jrlark
Posted: Thu Jan 14, 2010 9:44 pm Post subject: electric aileron trim |
Hey Guys
I'm getting ready to order my slow build wing kit and am wondering if most builders have also bought the aileron trim kit from Vans. I intend to install a Tru Tak autopilot and probably the Safety trim system that Bob Newman sells. Not sure if using the autopilot etc makes any difference with regards to the aileron trim system (I think not).
As I have already fabricated a rudder trim tab system very similar to Brian Steeves, I'm wondering if the aileron system could also be fabricated in house, as opposed to buying the Vans kit?
All opinions welcome. Thx.
Rick
#40956
Southampton, Ont
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Fri Jan 15, 2010 4:25 am Post subject: Re: electric aileron trim |
| jrlark wrote: |
In my opinion, you need both. Vans aileron trim works and unless you want to spend a bunch of time designing and making your own, Vans is simple to build and install.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
dmaib(at)mac.com Guest
Posted: Fri Jan 15, 2010 4:35 am Post subject: electric aileron trim |
I installed the Van's aileron trim and am glad I did. Fuel imbalance and passenger loading makes a noticeable need for trim. If you feel like fabricating your own system, I say go for it!
$.02 worth.
David Maib
40559
Flying
On Jan 15, 2010, at 12:42 AM, Rick Lark wrote:
Hey Guys
Rick
#40956
Southampton, Ont
Posted: Fri Jan 15, 2010 7:00 am Post subject: electric aileron trim |
fwiw. I'm using model airplane servos to turn hinge mounted on the
trailing edge of rudder and one aileron. You need a PWM signal to
operate the servos, but that's easy for me.
Linn
orchidman wrote:
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 81590#281590
Kelly McMullen
Posted: Fri Jan 15, 2010 7:12 am Post subject: electric aileron trim |
I question the need for both aileron trim and autopilot. The autopilot
should be able to handle the minor imbalances. While a trim tab could
reduce loads on the autopilot, it seems like unneeded extra
complexity. I'd be interested in hearing from flying -10s whether they
have and actually use both systems. I could see one or the other, but
both would appear to be overkill.
On Fri, Jan 15, 2010 at 5:25 AM, orchidman <gary(at)wingscc.com> wrote:
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Fri Jan 15, 2010 7:28 am Post subject: electric aileron trim |
I'd be interested in 'real life' info too. I had a discussion with a
friend with extensive autopilot experience, and his comment was that if
the aircraft was out of trim, the autopilot 'flew funny'. I'm guessing
it's because the autopilots he was flying behind had rate gyros, not
solid state ones so prevalent now. Since I was already going to install
the model airplane servos and designed the PWM module, adding the
aileron trim was real easy. I've never had actrive trim on anything
I've flown, so this is new ground for me.
Linn
Kelly McMullen wrote:
autopilot should be able to handle the minor imbalances. While a trim
tab could reduce loads on the autopilot, it seems like unneeded extra
they have and actually use both systems. I could see one or the
other, but both would appear to be overkill.
>> kit?
> -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying)
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Fri Jan 15, 2010 7:42 am Post subject: electric aileron trim |
If you want to save time on the controller, for a cost, Eric at Perihelion Designs has a nice little unit called the EGPNMSC.
http://www.periheliondesign.com/moreproducts.htm
Michael
drfred(at)suddenlinkmail. Guest
Posted: Fri Jan 15, 2010 7:46 am Post subject: electric aileron trim |
Kelley;
I put both in mine. Most of the time you will set the aileron trim at
one position and never move it. Depending on who's flying with you (I
tend to have the same left wheel wear problem Deems has), you may need
to adjust it. Also, I had to have my autopilot serviced and did a
couple long cross country trips. Having the aileron trim helps decrease
your workload and cut down some of the heading drift. My vote is that
it is worth the installation.
Dr Fred.
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
rene(at)felker.com Guest
Posted: Fri Jan 15, 2010 7:48 am Post subject: electric aileron trim |
I have both and use both. I would highly recommend having both unless you
fly almost 100% of the time on the autopilot. Fuel in-balance, fat pilot ,
pattern work, hood work ........ I use the trim every flight.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Tim Olson
Posted: Fri Jan 15, 2010 7:49 am Post subject: electric aileron trim |
You can question the need if you wish.
I'll tell you what...the RV-10's tanks are so looooong that they
give a pretty hefty imbalance. Sure, with the AP on you
won't notice it too much, but even just hand flying it around
town, that plane can get very wing-heavy. I would never want
to be without the ability to compensate it. Now, depending
on your loading and everything else, you may only use it on
30-60% of your flights, but when you need it, you'll really
want it. It's easier to build into the wing when the wing is
still on the bench and before you paint the access covers, so
I'd say in my recommendation I'd consider it standard equipment
and just do it. But, if someone really likes to suffer, because
suffering makes them feel more like a man, then skip it for
now and just let that nagging voice in the back of your head
keep talking to you as you fly your 200th hour wishing you'd
have put it in.
Tim
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
aerosport1
Posted: Fri Jan 15, 2010 8:00 am Post subject: electric aileron trim |
Take Tim's advice. It is easy to install and worth every penny. I only have
44 hrs on my Rv-10 and the first 32 were without auto pilot working
Correctly. I was glad I had aileron trim.
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Albert Gardner
Posted: Fri Jan 15, 2010 8:01 am Post subject: electric aileron trim |
I believe you need the aileron trim with an autopilot. I have a TruTrak but
you need to trim the aircraft before engaging the autopilot for two reasons.
When you disengage the aqutopilot an out-of-trim condition will cause abrupt
aircraft movement especially in pitch. Second, again especially in pitch,
the autopilot may "slip" if the out-of-trim condition is too strong. That
built-in slippage is what let's you overpower a runaway autopilot.
Albert Gardner
N991RV
Yuma, AZ
RV-10 N991RV |
jrlark
Posted: Fri Jan 15, 2010 8:53 am Post subject: electric aileron trim |
Albert, good points. The aileron trims a "go" from my perspective. A
friend with a T210 Cessna has an Stec55X that will squawk at him if the
trim is out too much (PITA), so I think it's a good idea.
(by the way Albert, nice design on your spring biased rudder trim)
Now my next question, are the Vans deluxe locking fuel caps worth the work
to install? When this aircraft is completed, it may be tied down outside for
a year or so. The catalogue description says they certainly are not a drop
in replacement. That's ok to me as long as the modification is reasonable.
Most of the archive messages seem to indicate they are worth the time and
expense. Again all opinions are welcome.
You guys have no idea how much easier it is to make these decisions with
input from this forum (especially since I'm stuck on the far north tundra of
southern Ontario). Thx again
Rick
Deems Davis
Don't leave home with out it!
Deems Davis
N519PJ
www.deemsrv10.com
Neal.George(at)hurlburt.a Guest
Posted: Fri Jan 15, 2010 9:25 am Post subject: electric aileron trim |
..and it works very well.
neal
smime.p7s |
5.09 KB |
451 Time(s) |
Posted: Fri Jan 15, 2010 1:45 pm Post subject: electric aileron trim |
Well, I was aware of that rather nifty item. I'd need two
(aileron/rudder trim) so that's $100 + shipping + servos ($2 .
I used a Stamp Computer (http://tinyurl.com/yjrv4kg) $54, and the two
servos $28 + shipping and wrote the program (simple basic language). I
have 10 more I/O ports left to do whatever strikes my fancy. I could
use some of the ports to control dimmers, or discrete flap settings or
Linn
Michael
Kellym
Posted: Fri Jan 15, 2010 3:29 pm Post subject: electric aileron trim |
All valid points, except that aileron trim is no where near as important as elevator trim. The examples you cite are all for elevator trim. I've heard the message from Tim and others that aileron trim is worthwhile. Some autopilots have aileron trim function built in. My Mooney has a knob on the turn coordinator that I just dial what gives a no turn, wings level position, and that is a crude Brittain wing leveler from the '60s.
[img]cid:part1.02080500.07090809(at)aviating.com[/img]
Albert Gardner wrote: [quote] [quote]--> RV10-List message posted by: "Albert Gardner" <ibspud(at)roadrunner.com> (ibspud(at)roadrunner.com) I believe you need the aileron trim with an autopilot. I have a TruTrak but you need to trim the aircraft before engaging the autopilot for two reasons. When you disengage the aqutopilot an out-of-trim condition will cause abrupt aircraft movement especially in pitch. Second, again especially in pitch, the autopilot may "slip" if the out-of-trim condition is too strong. That built-in slippage is what let's you overpower a runaway autopilot. Albert Gardner N991RV Yuma, AZ --
1.97 KB |
7444 Time(s) |
KCHD |
