Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Jan 06, 2010 10:57 am Post subject: Overhead console configuration |
I need some pro-builders, that's all of you on the list, to help me
with my lights on the overhead. Pilots that have flown the 10 or
pilots that have flown a lot of other planes I need your advice. That
includes you Tim and Robin. I want all feedback I won't get my
feelers hurt. I don't want to punch unnecessary holes in my overhead
console. I have two configurations below but not limited to these.
Also, I will make some bezels for the LED's.
553 KB |
15167 Time(s) |
557.63 KB |
15167 Time(s) |
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
drfred(at)suddenlinkmail. Guest
Posted: Wed Jan 06, 2010 11:49 am Post subject: Overhead console configuration |
Strasnuts
First off, it looks good either way. I have a Accuracy avionics
overhead. I have a couple small LEDs fairly far forward, up by the four
nuts holding the center bar. I have done some night flying recently and
it seems that the sun visors will sometimes obstruct the light access to
the panel. Farther back may be better, for what it's worth.
Dr Fred
515FW
200 hrs.
Tim Olson
Posted: Wed Jan 06, 2010 11:53 am Post subject: Overhead console configuration |
I'd really recommend the dome light for up front, and one
in the back if you wish as an option. The one in front
is very handy. My click-lights work in the back OK for
the kids, but if you wire up one, you could just as easily
wire up the second for the rear seat.
Then, for spot/moveable LED's, I'd really recommend that
the front have TWO of them, and that they be moveable.
I find that I could even use 3 if you want full lighting
on everything up front. What I usually do is when we're
in cruise, I dim everything as much as possible, but turn
my 2 overhead red lights so that I can see all the panel
switches well, and the co-pilot side is on the throttle
quadrant area. I leave the side by the breakers only
dimly lit...nothing aimed at them. In an ideal world,
I would have a left, right, and center. But you'll
want all switches to have some sort of illumination
to make them visible at night. don't find that a
glareshield light would do a fantastic job of lighting
switches down on the bottom of the panel without it being
really bright, and I don't like any bright lighting in the
cockpit at night. I dim the EFIS's, and everything else
to the minimum.
So, with that in mind, I like the photo with the 2
eyeball lights best. You may want eyeballs in the rear,
too. I put some lighting back by the rear air vents
that seems to be OK for the girls....although I
should probably make it brighter than what have today.
Tim Olson - RV-10 N104CD
Strasnuts wrote:
rleffler
Posted: Wed Jan 06, 2010 11:59 am Post subject: Overhead console configuration |
Sean,
Are those your only lighting on the overhead?
The reason I ask, is that I really like what Geoff did in his overhead. He
has an eyeball type of light used for map/task lighting for each passenger.
He has two of Stein's cockpit lights (B-12) mounted on the forward portion
of the overhead to wash the instrument panel, and one the dome lights that
Van's sells in the front and back seats, and two in the baggage area for
maintenance/cleaning.
I think this strategy of three different types of lighting is pretty
effective.
I'm sure you can talk Geoff into sharing a photo of his installation.
Ironically, he doesn't have one of his own overheads. That project didn't
start until his was almost ready to fly.
bob
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
Strasnuts
Posted: Wed Jan 06, 2010 12:07 pm Post subject: Re: Overhead console configuration |
I may send back the Aveoflash eyeballs. They are really cool how they work but they are big and need protection tape like that on an Iphone screen. I was wondering too if the rear passengers should have a red light also so the pilot doesn't get blinded by the white light. I like the input so far, I may still get two red LED lights from Stein to put on the forward slants on the overhead. How many lights is too many? I will have two eyebeams two big LED white lights, two red leds from Stein's AND a baggage light.
780 Hours
Strasnuts
Posted: Wed Jan 06, 2010 12:10 pm Post subject: Re: Overhead console configuration |
Oh ya, I also might also buy this and cut out the pocket so I can fit it inside the console and feed it video from a double din from the panel. This way it won't stick out of the console unless it is being used. Any other ideas on video screens? I heard some people say they are in the way of the rear passengers.
780 Hours
Strasnuts
http://www.crutchfield.com/p_077RM890W/Valor-RM-890W.html?tp=77
780 Hours
aerosport1
Posted: Wed Jan 06, 2010 12:26 pm Post subject: Overhead console configuration |
Sean here is a picture of what I did. So far I really like the setup. Each
passenger has there own LED reading light eyeball from Stein. Small but
works good. Those have there own on-off switch next to them. I then have the
small silver dome lights in the cockpit area, passenger area and then 2 in
the baggage area as my dome lights. Last I have the Blue LED adjustable
lights that I can shine on the panel or turn down to the pilot or copilot.
Although I do not have a lot of time in the airplane this seems to work
well. I like the idea of putting as many of the lights in the removable
panels so if for some reason a really cool light comes out that you have to
have you do not have hole to fill in the overhead just replace the panel
insert or fill it and repaint. The only problem I have is I cannot get my
head sets on the head set holders in the front as planned. The lights I
placed to close in. I had them mounted before I decided to put the head
Set hangar in. All you need to do is move them out as far as possible.
Hope this helps
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
447.71 KB |
15150 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Strasnuts
Posted: Wed Jan 06, 2010 12:41 pm Post subject: Re: Overhead console configuration |
That's nice Geoff, I like the switches for the little eyeballs. I want to make my eyebeams work but don't know where to put them. I'm re-installing the canopy right now so I can sit inside and see if the eyebeams can move far enough forward to the panel. I think I will add the eyeballs you have with the switches for each passenger.
780 Hours
Phil.Perry(at)netapp.com Guest
Posted: Wed Jan 06, 2010 12:44 pm Post subject: Overhead console configuration |
I really wanted the Aveo's but your experience has started to turn me
off. (... and save me money)
Now I'm leaning toward Stein's lights (2x) front, (2x) rear, 1(x)
baggage. I'm planning to us a off/on-dimmer in the front for each light
and the same thing for the rear seats. That makes a total of four
off/on-dimmers for local control.
But, I'm also planning to install a master (read "Kiddie") switch for
the rear lights. So I can shut them off up front and don't have to
worry about a kid flipping on lights unless I want them to. If I were a
kid, I'd do it just to make dad turn around and slap me... I know how I
thought.
The baggage light will have its own pair of switches.
1) Local in the baggage compartment to help during
loading/unloading.
2) Cockpit switch: So mom can crawl back there in flight and dig
through bags for diapers, bottles, and band-aids.
Phil
Tim Olson
Posted: Wed Jan 06, 2010 12:47 pm Post subject: Overhead console configuration |
You'll want the rear seaters to have SOMETHING other than
a bright light. We won't let the kids use any bright
lights in the back during flight. Red, Blue, whatever...
you won't want it bright. Having those 2 Stein lights
forward sounds like a good idea...then you can do
whatever you want overhead. I find I can reach up and turn
those forward lights to my lap if I need them....so other than
the white dome, I don't have anything separate, and don't need
it. I keep a 2 color (white/red) flashlight by each pilot
seat too.
A baggage light will be handy. I used a click-light back
there too. One less pair of wires to run,and when
you're unloading you don't need to leave a master on
or worry about leaving a light on if you directly tie
it to a battery bus. Click lights can be very handy since
they're bus independent.
Strasnuts wrote:
-------- Cust. #40936 RV-10 SB Fuselage N801VR reserved
http://forums.matronics.com/viewtopic.php?p 80407#280407
Tim Olson
Posted: Wed Jan 06, 2010 12:50 pm Post subject: Overhead console configuration |
For most people, overhead video screens won't be very comfortable
to view. Especially kids. It's just plain too high up. I'd
skip it and find something you can lower. Even monitors that
you can hold in your hands and plug in up top would be better.
Strasnuts wrote:
Tim Olson
Posted: Wed Jan 06, 2010 12:51 pm Post subject: Overhead console configuration |
Yeah, now that is excellent.
Geoff Combs wrote:
[quote] Sean here is a picture of what I did. So far I really like the setup. Each
Hope this helps
Geoff
Geoff Combs
President
614-834-5227p
614-834-5230f
rleffler
Posted: Wed Jan 06, 2010 1:15 pm Post subject: Overhead console configuration |
Probably more cost effective just to use portable units. I did that in my
SUV. I also bought a couple cheap lcd screens that can be slaved off the
player. The other item to keep in mind is the conversion from dvd to
blu-ray. I'm already a having issues at home. We only buy blue-ray, but
only have one blue ray player at the moment.
For these reasons, I've decided to not installed any permanent entertainment
in the RV-10.
N410BL - Phase I
aerosport1
Posted: Wed Jan 06, 2010 1:19 pm Post subject: Overhead console configuration |
One other thing I forgot to mention was I used TCW's intelligent lighting
system and it is awesome. My Dome lights can be dimmed as well as the front
blue lights. The dimmer is the on-off switch as well. It has the wig wag.
Easy to install. It also dims my switches and what ever else you might need.
Geoff
Geoff Combs
President
614-834-5227p
614-834-5230f
RV-10 QB N829GW
Flying 500 hrs
40033 |
Tim Olson
Posted: Wed Jan 06, 2010 1:48 pm Post subject: Overhead console configuration |
Exactly....I've already dumped my old hard drive based players
and got the kids apple ipod touches, which means all the work
I did to make charging accessories for those from plane power
is gone. So for things that change over time, I'd say stay
portable. How many people owned portable VHS players...how'd
you like to have one in your car/plane today? DVD's are
not going to be THE thing forever...especially with Blu-Ray
out. So for entertainment electronics, keeping it portable
but coming up with a nice fixed distribution is maybe a good
idea. This annual my plan is to permanently mount my video
splitter, install a couple of rear-seat USB charging jacks,
and find a way to make it so that one kid can plug in their
ipod to standard composite video jacks and have it play
on both portable screens. I can do it right now, but I don't
have the distribution hard mounted, so it's a bag of stuff
to bring along.
Actually, like Scott was talking about, if Apple makes their
tablet PC available soon, that might be a cool thing to use
for in-flight video...just load the sucker up like a big
ipod and then plug the audio in to your intercom.
in the RV-10.
MauleDriver(at)nc.rr.com Guest
Posted: Wed Jan 06, 2010 1:58 pm Post subject: Overhead console configuration |
Has anyone used both red and blue lights enough to have a preference?
I've flown with red but never with blue.
Bill
ricksked(at)cox.net Guest
Posted: Wed Jan 06, 2010 2:03 pm Post subject: Overhead console configuration |
After wandering through CES.....everything you own is now obsolete....some really coooool stuff
Sent via BlackBerry by AT&T
Strasnuts
Posted: Wed Jan 06, 2010 2:15 pm Post subject: Overhead console configuration |
I like the idea of power usb's and the tablets. I just noticed the
screens coming out that are paper thin, flexible and you can wear them
on a t-shirt. I'm now convinced to not install any permenant
entertainment except my garmins of course.
to bring along.
> that in my
> off the
> ray, but
> entertainment
> in the RV-10.
780 Hours
rv10builder(at)verizon.ne Guest
Posted: Wed Jan 06, 2010 4:51 pm Post subject: Overhead console configuration |
| Quote: | The baggage light will have its own pair of switches.
loading/unloading.
I spoke to a couple of flying RV-10 builders and they told me to get a
portable LED light that I can just velcro and use as needed as they have
used their baggage switch less than a hand full of time sin the last 2
years. Just a thought on maybe an easier solution.
Sent: Wednesday, January 06, 2010 12:35 PM
Subject: RE: Re: Overhead console configuration
thought.
loading/unloading.
Phil
