dewittw(at)earthlink.net Guest
Posted: Thu Jan 14, 2010 12:34 pm Post subject: Question on best use of buttons on stick grip |
Fellow Grand Rapids customers:
We are in the midst of trying to decide what functions to assign to the buttons on our CS-8 Aircraft Grips from Tosten Mfg. ( http://tostenmanufacturing.com/catalog/aircraft-grips/cs-8-aircraft-grip.html# ). In addition to a 4-way hat switch, this ambidextrous grip has two face buttons, an index button and a trigger switch.
We, of course, will use the hat switch for the elevator and aileron trim. Initially, we thought of assigning the two face buttons (L and R) to the cowl flap (Open and Close). The trigger switch would be the Push To Talk and the index button "Acknowledge and turn checklist pages" for the VP-200.
However, after receiving suggestions from fellow Subie engine users, it appears the cowl flap actuator does not deserve such a prominent position on the grip and would work fine on the panel. There are other possible uses for the two face buttons if we didn't assign them to the cowl flap. For instance:
1. "Swap" button to allow the pilot to switch from the current Com to the other Com frequency. (Suggested by PS Engineering.)
2. VFR button for GTX 327 transponder (Suggested by Garmin.)
3. Remote Servo Disconnect/Pilot Controlled Steering button for our Trio Pro Pilot. (Strongly suggested by Trio.)
Any of you have experience of upside or downside of assigning all these buttons?
Dee Whittington
DeWitt (Dee) Whittington
406 N Mulberry St
Richmond, VA 23220-3320
(804) 358-4333 phone and fax
SKYPE: hilltopkid
GlaStar Sportsman 2+2 #7034, reserved N18TA
Eggenfellner E6 Subaru 3.6L with 2.01 redrive
dee.whittington(at)gmail.com
sarg314(at)gmail.com Guest
Posted: Thu Jan 14, 2010 1:04 pm Post subject: Question on best use of buttons on stick grip |
I used the extra buttons for comm radio flip-flop and transponder 'ident' button (I also have a GTX-327). Not flying yet, so I can't really tell if these are very useful.
Tom Sargent, RV-6A, final assembly.
Posted: Thu Jan 14, 2010 1:36 pm Post subject: Question on best use of buttons on stick grip |
I'm not flying either (RV10) but I'm using the 2 buttons for AP
disconnect and freq flip flop.
The little button on the backside I'm using for ident. Using it for
squawking VFR would probably be equally useful since either function is
used on average slightly less than once a flight.
I really like the Tosten grip. Had some concerns about the 'fit and
finish' appearance from the website picture but turns out it is a very
nicely designed unit. The swiveling ability seems like a winner too.
Can't wait to fly it.
Bill "just finished wiring the stick last week" Watson
RV10 Durham NC
DeWitt Whittington wrote:
| Quote: | Fellow Grand Rapids customers:
these buttons?
Dee Whittington
406 N Mulberry St
SKYPE: hilltopkid
pmather
Posted: Thu Jan 14, 2010 1:48 pm Post subject: Question on best use of buttons on stick grip |
Dee
I've got the two buttons as Com frequency switch and Trio servo disconnect - never used them !
Best regards
Peter
FisherPaulA(at)johndeere. Guest
Posted: Fri Jan 15, 2010 7:43 am Post subject: Question on best use of buttons on stick grip |
I too have one of these grips and I like it a lot. I’ve only got about 60 flight hours so far, but I’m happy with the switch selections:
4 way hat switch – as you stated, aileron and elevator trim
Trigger – Push to talk
Left top button – Com1/Com2 swap (function of the audio panel)
Right top button – Com1 active/standby frequency swap (SL-30)
Index button – Trio Autopilot and altitude hold disconnect
Obviously it depends on the kind of flying you do, but these have worked out well for me.
Paul A. Fisher
RV-7A N18PF (flying since August 2009)
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of DeWitt Whittington
Sent: Thursday, January 14, 2010 14:33
Subject: Question on best use of buttons on stick grip
… snip…
[quote] [b]
dfritzj(at)yahoo.com Guest
Posted: Fri Jan 15, 2010 8:24 am Post subject: Question on best use of buttons on stick grip |
I have the same sticks in my Velocity (not flying yet) and plan to use one of them as a remote autopilot disconnect.
I've flown many military aircraft and found a remote disconnect on the stick to be extremely useful when the glass starts to do something you'd rather it doesn't. With the button on the stick you can both disconnect the autopilot and begin your manual correction with one action. YMMV
Dan
Dennis Johnson
Posted: Fri Jan 15, 2010 9:26 am Post subject: Question on best use of buttons on stick grip |
I've been flying three years with the same stick grip and I'm very happy with it. Here is how I have mine wired:
Hat Switch: Elevator and aileron trim
Right Switch: Radio frequency flip/flop
Left Switch: Chelton audio warnings mute
Index Switch: Autopilot on/off
Trigger: Push to transmit on radio
Some of the switches share a common ground, which reduced the versatility a little. I had to add a relay to control the Chelton mute because merely connecting a pin to ground didn't work. I bought my stick grip from CH Products and the current one from Tosten appears to be similar.
A few times I've accidentally hit the frequency flip/flop switch. It would be nice if the left and right switches had ring guards to make accidental activation less likely. I certainly wouldn't want anything on those two switches if accidental activation could jeopardize safe flight.
Dennis
