jfrjr(at)roadrunner.com Guest
Posted: Wed Dec 30, 2009 2:49 pm Post subject: Loose steps |
I still have not flown (DAR tomorrow then wait for runway(s) to de-ice) and already my pilotside step is a little loose. I remember that TCW had machined an insert that they said worked well. Are those commercially avialable or are there any other "fixes" out there. I did construct access panels so I can get to those pesky AN-3 bolts. Jay Rowe
jeff(at)westcottpress.com Guest
Posted: Wed Dec 30, 2009 4:45 pm Post subject: Loose steps |
I'm planning to pour epoxy/flocks in to the step with mold release on
the bolt. Nick Gautier ran a test on this, putting it through a
number of hot/cold shock cycles. As I recall, it took a significant
and immediate temperature change for the flocks to separate from the
inside of the step.
Jeff Carpenter
40304
On Dec 30, 2009, at 2:12 PM, <jfrjr(at)roadrunner.com> <jfrjr(at)roadrunner.com
> wrote:
rv10rob(at)gmail.com Guest
Posted: Mon Jan 04, 2010 10:46 am Post subject: Loose steps |
I used the insert that Bob (TCW) sells: http://tcwtech.com/RV-10-construction-project.htm
One change is I drilled the holes in the steps and mounts to 1/4 and in the insert to 5/16 to enable the use of an AN4 bolt. They're rock solid now.
-Rob
On Wed, Dec 30, 2009 at 2:12 PM, <jfrjr(at)roadrunner.com (jfrjr(at)roadrunner.com)> wrote:
| Quote: | --> RV10-List message posted by: <jfrjr(at)roadrunner.com (jfrjr(at)roadrunner.com)>
is the Annual List Fund Raiser. Click on
-= * AeroElectric www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
contribution" target="_blank">http://www.matronics.com/contribution
-Matt Dralle, Li - The RV10-List Email Forum -
0-List" target="_blank">http://www.matronics.com/Navigator?RV10-List< - MATRONICS WEB FORUMS -
= --> h
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
