LED lights & resin dispenser
Bob Wichita
PostPosted: Thu Jan 14, 2010 6:35 am    Post subject: LED lights & resin dispenser Reply with quote
Have been trying to find a LED direct replacement for the standard GE
landing light bulb.. With my 20 amp generator I can't run the Aeroflash
wingtip strobes and landing lights without the battery dieing. Don't really
want to try to build a unit if I can just buy one. Have checked all the
recommended web sites without any luck so far.
Anyone need an adjustable sticky stuff resin pump. Works fine but I'm done
with it. $150.00 plus shipping.
Bob, Wichita
flyboy3847(at)onecommail.
PostPosted: Thu Jan 14, 2010 7:58 am    Post subject: LED lights & resin dispenser Reply with quote
A standard light available at Auto Zone can be modified to fit in a Grimes
fixture. Just solder a jumper wire between the two bottom contacts.
Leroy Wheeler
601RX
PostPosted: Thu Jan 14, 2010 4:28 pm    Post subject: Re: LED lights & resin dispenser Reply with quote
Aero LED makes a direct replacement. It draws 3 amps, but is expensive
________
New Jersey Medical Marijuana
