eddie.seve(at)clarity.com Guest
Posted: Mon Apr 17, 2006 3:39 pm Post subject: Rubber o-ring on the quick drain fuel fitting supplied by Ze |
Hi all,
I noticed that after fitting the fuel level sender to my right wing tank
and then sloshing the tank out with preium unleaded pertol to removed
dust etc. that the small o-ring on the fuel quick drain in the bottom of
the fuel tank had expanded in size and no longer provided a good seal,
in fact it looked like it would slide off completely if left alone, I
removed it and after a few hours it returned to its correct size. I was
under the impression that this should have been safe to use for MOGAS or
AVGAS, has anyone else had this problem, or do I need to install a
different type of o-ring.
Any suggestions would be appreciated.
Best Regards,
Eddie Seve
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon Apr 17, 2006 4:13 pm Post subject: Re: Rubber o-ring on the quick drain fuel fitting supplied b |
My guess is the mogas may have contained alcohol.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
