dean.psiropoulos(at)veriz Guest
Posted: Sun Apr 16, 2006 8:34 pm Post subject: Slick Mags |
Anyone know how to tell if a Slick mag has impulse coupling or not? I
don't have the prop on yet so I can't turn the engine over and listen for
the tell-tale snap. I'd rather not remove the mag or turn the engine over
with the starter until the airplane is completely finished. Can I get
impulse coupling information from the Mag serial/model numbers or otherwise
figure this out by looking at the mag when installed on the engine? Thanks.
Dean Psiropoulos
RV-6A N197DM
Sooooo close to the finish
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
klwerner(at)comcast.net Guest
Posted: Sun Apr 16, 2006 8:47 pm Post subject: Slick Mags |
Dear Dean,
If you have two mags (one with-/one without I.C.), then one should stick out further from the accessory case than the other (normally the left mag) due to the additional width of an adapterplate/spacer which is necessary for the extra space needed for the Impulse Coupling. If both are the same distance, then you either have NO Impulse Coupling, or you have two (but I daubt it!).
rtitsworth
Posted: Sun Apr 16, 2006 10:28 pm Post subject: Slick Mags |
On my Cessna, the spacer is about 1/2-3/4" thick and visable between the mag
and the engine case. (look close and compare the two).
The following link has an exploded view of the mag and IC (but does not show
the spacer) https://robertscarbrepair.com/piccategory.asp?id=300
flyv35b(at)ashcreekwirele Guest
Posted: Mon Apr 17, 2006 6:00 am Post subject: Slick Mags |
In addition to an extra spacer between the mag and accessory housing the
model # with tell you. You probably have a 4371 impulse mag and a 4370
non-impulse mag on the RH side.
Cliff A&P/IA
Wes Bunker
Posted: Tue Apr 18, 2006 11:49 am Post subject: Re: Slick Mags |
Unison lists mags with Lag/retard values in their publication at:
http://www.unisonindustries.com/docs/ConsolidatedAppData_L1318.pdf. This may help you identify IC units by the model number. If you can get the sheet that comes with a new mag, (L-1058-K) it does the same.
_________________ Wes
N7337G
C172K |
