jchang10
Posted: Sat Jan 23, 2010 9:29 am Post subject: Fake powder coat - Re: Windscreen install before panel? |
I was just told about using truck bedliner paint trick, too. I was told
it gives a texture similar to powder coating, if you paint over it with
color. Not sure if that is true or not, as i have yet to test it myself.
I am regretting not painting the baffling pieces white earlier.
Considering the above for the baffling pieces.
Jae
40533
Hung the exhaust and now it's beautiful!
Dave Leikam wrote:
I am putting windscreen on first. I don't see any difference if you
already riveted on the forward fuse top. Two more cents - I used
rattle can, spray on, truck bed liner from the local auto parts store
to paint the forward fuse top. Textured, flat black and very tough.
Scuff and prime first.
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
