Flap motor brushes
Allen Fulmer
PostPosted: Tue Dec 29, 2009 6:06 am    Post subject: Flap motor brushes Reply with quote
“Well, now I’ve gone and done it!” Flap motor installed but I decided I would see what folks were talking about with flap motor/gearbox grease causing problems. While trying to put the motor back together I managed to break one of the carbon brushes trying to get it back in its little hole! $389 for whole flap motor assembly, $89.00 for replacement motor from Allied Electronics (http://www.alliedelec.com/search/productdetail.aspx?SKU=3880012), no luck on just the brush holder and brushes so far.
Anyone else had to replace the brush holder and brushes or complete flap motor?
Can I get away with replacing just the motor?
Allen Fulmer
RV7 Finishing wiring
Alexander City, AL
RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL
recapen(at)earthlink.net
PostPosted: Tue Dec 29, 2009 6:44 am    Post subject: Flap motor brushes Reply with quote
Allen,
The motor doesn't look like the exact same thing. It may be functionally, but I would be wary of the size. Also, I think that the little gear on the end will be your biggest problem.
If the motors are enough alike, you can take the brush assy from the new motor and use it on the original....just a thought.
I've had to clean mine already too - so I know what a bugger it can be.
Ralph
pitts_pilot(at)bellsouth.
PostPosted: Tue Dec 29, 2009 6:54 am    Post subject: Flap motor brushes Reply with quote
I've heard that Home Depot has brushes, but never looked for them. If the brushes aren't an exact match, they can be carefully sanded to size .... carefully, as you well know!!! Good luck, and let us know how it turns out.
Linn
Allen Fulmer wrote: [quote] <![endif]--> <![endif]-->
Allen Fulmer
Alexander City, AL
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.howtocrimp.com">www.howtocrimp.com
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
chaskuss(at)yahoo.com
PostPosted: Tue Dec 29, 2009 10:49 am    Post subject: Flap motor brushes Reply with quote
Allen,
Stan Gould posted about this in May of last year. I saved the info and will send you a copy off list.
Charlie Kuss
--- On Tue, 12/29/09, Allen Fulmer <afulmer(at)charter.net> wrote:
Subject: Flap motor brushes
To: "Rv-List(at)Matronics." <rv-list(at)matronics.com>
Date: Tuesday, December 29, 2009, 8:49 AM
it!”
were talking about
assembly, $89.00
far.
motor?
Allen Fulmer
Alexander City, AL
provided
HCRV6(at)comcast.net
PostPosted: Tue Dec 29, 2009 4:05 pm    Post subject: Flap motor brushes Reply with quote
Hey Charlie, how about posting that info to the list as well. A lot of us would like to have it just in case.
Harry Crosby
RV-6 N16CX, 648 hours
PostPosted: Tue Dec 29, 2009 4:52 pm    Post subject: Flap motor brushes Reply with quote
No can do. It involves photos, which won't post. I actually saved it all as a pdf file, which won't post either. I'll send you a copy off list.
Charlie
--- On Tue, 12/29/09, HCRV6(at)comcast.net <HCRV6(at)comcast.net> wrote:
[quote] From: HCRV6(at)comcast.net <HCRV6(at)comcast.net>
Subject: Re: Flap motor brushes
To: rv-list(at)matronics.com
Date: Tuesday, December 29, 2009, 6:58 PM
#yiv83213696 p
{margin:0;}Hey
Harry Crosby
PostPosted: Tue Dec 29, 2009 5:55 pm    Post subject: Flap motor brushes Reply with quote
Charlie, this a test of a photo .... showing my re-routed brake lines as an insert to the email and as an attachment.  Hope it works. Linn
[img]cid:part1.08000307.02030405(at)bellsouth.net[/img]
Charles Kuss wrote: [quote] [quote]--> RV-List message posted by: Charles Kuss <chaskuss(at)yahoo.com> (chaskuss(at)yahoo.com)
Charlie
--- On Tue, 12/29/09, HCRV6(at)comcast.net (HCRV6(at)comcast.net) <HCRV6(at)comcast.net> (HCRV6(at)comcast.net) wrote:
[quote]From: HCRV6(at)comcast.net (HCRV6(at)comcast.net) <HCRV6(at)comcast.net> (HCRV6(at)comcast.net) Subject: Re: Flap motor brushes To: rv-list(at)matronics.com (rv-list(at)matronics.com) Date: Tuesday, December 29, 2009, 6:58 PM #yiv83213696 p {margin:0;}Hey Charlie, how about posting that info to the list as well.  A lot of us would like to have it just in case. Harry Crosby RV-6 N16CX, 648 hours ---
 Filesize:  201.6 KB
 Viewed:  6535 Time(s)
 Filesize:  201.6 KB
PostPosted: Tue Dec 29, 2009 5:59 pm    Post subject: Flap motor brushes Reply with quote
Harry,
Here is some of the info. There is actually an early and a late flap motor. Vans changed vendors in 2002. The whole story on that can be found here.
http://www.vansaircraft.com/pdf/flap_motor.pdf
You can find lots of info on the flap motors here
http://www.vansairforce.com/community/showthread.php?t=5824&highlight=Flap+motor+brushes
Charlie
#yiv601653149 p
{margin:0;}Hey
Harry Crosby
PostPosted: Tue Dec 29, 2009 7:53 pm    Post subject: Flap motor brushes Reply with quote
Here is the info I mentioned earlier.
Charlie
RV_Flap_Motor_Info.pdf
 Filename:  RV_Flap_Motor_Info.pdf
 Filesize:  70.52 KB
 Downloaded:  4358 Time(s)
PostPosted: Tue Dec 29, 2009 8:05 pm    Post subject: Flap motor brushes Reply with quote
Linn,
I stand corrected. I'll post the document to the list.
Charlie
Date: Tuesday, December 29, 2009, 8:42 PM
[img]cid:1.2640675711(at)web51302.mail.re2.yahoo.com[/img]
Charles Kuss wrote: [quote] [quote]--> RV-List message posted by: Charles Kuss HCRV6(at)comcast.net (HCRV6(at)comcast.net) HCRV6(at)comcast.net (HCRV6(at)comcast.net) [url=/mc/compose?to=HCRV6(at)comcast.net]<HCRV6(at)comcast.net>[/url]
To: [url=/mc/compose?to=rv-list(at)matronics.com]rv-list(at)matronics.com[/url]
#yiv83213696 p
{margin:0;}Hey
Harry Crosby
 Filesize:  201.6 KB
 Viewed:  6533 Time(s)
PostPosted: Tue Dec 29, 2009 8:53 pm    Post subject: Flap motor brushes Reply with quote
Thanks Charlie! ....
Allen, I've had really good luck replacing motor brushes by making a tube of thin plastic ..... 6 mil stuff from the hardware store .... and wrapping it around the commutator and then sliding the brush assembly down over the plastic tube. Keeps the brushes from hitting the end of the commutator and breaking.
Take it slow and rock the brush assembly a little while using a thin pick to push the brushes into their pockets while sliding the assembly over the commutator.
Linn
Charles Kuss wrote:
> Here is the info I mentioned earlier. Charlie
