oil adapter spacer
daveleikam(at)wi.rr.com
PostPosted: Wed Jan 13, 2010 5:42 pm    Post subject: oil adapter spacer Reply with quote
For those who have installed the B&C angled oil adapter, what size spacer did you need if any?
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
partner14
PostPosted: Wed Jan 13, 2010 6:07 pm    Post subject: oil adapter spacer Reply with quote
Dave, I was a real newbie when I ran into this issue.... and I didn't know the matronics board existed... Anyway, I made my own adaptor which attatched to the engine, and a second, stock, adaptor went on next. It looked to me that the mount needed to be both spaced rearward and offset. It appears to have worked.... engine performing beautifully, with all the right pressures, for over 100 hours.
Don McDonald
--- On Wed, 1/13/10, Dave Leikam <daveleikam(at)wi.rr.com> wrote:
Subject: oil adapter spacer
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Date: Wednesday, January 13, 2010, 5:42 PM
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
 Filesize:  660.61 KB
 Viewed:  2488 Time(s)
 Filesize:  163.01 KB
Don A. McDonald
40636
ricksked(at)cox.net
PostPosted: Wed Jan 13, 2010 6:39 pm    Post subject: oil adapter spacer Reply with quote
Dave you will need the adapter…here is a link to B & C and I think you need the .75 or ¾”…I really can’t remember…I need to go and measure if someone else doesn’t pipe in.
http://www.bandc.biz/oil-filter-adapter.aspx
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Wednesday, January 13, 2010 5:42 PM
To: RV-10 matronics
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
