cowl for 601hds
rflick(at)ovalinternet.ne
PostPosted: Sat Jan 02, 2010 6:09 am    Post subject: cowl for 601hds Reply with quote
looking for a cowl to fit my 601hds with a corvair but i can probably modify some others to fit. maybe even a damaged one. thanks ralph
craig(at)craigandjean.com
PostPosted: Sat Jan 02, 2010 10:42 am    Post subject: cowl for 601hds Reply with quote
Isn't the firewall on the HDS the same shape as the XL? The standard solution for many Corvair powered planes (including XLs) is William Wynne's generic nose bowl and metal fairings back to the firewall. I believe he sells the metal parts pre-made now. This does raise the question - whose motor mount design are you using?
You could also ask your question on the Corvair list:
http://www.krnet.org/corvaircraft_inst.html
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Flick
Sent: Saturday, January 02, 2010 6:07 AM
Subject: cowl for 601hds
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Afterfxllc(at)aol.com
PostPosted: Mon Jan 04, 2010 9:24 am    Post subject: cowl for 601hds Reply with quote
 Filesize:  34.12 KB
 Viewed:  3044 Time(s)
 Filesize:  26.77 KB
