jonlaury
Posted: Wed Dec 23, 2009 10:55 am Post subject: Was Ammeter Help- Now about switches |
Bob,
Now you've got me thinking Z-14. If I go with another alternator, I'm one contactor away from Z-14.
One thing that is vexing to me is that I'm using Honeywell AML 34 switches because the aesthetics appeal to me. Problem is that they are only available as DPST. I haven't thought about this too much, but I'm assuming that I can accomplish the switching functions shown in Z-14 and other architectures with the Honeywell switches, but I'll just have to use more of them and some behind-the-panel circuitry??? I can see the S-700-2-5 being replaced with an AML 34 and a pusbutton switch. But what combination would I use to achieve the function of S-700-2-10? In other architectures I see this switch associated with some automatic function that I don't understand.
Posted: Thu Dec 24, 2009 7:16 am Post subject: Re: Was Ammeter Help- Now about switches |
Honeywell AML switches are available in DPDT, either 2 position , or 3 position with center off. The AML24EBA3AC04 can replace the S700-2-7 as used in Z-14
These switches will not replace the S700-2-10. You could use two SPST switches instead, one for Master and one for Alternator. If it is desirable to have the Master switch enable the Alternator switch, then a relay will have to be used behind the panel. But then you add another failure point and cost and weight. Although these switches may be more pleasing to the eye, they might not have the optimum functionality, contact rating and price compared to other switches.
Joe
| Code: | | http://www.mouser.com/Electromechanical/Switches/Rocker-Switches-Paddle-Switches/_/N-5g2qZscv7?P=1z0sh5hZ1yzvtnwZ1z0x3c8Z1z0z2xk&Keyword=honeywell&FS=True |
_________________ Joe Gores |
MauleDriver(at)nc.rr.com Guest
Posted: Fri Dec 25, 2009 10:24 pm Post subject: Was Ammeter Help- Now about switches |
I like the AML 34 switches and AML 41 indicators too. Here's my Z-14
design and specs.
John Burnaby wrote:
| Quote: | Bob,
263.03 KB |
12100 Time(s) |
Tigressa_switches_and_indicators_Dec_09.xls |
347 KB |
605 Time(s) |
Posted: Sat Dec 26, 2009 5:49 am Post subject: Was Ammeter Help- Now about switches |
I was looking at the Z-14 diagram and see that I used a standard key
switch for the starter and mag switching in place of the S-700-2-5 (in
5/9/06 revision it is an S-700-2-7).
A pic of my panel can be found here:
http://www.vansairforce.com/community/showthread.php?t=18921&page=13
Have fun with the electrical design. Everything you need is here in
Bob's world. Quite a resource.
Bill "making fiberglass dust" Watson
RV10 Durham NC
Bill Mauledriver Watson wrote:
| Quote: | I like the AML 34 switches and AML 41 indicators too. Here's my Z-14
design and specs.
John Burnaby wrote:
> Bob,
Posted: Sat Dec 26, 2009 8:30 am Post subject: Re: Was Ammeter Help- Now about switches |
Some aircraft use a DPST switch to control the master contactor and the alternator field instead of DPDT. Wired like this, both the master contactor and the alternator must be turned on or turned off together. The alternator can not be off while the master contactor is on. Is there any disadvantage of wiring it this way? Many TC aircraft have split master switches so that the pilot can shut off the alternator without shutting off the master contactor. Many pilots do not understand why the master switch is split and would not know under what circumstances they should shut off the right hand side of the switch. Has anyone ever had reason to disable the alternator in flight?
If the aircraft is wired according to one of Bob N's drawings that incorporate an essential bus circuit and automatic over-voltage protection, then there is no need to have separate control over the alternator. In case of high voltage, the alternator is automatically disabled. In case of low voltage, the pilot can turn on the essential-bus switch and shut off the master switch. In fact, why even have an alternator field switch? The alternator field could be connected directly to the main power bus (through a circuit breaker). I suspect that more incidents have occurred when the pilot inadvertently left the alternator shut off, then when a problem arose requiring the alternator to be disabled. Is it better to give the pilot separate control over the alternator or is it better to keep it simple to reduce operator error?
Joe
Posted: Sat Dec 26, 2009 1:32 pm Post subject: Was Ammeter Help- Now about switches |
At 10:30 AM 12/26/2009, you wrote:
No, in fact early Z-figures proposed just that . . . before
fuse-blocks came along. In those days, existence of a pullable
circuit breaker made it possible to shut off the field circuit
for extended battery only ground operations.
| Quote: | Many TC aircraft have split master switches so that the pilot can
Not necessarily in flight. More often one wants to
operate battery-on while leaving the alternator field
off as cited above. Using a simpler DPDT DC PWR MASTER
combined with the pullable circuit breaker works too.
| Quote: | If the aircraft is wired according to one of Bob N's drawings
The design goals for pilot control for all
sources of electrical energy have been with
us for a very long time. Whether or not you
choose to embrace and implement them is
a personal choice enjoyed by the OBAM aircraft
community.
jonlaury
Posted: Sat Dec 26, 2009 10:36 pm Post subject: Re: Was Ammeter Help- Now about switches |
Bill Bob and Joe,
Thanks for your comments and schematics. Bill's Z-14 is exactly how I plan to put Z-14 to use.
Where Bob uses a 700-2-7, theres a pin connected to the volt meter and I don't get what this circuit is about. From somebody's post, I picked up that this circuit had an auto switch function in the event of OV.
Can either of you clarify this?
John
mrspudandcompany(at)veriz Guest
Posted: Sun Dec 27, 2009 5:53 am Post subject: Was Ammeter Help- Now about switches |
John
I am not sure about your reference to a connection to a
voltmeter, but Bob's Z-14 drawing has the S700-2-7 switch labeled as
STARTER/CROSS-FEED. There is a light to the left of the switch which will
illuminate whenever the cross-feed contactor is activated. This light will
illuminate when the switch is pushed up, to activate the starter,
simultaneously activating the cross-feed contactor, so you use both
batteries for starting. When the switch is pushed down, it will activate
the cross-feed only, tying the two batteries together, but not activating
the starter.
Hope this is the info you were looking for.
Roger
winmail.dat |
3.59 KB |
742 Time(s) |
jonlaury
Posted: Sun Dec 27, 2009 11:35 am Post subject: Re: Was Ammeter Help- Now about switches |
All,
I got Z-14 and 19 confused.
The circuit that I don't understand is in Z-19. It's the ENG BAT, OFF/ON/Auto circuit using a 700-2-10 switch. When switched to the 3rd position, contacting pin 4, what happens? Pin 4 goes to the 'Relay' pin of the LoVo monitor.
John
Posted: Sun Dec 27, 2009 2:11 pm Post subject: Was Ammeter Help- Now about switches |
At 01:35 PM 12/27/2009, you wrote:
All,
Okay. THAT drawing shows the AEC9005 Aux Battery
Management/LV Warning module . . .
http://www.aeroelectric.com/Catalog/AEC/9005/LV_Warn_Fab_and_Install.pdf
The 3-position Aux Battery switch in question offers an
OFF function at full down, a manual ON function at
the mid position and an AUTOMATIC management function
at the full up position. This functionality is described
in the document cited above.
The 9005 is being replaced by versions of the 9024 reviewed
at . . .
http://www.aeroelectric.com/Catalog/AEC/9024/
with applications illustrated at . . .
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z09A.pdf
jonlaury
Posted: Sun Dec 27, 2009 6:31 pm Post subject: Re: Was Ammeter Help- Now about switches |
Thank you Bob. I got it now.
Sorry for the confusion.
John
