rparigoris
Posted: Mon Jan 04, 2010 11:11 am Post subject: What happens if you overspeed a 91X? |
Hi IraI am curious what failure occurs if you overspeed a 91X?You mentioned:" what will happen is that above 6000 engine rpm, the speed of the hydraulic valve lifters is inadequate to completely open and close. They essentially float out of synch and get bent out of straight by the cams."I am not sure what you said, do the hydraulic valve lifters themselves get bent by overspeed? I always assumed that the mass of valve train has more inertia than can be held by the valve springs where the valve lifters are in contact with the cam (valve float)? Then a valve is left opened where it shouldn't be and a piston contacts the valve and bends the valve, and probably also the pushrod? Another question, since the 912S has a different cam grind than the 912 or 914, does overspeed problems occur at the same RPM as 912 or 914?Thx.Ron Parigoris [quote][b]
bob(at)fly-ul.com Guest
Posted: Mon Jan 04, 2010 11:47 am Post subject: What happens if you overspeed a 91X? |
On 11:10 AM 1/4/2010, rparigor(at)suffolk.lib.ny.us wrote:
| Quote: | Then a valve is left opened where it shouldn't be and a piston contacts the valve and bends the valve, and probably also the pushrod?
For what its worth, In the 912 Line maintenance manual (05-50-00, section 3.3), the inspections exceeding max RPMs are addressed. Yes, Pushrods are on the "list" of things to inspect.
Bob Comperini
e-mail: bob(at)fly-ul.com
WWW: http://www.fly-ul.com
rampil
Posted: Mon Jan 04, 2010 5:19 pm Post subject: Re: What happens if you overspeed a 91X? |
Hi Ron,
It did not occur to me that the cams are different on the different
models.
As for different frequency response of the valve train, sounds like a
factory question. No one else would have an engine closely instrumented
to detect the float and over-sped to destruction. The cams should only
be different in amplitude, not angular change. The float is a
phenomena of frequency response so it should be a function of spring
compliance and push rod inertance. (Hows that for an x engineer)
Happy New Year!
davidjoyce(at)doctors.org Guest
Posted: Tue Jan 05, 2010 2:12 am Post subject: What happens if you overspeed a 91X? |
Ron, The UK Rotax agent procedure for modest overspeeding (between 6000 &
6100 rpm) was to remove the push rods and check them for straightness using
a sort of cradle and a micrometer measuring device. If that is OK no further
checks are needed.
Regards, David Joyce, G-XSDJ
rampil
Posted: Tue Jan 05, 2010 7:12 am Post subject: Re: What happens if you overspeed a 91X? |
Hi All,
The push rod check is all that is required IF the overspeed <6200 AND
less than 1 minute in duration. Overwise, the requirements escalate
expensively! This is per page 10 of the Unscheduled Checks section
of the new Line Maint manual(912, 912S).
Ira
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Tue Jan 05, 2010 7:58 am Post subject: Re: What happens if you overspeed a 91X? |
| bob(at)fly-ul.com wrote: |
Bob Comperini
WWW: http://www.fly-ul.com |
Unfortunately the manual leaves out the following step in this case:
- go to bank (with gun)
LS
_________________ LS
Titan II SS |
