PaulR
Posted: Tue Dec 29, 2009 5:31 pm Post subject: Audio Question |
I'm woefully short of 3 conductor shielded wire for wiring the headphone jacks but have plenty of 6 conductor shielded. Would it cause problems to use this in lieu of the separate pcs. of 3 conductor? I have a PSE intercom if that makes a difference.
Also, the serial lines that Dynon, Garmin and about everyone else uses are shown both shielded and un-shielded. As long as ALL equipment utilizing the serial signals are grounded the same place (AVX GND) is it necessary to shield them?
_________________ Paul Rose
N417PR
RV-9A |
Posted: Tue Dec 29, 2009 6:10 pm Post subject: Audio Question |
At 07:31 PM 12/29/2009, you wrote:
First, I've got a couple thousand feet of shielded
triple, if that's what you'd LIKE to be using,
I can make you a great deal on it. On the other-hand,
twisted pairs in lieu of shielded wires will
probably be just fine in the cockpit and behind
the panel. Make sure the magneto p-leads are
shielded and wired per Z-figures. After that,
risks to other signals are very low.
| Quote: | Also, the serial lines that Dynon, Garmin and about everyone else
As short as they are and living in a behind the
panel environment, twisted pairs are okay too
along with any adaptation you care to devise
with the 6 wire cable you already have.
