Grommet supplier
Eric_Kallio
PostPosted: Fri Jan 01, 2010 11:35 am    Post subject: Grommet supplier Reply with quote
I have been searching through the normal places for the grommet type thing Ed Hayden used to get the 3 light speed ignition wires through the baffling to get under the plenum. The picture attached is from Deems website, and shows the part I am looking for.
Eric Kallio
N518RV wiring and panel installation
 Filesize:  67.71 KB
 Viewed:  3191 Time(s)
pitts_pilot(at)bellsouth.
PostPosted: Fri Jan 01, 2010 12:59 pm    Post subject: Grommet supplier Reply with quote
Page 280 of the AA catalog has a lousy picture so I don't know if it's
the same type.
Linn
Eric Kallio
http://forums.matronics.com/viewtopic.php?p 79632#279632
http://forums.matronics.com//files/ignition_wire_pass_through_662.jpg
ricksked(at)cox.net
PostPosted: Fri Jan 01, 2010 1:03 pm    Post subject: Grommet supplier Reply with quote
Eric
That's a ignition wire grommet available from Spruce under engine ignition accessories
Rick S.
