Fergus Kyle
Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
Posted: Sat Jan 02, 2010 7:34 am Post subject: Aft battery |
I seem to recall someone placing his/her battery aft to balance the aircraft. I would like to ask if that someone would be kind enough to describe how the square-type item is mounted in the roundie-kind aft fuselage – contoured bulkheads, foam filler, size plywood etc.
Thanks, Ferg
Still wiring [quote][b]
frans(at)paardnatuurlijk. Guest
Posted: Sat Jan 02, 2010 8:17 am Post subject: Aft battery |
On 01/02/2010 03:23 PM, Fergus Kyle wrote:
Quote: | I seem to recall someone placing his/her battery aft to balance the
fuselage - contoured bulkheads, foam filler, size plywood etc.
I made an aluminium tray for the batteries, that "hangs" on the bagage
floor.
This tray is also the mount for the starter relay, and mass rail.
The bagage floor is stronger than the fuselage at that point, allows for
easy access, and you don't have to drill holes through the fuselage skin.
Frans
rlborger(at)mac.com Guest
Posted: Sat Jan 02, 2010 10:12 am Post subject: Aft battery |
Ferg,
Go to my build web site, album Year#7 Q3 2008, page 5 and you will see a couple pics on how I handled the situation.
My friend Tommy made the base and strap for the battery so it is metal. When a friend asks to help, you don't question, you accept the assistance.
I probably would have done something with a thin sheet of urethane foam covered in a ply or two of fiberglass, but this worked very well.
You can see that it was bonded under the starboard side baggage bay with Araldite so there are no holes in the fuselage and it's not going anywhere.
Hope this helps...
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Jan 2, 2010, at 8:23, Fergus Kyle wrote:
Thanks, Ferg
Still wiring Quote: |
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
rparigoris
Posted: Sat Jan 02, 2010 10:42 am Post subject: Aft battery |
Hi Ferg"someone placing his/her battery aft to balance the aircraft."Here is info on my aft battery install: http://www.europaowners.org/forums/gallery2.php?g2_itemId=30710Note the "Kool" balsa battery hold down. If by chance I needed to move the box, easy cut bid and move.If by chance you are still nose heavy, here is an idea I implimented that also removes about 15% of the stress on the stabilator drive pins:[url=http://www.europaowners.org/forums/gallery2.php?g2_itemId 8658]http://www.europaowners.org/forums/gallery2.php?g2_itemId 8658[/url]Ron Parigoris [quote][b]
Posted: Sat Jan 02, 2010 2:25 pm Post subject: Aft battery |
Hi! Ferg
Happy New Year .
I started with a serious weight and balance issue with the Jabiru 6 seemingly needing the battery mounted aft. I made a base out of foam and glassed it all to the floor with hard points and through bolts to restrain the battery …..until I found that the length of the leads so needed wouldn’t start the damn engine! Reverted to mounting them on the passenger side foot well within about 18” of the starter and then never had a problem with weight and balance OR starting! But have two Oddesy 13AH Batteries in parallel and a heavy duty starter on my now 914 !
Happy Days !
Bob Harrison G-PTAG
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fergus Kyle
Sent: 02 January 2010 14:23
To: EUROPALIST
Subject: Aft battery
Thanks, Ferg
Still wiring 0123456789
milneab(at)btinternet.com Guest
Posted: Sun Jan 03, 2010 12:15 am Post subject: Aft battery |
Make a battery box with a rim (glass and resin - I used the transit box as a form) and bond it to the baggage bay floor clear of the flap tube so that a hatch is the lid . That saves wrinkling the bottom fuselage skin, holds the battery securely when the hatch is screwed down and retains the battery connection washers and wing nuts when you drop them.
Alasdair Milne
davidjoyce(at)doctors.org Guest
Posted: Sun Jan 03, 2010 3:40 am Post subject: Aft battery |
Ferg, It seems to me there are real advantages in having the battery forward
(as Bob Harrison + convenient access). Even with a 914, a Woodcomp SR3000, a
17 amp hr Odyysey, and a very full panel, I found that a forward battery
gave me an ideal C of G position with 3 lbs of lead fixed to the rudder post
in the fin. 3 lbs is probably less than the wire needed to get decent
performance from an aft placed battery. So I would recommend planning
forward until proved otherwise.
Regards, David Joyce, G-XSDJ
Posted: Sun Jan 03, 2010 4:58 am Post subject: Aft battery |
Ferg
you are not overweight so I agree with David
Graham
David Joyce wrote:
<davidjoyce(at)doctors.org.uk>
Ferg, . So I would recommend planning forward until proved otherwise.
rparigoris
Posted: Sun Jan 03, 2010 10:23 am Post subject: Aft battery |
Hi DavidI calculated CG with battery mounted on firewall versus aft mounting butting baggage ribs. Even with using number 4 copper Tefzel cable there is a weight savings with an aft battery. I have my PC545 mounted aft of baggage bulkhead and there is even more of a weight savings and using #4 copper clad aluminium wire as sold by Eric Jones, even more. One advantage for me is i am not using a battery main relay, but instead a switch from Flaming river mounted on the headrest. I also have a selection of circuit breakers and switches just aft of passeneger headrest. an aft battery easily allows this. For simplicity no question battery on firewall, for weight savings aft mounted.Here is stuff in headrest that aft mounting makes possible that moves CG aft as well:http://www.europaowners.org/forums/gallery2.php?g2_itemId=30502I have my shoulder harness mounted just aft of rear door closeout so passenger headrest need not be very structural:[url=http://www.europaowners.org/forums/gallery2.php?g2_itemId 7386]http://www.europaowners.org/forums/gallery2.php?g2_itemId 7386[/url]Switch saves weight and power over relay, details:http://www.europaowners.org/forums/gallery2.php?g2_itemId=30683Ron Parigoris [quote][b]
Posted: Sun Jan 03, 2010 1:58 pm Post subject: Aft battery |
forward (as Bob Harrison + convenient access). Even with a 914, a
Woodcomp SR3000, a 17 amp hr Odyysey, and a very full panel, I found
that a forward battery gave me an ideal C of G position with 3 lbs of
lead fixed to the rudder post in the fin. 3 lbs is probably less than
the wire needed to get decent performance from an aft placed battery.
I have an aft placed battery (well, actually two), and the wires needed
weigh closer to 1 lbs than 2 lbs (and not even substracting the weight
of the wires you would need anyway with a forward placed battery.) "Aft"
may sound like it is awfully far away, but in reality, it is just a few
feet more than on the footwell, nothing to worry about. I used the
copper clad aluminium wires from Eric Jones.
The 914 cranks superb, as if the battery is placed next to the engine.
I still don't know how my C of G will turn out (weather isn't
cooperating; I would have to trailer the ship to a weighing station, but
don't want to do this on roads covered with snow and salt), but I
suspect that with a 914 with dual alternator, intercooler and SR3000, an
aft placed battery has an advantage here.
To carry around 3 lbs of non functional lead, after all the painstaking
weigh savings during the built, is well, quite a waste to my opinion,
and something to be avoided if possible.
Frans
