speedy11(at)aol.com Guest
Posted: Tue Dec 22, 2009 6:57 pm Post subject: Contactor Failure |
Bob,
Sorry to be so long in responding.
Very interesting analysis.
I will follow your advice.
Stan Sutterfield
| Quote: | At 08:46 AM 12/2/2009, you wrote:
The continuous duty contactor I have installed is temporary. I will
replace it with an intermittent duty one.
I installed the Skytec starter as it arrived from the manufacturer -
that is, with the jumper from the contactor's control line to the
main terminal installed. I left the jumper installed because Skytec
recommend it - see
http://www.skytecair.com/images/Certified%20LS%20Wiring_1100.jpg. My
error, of course, was that I left out what they call the master solenoid.
I'm just guessing . . . but this configuration was probably
crafted to MINIMIZE changes to an existing system in a TC
aircraft. Adding the jumper to the starter contactor (a
technique adopted by B&C many years earlier) offers three
advantages. (1) you get a drop-in replacement of a previously
installed starter and (2) buffers existing ship's wiring from
experiencing the extra-ordinary inrush offered by the two-stage
solenoids as described in my article and (3) the PM motor inrush
current doesn't hit the system until BOTH the standard starter
and built-in contactors close. Since the standard contactor
closes first, there's a potential for improving life of this
contactor IF it's contacts are closed and stable when the
second set of contacts on the starter get closed a few milliseconds
later. The DOWNSIDE is the potential for suffering delayed
pinion dis-engagement.
This is Van's recommended wiring
http://www.skytecair.com/images/Van's%20Starter%20Wiring%20Lg.jpg,
but Skytec recommends against wiring this way.
This is pretty slick. The diagram suggests using the auxiliary
"I" (ignition boost) terminal available on most starter
contactors to close the starter-mounted contactor . . . again
with the idea of shifting motor inrush currents to the
starter's internal contactor. It has the advantage of breaking
the internal contactor's coil current when the external starter
contactor opens. This accomplishes the same goals as Z-22
but with an external STARTER CONTACTOR as opposed to an external
BUFFER RELAY.
Bob, are you implying that I should have removed the jumper wire from
the starter?
Not implying, recommending . . . based on what we learned
about (1) delayed disengagement and (2) higher stresses
on starter control contactor with substitution of PM
motor technology. If you already have an external contactor
installed (a la Van's suggestion) then making a simple change
to remove the jumper and wire the internal contactor control
terminal to the external contactor "I" terminal would be
a good move.
Van's drawing or Z-22 is the elegant solution for new design
in an OBAM aircraft. Skytec's drawing is the less than elegant
solution for minimizing changes to a TC aircraft when replacing
original starter called out on the ship's certification documents.
The way you had it wired ORIGINALLY wasn't all that hard on
the external contactor . . . assuming that it's contacts were
closed and stable before the internal contactor gets closed.
I've not had an opportunity to measure it but I suspect this
is the case. THEREFORE, I'm comfortable with suggesting that
your original sticking failure was probably an isolated case
and not indicative of a system design error. ADDING the battery
master contactor in series with cranking currents is the
firewall against a future repeat causing you to burn a battery
or starter.
Adding the wire to conform to Van's suggested configuration
would be a good move to take care of the potential for delayed
disengagement.
Bob . . . |
