ces308
Joined: 03 Nov 2008 Posts: 317 Location: houghton lake ,mi
Posted: Mon Feb 22, 2010 7:58 pm Post subject: corrosion in the crank hub.. |
Hi all,
Does anyone out there know the AD on pulling the plug at the end of the crank to check for corrosion on a o-320-e2d? And is it a one time check or repetitive??
chris ambrose
172-k
N79308
| | - The Matronics LycomingEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?LycomingEngines-List |
ces308
Posted: Mon Feb 22, 2010 10:11 pm Post subject: Re: corrosion in the crank hub.. |
Never mind all....I found it.....98-02-08,if anyone was looking...
chris ambrose
dsleepy47
Posted: Mon Feb 22, 2010 10:49 pm Post subject: corrosion in the crank hub.. |
Sorry, here is the link I wanted to send: http://www.lycoming.textron.com/support/publications/service-bulletins/index.html
Deems
[quote] Subject: corrosion in the crank hub..
Date: Mon, 22 Feb 2010 19:58:43 -0800
To: lycomingengines-list(at)matronics.com
--> LycomingEngines-List message posted by: "ces308" <ces308(at)ldaco.com>
Hi all,
chris ambrose
172-k
N79308
http://forums.matronics.com/viewtopic.php?p=287751#287751
&g========================Hotmail: Free, 69228/direct/01/' target='_new'>Get it now.
_________________ dsleepy47
N1491R |
dsleepy47
Posted: Mon Feb 22, 2010 10:50 pm Post subject: corrosion in the crank hub.. |
The short answer is yes and no. Uncoated (not stamped PID) crankshafts have a repetitive inspection until coated or removed from service. If no pitting is found the SB has instructions on coating and marking the crankshaft and after the coating no inspection is required. The SB does not apply to engines shipped new after 2/15/1997. The recurring requirements depend on if the crankshaft is pitted or not.
Go here for a copy of the service bulletin.
Deems
| Quote: | Subject: LycomingEngines-List: corrosion in the crank hub..
Hi all,
chris ambrose
172-k
N79308
Hotmail: Trusted email with powerful SPAM protection. Sign up now. [quote][b]
N1491R |
ces308
Posted: Mon Feb 22, 2010 11:46 pm Post subject: Re: corrosion in the crank hub.. |
Thank you very much !
chris ambrose
