roxianmike(at)msn.com Guest
Posted: Sat Jan 09, 2010 9:01 pm Post subject: door handle & mechanism |
I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this. After sanding the powder coat off of the shaft handle C the spring is still too small to move on the shaft and make the mechanism work. I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight. Maybe a bigger hammer tomorrow will bring success. [quote][b]
jeff(at)westcottpress.com Guest
Posted: Sat Jan 09, 2010 9:37 pm Post subject: door handle & mechanism |
Try filing out the area in the shaft that the pin travels up and down in... that's where mine bound up.
Jeff Carpenter
40304
On Jan 9, 2010, at 8:57 PM, Roxanne and Mike Lefever wrote:
| Quote: | I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this. After sanding the powder coat off of the shaft handle, the spring is still too small to move on the shaft and make the mechanism work. I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight. Maybe a bigger hammer tomorrow will bring success. | Quote: |
rvdave
Posted: Sat Jan 09, 2010 9:52 pm Post subject: Re: door handle & mechanism |
I thought maybe they gave me the wrong sized spring but I was able to unwind(?) the spring a little to fit the shaft and now works fine.
_________________ Dave Ford
Cadillac, MI |
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Sat Jan 09, 2010 9:58 pm Post subject: door handle & mechanism |
Spring for the cnc machined handles.... they work perfectly, are a direct Vans replacement, and they look WAY better.
Don McDonald
--- On Sat, 1/9/10, Roxanne and Mike Lefever <roxianmike(at)msn.com> wrote:
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Subject: door handle & mechanism
Date: Saturday, January 9, 2010, 8:57 PM
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
142.83 KB |
5086 Time(s) |
_________________ Don A. McDonald
40636 |
Posted: Sat Jan 09, 2010 10:04 pm Post subject: door handle & mechanism |
thanks
Subject: Re: door handle & mechanism
Date: Sat C 9 Jan 2010 21:15:39 -0800
Jeff Carpenter
40304
On Jan 9 C 2010 C at 8:57 PM C Roxanne and Mike Lefever wrote:
[quote] I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this. After sanding the powder coat off of the shaft handle C the spring is still too small to move on the shaft and make the mechanism work. I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight. Maybe a bigger hammer tomorrow will bring success. | Quote: |
ronics.com
kearney
Posted: Sun Jan 10, 2010 12:00 pm Post subject: door handle & mechanism |
Hi
Be careful when filing out the slot, do as little as possible. You will get a little "slop" in the handle movement as the pin can now wiggle a bit in the slot. I think you want to keep this to a minimum.
I also found that a little white grease goes a long, long way to making the mechanisms move easily and smoothly. There is a *huge* amount of internal friction in the mechanism. The grease deals with this effectively - or so I found. I put it on the tubes, gears and rails etc.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roxanne and Mike Lefever
Sent: January-09-10 11:01 PM
Subject: RE: door handle & mechanism
thanks
Date: Sat, 9 Jan 2010 21:15:39 -0800
Jeff Carpenter
40304
[quote] I can't be the first to declare the Van's door handle and mechanism a total RPITA.......although not an engineer..........even I could design a mousetrap better than this. After sanding the powder coat off of the shaft handle, the spring is still too small to move on the shaft and make the mechanism work. I thought bringing in my Saturday night consulting engineer Jack (Daniels) would help but we finally gave up tonight. Maybe a bigger hammer tomorrow will bring success. | Quote: |
ronics.com
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Jan 14, 2010 7:05 pm Post subject: door handle & mechanism |
Hey Don,
Where did you find these CNC machined handles?
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
kearney
Posted: Thu Jan 14, 2010 7:45 pm Post subject: door handle & mechanism |
Sean
If these are the ones you want : davidnellis691(at)comcast.net (davidnellis691(at)comcast.net)
I have a set and they are very nice. I also used Steve Deniri's billed handles on the outside for a nice flush fit.
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano
Sent: January-14-10 8:04 PM
Hey Don,
Strasnuts
Posted: Thu Jan 14, 2010 8:07 pm Post subject: door handle & mechanism |
Cool thanks
On Jan 14, 2010, at 20:30, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] Sean
If these are the ones you want : [url=mailto:davidnellis691(at)comcast.net]davidnellis691(at)comcast.net (davidnellis691(at)comcast.net)[/url]
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Hey Don,
780 Hours
