 45
"It is necessary for every American, with becoming energy to endeavor
to stop the dissemination of principles evidently destructive of the
cause for which they have bled. It must be the combined virtue of the
rulers and of the people to do this, and to rescue and save their
civil and religious rights from the outstretched arm of tyranny, which
may appear under any mode or form of government."
-- Mercy Warren, History of the Rise, Progress, and Termination of the
American Revolution, 1805
Europe was created by history. America was created by philosophy.
-- Margaret Thatcher
It's passionately interesting for me that the things that I learned in a
small town, in a very modest home, are just the things that I believe
have won the election.
A government big enough to give you everything you want, is strong
enough to take everything you have.
-- Thomas Jefferson
"As on the one hand, the necessity for borrowing in particular
emergencies cannot be doubted, so on the other, it is equally
evident that to be able to borrow upon good terms, it is essential
that the credit of a nation should be well established."
-- Alexander Hamilton, Report on Public Credit, 1790
"Liberty has never come from the government. Liberty has always come
from the subjects of government. The history of liberty is the
history of resistance. The history of liberty is a history of the
limitation of governmental power, not the increase of it."
-- President Woodrow Wilson (1856-1924)
"To cherish and stimulate the activity of the human mind, by multiplying
the objects of enterprise, is not among the least considerable of the
expedients, by which the wealth of a nation may be promoted."
-- Alexander Hamilton, Report on Manufacturers, December 1791
The strongest reason for the people to retain the right to keep and
bear arms is, as a last resort, to protect themselves against
tyranny in government.
-- Thomas Jefferson
"A fondness for power is implanted, in most men, and it is
natural to abuse it, when acquired."
-- Alexander Hamilton, The Farmer Refuted, 23 February 1775
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
dave
Posted: Mon Jan 18, 2010 1:26 am Post subject: Re: Northstar F210 Fuel flow gauge |
Dick, I have a navman 2100 I think it called. I think the one you have replaced it . Mine is over 4 years old and put through over 7000 gallon of gas--ethanol regular avgas marine gas whatever. I have noticed a few times it stops fora minute or two but continues on.
Mine us mounted on front of firewall almost vertical after the gascolator. Most of my fuel goes through a filter funnel as well.
There are better fuel flow meters on the market for 300 $ up .
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Mon Jan 18, 2010 3:29 am Post subject: Northstar F210 Fuel flow gauge |
Just to "balance the scales", so to speak, I've never had an issue
with my F210 unit, and my transducer is located inside the cabin at
an angle of not quite vertical...maybe 30 degrees from vertical, with
a Purolator glass filter just before the transducer.
Lynn Matteson
Jabiru 2200, #2062, 839.2 hrs
Countdown to 1000 hrs~162 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Jan 17, 2010, at 11:36 PM, Paul Franz - Merlin GT wrote:
<paul(at)eucleides.com>
> the firewall? Or
> before the
> transducer?
> header tank.
come up with a
a year. This unit
find something
is stuck and I
hammer) ...."
Northstar units but
100% failure rate.
useless.
Paul A. Franz
Bellevue WA
425.241.1618 Cell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Dick Maddux
Posted: Mon Jan 18, 2010 6:15 am Post subject: Northstar F210 Fuel flow gauge |
Leonard,
The transducer was located about 3 inches above the firewall gascolator inside the engine compartment against the firewall. I had it wrapped in heat shield material and it is about 1 1/2 ft from the muffler. I sure didn't see any caution about using it in in the engine compartment in the instructions. That's where it would have to go in a boat.
I removed the transducer yesterday and looked unto the interior of the thing The small rotor was "stuck tighter then a bulls ass at fly time" to quote an old buddy of mine! I couldn't move it with compressed air or a piece of safety wire. There was no trash in there I could see. The unit looked fine otherwise.
Anyway, I bought another piece of 5/16 injection hose and have removed the transducer from the system (gauge to follow) It wasn't giving me much useful info anyway. It was never accurate no mater how many times I tweaked it. Half the time the buttons would not work. I guess you get what you pay for. You must have lucked out. The net has many failures of this unit and it sure did not suprise the Northstar tech when I told him about it.There was a 5 month backlog just in replacing these transducers !
Anyway,done,nada,fine,no more of this instrument !
Thanks for your input Leonard.I appreciate it.
Dick Maddux
Fox 4
Milton,Fl
Dick Maddux
Posted: Tue Jan 19, 2010 5:34 am Post subject: Northstar F210 Fuel flow gauge |
I removed the transducer and looked at the internal rotor in bright sunlight. With a magnifying glass you could see that the rotor had jammed itself against the side of the tube. Apparently it had started to wobble in it's mounts I guess and that was that. This is the same thing that happened to my prior transducer. At least this was a good test of fuel flow with a jammed rotor. There was definite resistance as I blew through the transducer but not enough to block fuel flow to the engine as it was running fine. I looked at my logbook and it has been right at a year since I installed this instrument and cycled thru two tansducers.This was less than 75 hrs of flying!
Lynn, you and Leonard have had good luck with this unit. Maybe a different mfg. made the transducers as your units are older than mine. In any case, that's enough for me! I will find something else to fill that hole in my panel
Dick Maddux
Fox 4
Milton,Fl
dave
Posted: Tue Jan 19, 2010 2:44 pm Post subject: Re: Northstar F210 Fuel flow gauge |
Dick I was just flying and my fuel flow was not showing any flow rate.
do you got a voodoo doll over there?
LOL
Float Flyr
Posted: Tue Jan 19, 2010 5:08 pm Post subject: Northstar F210 Fuel flow gauge |
The bearings in the transducer may be the reason they like to see a vertical installation.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of catz631(at)aol.com
Sent: January 19, 2010 9:58 AM
Subject: Re: Re: Northstar F210 Fuel flow gauge
Dick Maddux
Fox 4
Milton,Fl
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Dick Maddux
Posted: Wed Jan 20, 2010 6:44 am Post subject: Northstar F210 Fuel flow gauge |
Dave,
I am sorry to hear about the failure in your gauge but in some ways I am going ...Yessssss ! The old adage "misery loves company" is true in this case. I hate being the only one that ever has a problem with a product.(it has been that way lately)
Perhaps voodoo did have something to do with it.
Anyway, I do hope you find the problem and if it is a jammed rotor in the transducer, tell Northstar about it.
My transducer was mounted perfectly vertical as per the instructions and both of them failed in short order
Dick Maddux
Fox 4
Milton,Fl
dave
Posted: Wed Jan 20, 2010 8:37 am Post subject: Northstar F210 Fuel flow gauge |
Will go flying later today
I had this afew times before with it cleared up
this time ? no idea
Wil let you know
dave
Posted: Wed Jan 20, 2010 9:03 am Post subject: Northstar F210 Fuel flow gauge |
Dick ok, just went for a quick flight
-7 C here today and still shows zero
oh well
mikeperkins
Posted: Wed Jan 20, 2010 8:36 pm Post subject: Re: Northstar F210 Fuel flow gauge |
It's a little scary to jump into this hot topic when it almost seems to have settle down, but anyway. . . . I've probably got 35 hours on my F210.
A pre-installation volume test showed that it was within 5%, as advertised. After some flight testing to determine flow rates at different steady airspeeds, I started using fuel flow to set the power of my 532 instead of the tach. So I began to refer to it quite frequently for small throttle adjustments while in cruise.
At least three times I've seen the fuel flow drop to zero and stay there for a minute or so; once during warm-up, once at cruise during the day, and once at cruise on a black, moonless night (a bit disconcerting).
It seems clear from all these excellent postings that this instrument is inconsistent from one unit and another, and that perhaps the fault lies mostly in the transducer.
A flight instrument with this kind of track record would probably be blackballed.
Mike Perkins
sdemeyer
Posted: Wed Jan 20, 2010 9:11 pm Post subject: Northstar F210 Fuel flow gauge |
For what it's worth, I have 74 hours on mine and it works great. Never had any problems, so far.
Scott
--- On Wed, 1/20/10, mikeperkins <michael.perkins(at)rauland.com> wrote:
Subject: Re: Northstar F210 Fuel flow gauge
Date: Wednesday, January 20, 2010, 8:36 PM
--> Kitfox-List message posted by: "mikeperkins" <[url=/mc/compose?to=michael.perkins(at)rauland.com]michael.perkins(at)rauland.com[/url]>
Mike Perkins
http://forums.matronics.com/viewtopic.php?p=282647#282========================http://www.matronics.com/Nav= - MATRONICS cs.com" bsp; -Matt Dralle, List Adontribution" target="_blank">http://www.matronics.com/contribution [quote][b]
Dick Maddux
Posted: Thu Jan 21, 2010 6:44 am Post subject: Northstar F210 Fuel flow gauge |
Thanks Mike ! , I agree !
Dick Maddux
Milton, Fl
dave
Posted: Thu Jan 21, 2010 12:45 pm Post subject: Update and Good news Re: Northstar F210 Fuel flow gauge |
Dick,
I just in from flying , before I took off I saw something under the dash that look askew. Was the plug from the Navman hanging there LOL
plugged it back together went flying............. it works LoL
I guess you never did jinx it.
Float Flyr
Posted: Thu Jan 21, 2010 5:33 pm Post subject: Northstar F210 Fuel flow gauge |
May be ethanol on the transducer... sorry coudn’t resist.... like I tried J
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dave Fisher
Sent: January 20, 2010 1:33 PM
oh well
----- Original Message -----
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Wednesday, January 20, 2010 11:36 AM
Subject: Re: Kitfox-List: Northstar F210 Fuel flow gauge
this time ? no idea
Wil let you know
Sent: Wednesday, January 20, 2010 9:33 AM
Dave,
Dick Maddux
Fox 4
Milton,Fl
| Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 0 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 1 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 2 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 3 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 4 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 5 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 6 | Quote: | | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 7
Kitfox III-A
Dick Maddux
Posted: Fri Jan 22, 2010 5:13 am Post subject: Northstar F210 Fuel flow gauge |
Dick,
AAhhh Rats ! I guess it's just me that had the failures. Glad you got her running again !
Dick
