Jim Berry
Posted: Thu Jan 14, 2010 5:09 pm Post subject: Door safety latch |
Van's has issued a service bulletin for their new door safety latch, which I installed 2 weeks ago. They have started shipping parts kits to those flying and those who have purchased finish kits. See attached link or go to Van's website.
The latch works very nicely and can also be used to pull the door inward while closing the door handle.
Jim Berry
40482
N15JB
| Door latch service bulletin |
sb10-1-4.pdf |
34.03 KB |
480 Time(s) |
Ron B.
Posted: Thu Jan 14, 2010 5:29 pm Post subject: Re: Door safety latch |
Any pictures or install drawings you can share?
rleffler
Posted: Thu Jan 14, 2010 5:38 pm Post subject: Door safety latch |
Jim,
Can you post a picture of the new latch?
bob
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
dlm46007(at)cox.net Guest
Posted: Thu Jan 14, 2010 5:39 pm Post subject: Door safety latch |
Anybody have the section 45A?
Jim Berry
Posted: Thu Jan 14, 2010 5:41 pm Post subject: Re: Door safety latch |
It looks very much like the Staniforth latch in the archives. I will take some pictures when I am out at the hangar tomorrow. My drawings are also at the hangar right now. With a little care, there should be no problem installing in a finished and painted door.
Jim Berry
40482
N15JB
Jim Berry
Posted: Fri Jan 15, 2010 11:13 am Post subject: Re: Door safety latch |
Attached are photos of the new door safety latch, which I think are self explanatory. It is my understanding that everyone with a finish kit will have their parts and drawings by the end of next week. The only thing I would consider changing is to increase the angle between the legs of the springs that you will fabricate. My personal preference would be for a stronger spring loading of the latch. I don't have a way to scan the large format drawings, but will try to photograph them and get them posted later today.
Jim Berry
40482
N15JB
22.49 KB |
14578 Time(s) |
30.92 KB |
14578 Time(s) |
41.38 KB |
14578 Time(s) |
47.77 KB |
14578 Time(s) |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Fri Jan 15, 2010 11:30 am Post subject: Re: Door safety latch |
Thanks Jim,
NO pressure there was there?
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
bwestfall
Joined: 22 Oct 2008 Posts: 131 Location: Portland, OR
Strasnuts
Posted: Fri Jan 15, 2010 12:11 pm Post subject: Re: Door safety latch |
When you are inside of the plane and want to open the door, how do you open the latch? Do you grab the edge of it. What am I missing here? Oh ya and you are on fire!
780 Hours
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
kearney
Posted: Fri Jan 15, 2010 12:59 pm Post subject: Door safety latch |
Hmmm
At least the Staniforth design had provision for opening on the interior. I
could see this getting jammed closed in the event of an accident - or at
least being very difficult to open.
What would really be nice would be the ability to open the door using the
main door handle and having this keep the door *slightly* ajar prior to an
off-field landing. On my Cherokee, part of the off field checklist is to
unlatch and unlock the door so it does not wedge shut in the event of an
accident.
Not knowing how tight this will hold the door, I am wondering if we are
trading on problem for another.
Cheers
Les
Deems Davis
rv10builder(at)verizon.ne Guest
kearney
Posted: Fri Jan 15, 2010 1:14 pm Post subject: Door safety latch |
But Deems,
Your -10 is way too pretty anyway.
I will duck for cover now...
Les
Deems Davis
Posted: Fri Jan 15, 2010 1:22 pm Post subject: Door safety latch |
What about attaching a 'grab strap' to the inside door catch? It would
serve for both opening and closing the doors from the inside?
Deems Davis
N519PJ
www.deemsrv10.com
Les Kearney wrote:
Hmmm
accident.
Cheers
Les
Phil.Perry(at)netapp.com Guest
I'm thinking of playing games with the color scheme. (Aka: alodine every other layer. Or alodine one layer darker than the other.)
Or even anodizing with a color that complements the interior.
I'm sure we'll have some machined versions soon though.
Phil
jchang10
Posted: Fri Jan 15, 2010 1:35 pm Post subject: Door safety latch |
http://www.glenrowanrestaurant.co.uk/loch_ness_monster.jpg
I saw this scottish influence personally. Anybody else see the
resemblance? I'm going to call it the Nessie Latch.
Jae
40533
Phil
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Posted: Fri Jan 15, 2010 2:03 pm Post subject: Door safety latch |
I find it rather ludicrous to build an efficient airplane only to hang
the handle and a speed brake on the outside of the door. IMHO, it's a
poor solution at best.
Linn
Jim Berry wrote:
scottmschmidt(at)yahoo.co Guest
Posted: Fri Jan 15, 2010 2:31 pm Post subject: Door safety latch |
(I posted this at VAF, I also am not very impressed)
I am going to have to think about this SB before installing.
It would have been nice to talk with the whole community of RV-10 builders before launching this SB. I do not feel it is necessary and is just an extra device that if not installed properly will not function correctly I would suspect. If you drive to root cause on the door issue it comes down to people not installing the warning lights, and not properly completing their pre-flight.
I don't want to offend anyone that has had their door come off but I have heard many stories about the doors that have come off, especially the one that hit the horizontal stabilizer and there were many other factors involved with that incident. Most of them will admit that the door was never fully closed before taking off. All of them should have been prevented through proper preflight and checklists.
If the current system is installed correctly, the indicator lights installed, it is very unlikely and almost impossible to have a problem. The only way for the door to open is if you squeezed the interlock on the handle and opened the door. I know there are many RV-10's flying around with no indicator lights on the doors and I don't understand why. They work so great. On my doors if the pin moves 1/8" away from fully closed the lights come on.
My preflight includes the following:
-Confirm door handle has locked into place
-Check all four corners for any obvious gap
-Check door ajar light
-Before takeoff, check all warning lights (includes the door ajar light)
If the proximity sensors are installed correctly it is IMPOSSIBLE not to have each of the four pins in their proper spot. If one is caught outside the cabin (which has happened to me when passengers try to shut the door before I get there) the light is on and there is an obvious gap.
Another concern I read about is the handle not locking into place. If yours does not, take it apart and fix it. Once mine snaps into place it will not rotate and is very safe.
I may find that this is a great addition after I have played with someones door that has this new addition but I won't be adding this to my experimental plane anytime soon. I worry about emergencies and having someone on the outside who is trying to get me and my family out try to understand that you have to lift the little handle, push the button and rotate the handle.
I agree that the door can be improved but this is a very poor band-aid. I don't want to get flamed here, I just want new builders to understand that the doors are not unsafe and if installed correctly with the warning lights and properly locking handles they are safe. New builders have this perception that the doors need a 100% redesign, and I don't want anyone to be scared off.
Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Fri, January 15, 2010 3:01:38 PM
Subject: Re: Re: Door safety latch
--> RV10-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
I find it rather ludicrous to build an efficient airplane only to hang the handle and a speed brake on the outside of the door. IMHO, it's a poor solution at best.
Linn
Jim Berry wrote:
[quote] --> RV10-List message posted by: "Jim Berry" <jimberry(at)qwest.net (jimberry(at)qwest.net)>
Jim Berry
40482
N15JB
[url=http://forums.matronics.com/viewtopic.php?p 81668#281668]http://forums.matronics.com/viewtopic.php?p 81668#281668[/url]
http://forums.matronics.com//files/img_0441_836.jpg
http://forums.matronics.com//files/img_0440_915.jpg
http://forums.matronics.com//files/img_0439_172.jpg
gommone7(at)bellsouth.net Guest
My spy inside Van's just send me the revision for the SB come out yesterday,will looking more efficient then the parachute of the outside lever of the previews SB
Any way I thinks I will adop this one
Hugo ---
On Fri, 1/15/10, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
| Quote: | -Matt
D==============
108.86 KB |
14530 Time(s) |
