roxianmike(at)msn.com Guest
Posted: Sun Dec 20, 2009 5:12 pm Post subject: Door Hinges |
I finished making the doors today and assembled the hinges. I notice that the hinges(the half for the cabin; and the half for the door) are not on the same planes C nor even parallel planes...................looking at the plans there no mention of this and which may be appropriate for the fore and aft........Anyone have advise on which to put in each location?
Moreover C while the welds look fine C the hinges aren't very attractive and the hinge intersections will be visible. Is there anyone producing any aftermarket replacement......hopefully machined?
Mike Lefever
RV-10 "finish" kit
Bob Turner
Posted: Sun Dec 20, 2009 5:24 pm Post subject: Re: Door Hinges |
Look very carefully at the plans, and which way the square block-like piece which holds the hinge pin is offset from the hinge plate. These drawings are correct, and apply to both doors in a left-right sense (when facing them), not in a fore-aft sense (which is reversed from one door to the other).
The cabin top is curved; you want the hinge line to be straight.
_________________ Bob Turner
RV-10 QB |
robin1(at)mrmoisture.com Guest
Posted: Sun Dec 20, 2009 5:48 pm Post subject: Door Hinges |
I looked long and hard at milling a set for my build and then considered producing them as OEM replacements. The “complex” angles made me think a second time about milling them not that it would be that difficult. (I think they penciled out to $100/pair) Eventually I came to the conclusion that there was no need as the hinge are going to stay in place even as the door is ripped off in flight. Maybe I should spend my time figuring out a way to reinforce the horizontal stab instead?
Ultimately we designed a cover plate I was going to leave polished till the painter shot it against my specific instructions.(It has to be the fumes!)
After all that angst I have yet to see another -10 that made me say to myself “gee I am really glad I made that mod.” I don’t even think I notice mine as the doors may block the view of the hinges when open. Or maybe I don’t see mine because they are painted. Regardless I think our solution is simple if you really want to go to the effort.
Robin
(painted photo attached)
http://www.painttheweb.com/rv-10/doors.htm
To install the hinge covers the scribes and routed out a channel for the hinge covers.
Below are two photos of the canopy top. One side has the hinge covers and the other side is the standard configuration. I will either paint the metal covers with the plane or I will powder coat the covers to match the smoke chrome of my steps and other items on the plane.
78.56 KB |
12659 Time(s) |
59.8 KB |
12659 Time(s) |
43.75 KB |
12659 Time(s) |
43.99 KB |
12659 Time(s) |
446.45 KB |
12659 Time(s) |
rv10builder(at)verizon.ne Guest
Posted: Sun Dec 20, 2009 6:57 pm Post subject: Door Hinges |
I recall that that I needed to flip the hinges, basically the high end goes on the back end of the front hinge and the forward end of the back hinge.
Don MacDonald makes the plates. They are very nice.
P
From: Roxanne and Mike Lefever (roxianmike(at)msn.com)
Sent: Sunday, December 20, 2009 5:10 PM
Subject: Door Hinges
I finished making the doors today and assembled the hinges. I notice that the hinges(the half for the cabin; and the half for the door) are not on the same planes, nor even parallel planes...................looking at the plans there no mention of this and which may be appropriate for the fore and aft........Anyone have advise on which to put in each location?
Moreover, while the welds look fine, the hinges aren't very attractive and the hinge intersections will be visible. Is there anyone producing any aftermarket replacement......hopefully machined?
Mike Lefever
RV-10 "finish" kit
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.howtocrimp.com">www.howtocrimp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Posted: Sun Dec 20, 2009 8:52 pm Post subject: Door Hinges |
Thanks!
Subject: Re: Door Hinges
Date: Sun C 20 Dec 2009 18:55:53 -0800
I recall that that I needed to flip the hinges C basically the high end goes on the back end of the front hinge and the forward end of the back hinge
Posted: Sun Dec 20, 2009 8:54 pm Post subject: Door Hinges |
Thanks!
Subject: RE: Door Hinges
Date: Sun C 20 Dec 2009 20:46:45 -0500
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal C .ExternalClass li.ecxMsoNormal C .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass p.ecxMsoAcetate C .ExternalClass li.ecxMsoAcetate C .ExternalClass div.ecxMsoAcetate {margin-bottom:.0001pt;font-size:8.0pt;font-family:'Tahoma' C'sans-serif';} .ExternalClass span.ecxHTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.ecxEmailStyle20 {font-family:'Arial' C'sans-serif';color:#1F497D;font-weight:normal;font-style:normal;} .ExternalClass span.ecxapple-converted-space {;} .ExternalClass span.ecxtxtindent {;} .ExternalClass span.ecxBalloonTextChar {font-family:'Tahoma' C'sans-serif';} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
Robin
78.56 KB |
12648 Time(s) |
59.8 KB |
12648 Time(s) |
43.75 KB |
12648 Time(s) |
43.99 KB |
12648 Time(s) |
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Sun Dec 20, 2009 10:49 pm Post subject: Door Hinges |
I made up about 40 sets of these.... because it was just as easy to make 40 as it was 4. I had them painted prior to installation... that way the hinges underneath were also totally painted. Don't have any pics of what they look like afterward.... maybe I'll shoot those tomorrow. If anybody wants a set of 4, let me know...send me an address... cost... $20 including shipping.... again not trying to make money here, just get some parts out there to my fellow 10 guys.
Damn this planbe is fun to fly.
Don McDonald
Broke the 100 hour mark this weekend.
--- On Sun, 12/20/09, Roxanne and Mike Lefever <roxianmike(at)msn.com> wrote:
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Date: Sunday, December 20, 2009, 8:51 PM
Thanks!
Date: Sun, 20 Dec 2009 18:55:53 -0800
#yiv2008558399 .ExternalClass .ecxhmmessage P {padding:0px;} #yiv2008558399 .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} I recall that that I needed to flip the hinges, basically the high end goes on the back end of the front hinge and the forward end of the back hinge.
P
Mike Lefever
RV-10 "finish" kit
lectric.com
/">www.buildersbooks.com
ebuilthelp.com
p.com
ronics.com
_blank rel=nofollow>www.aeroelectric.com
/" target=_blank rel=nofollow>www.buildersbooks.com
=_blank rel=nofollow>www.homebuilthelp.com
nk rel=nofollow>www.howtocrimp.com
blank rel=nofollow>http://www.matronics.com/contribution
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
877.83 KB |
12641 Time(s) |
527.07 KB |
12641 Time(s) |
_________________ Don A. McDonald
40636 |
partner14
Posted: Mon Dec 21, 2009 9:33 pm Post subject: Door Hinges |
Here's the brackets after paint.
--- On Sun, 12/20/09, Don McDonald <building_partner(at)yahoo.com> wrote:
Date: Sunday, December 20, 2009, 10:37 PM
I made up about 40 sets of these.... because it was just as easy to make 40 as it was 4. I had them painted prior to installation... that way the hinges underneath were also totally painted. Don't have any pics of what they look like afterward.... maybe I'll shoot those tomorrow. If anybody wants a set of 4, let me know....send me an address... cost.. $20 including shipping.... again not trying to make money here, just get some parts out there to my fellow 10 guys.
Don McDonald
Thanks!
#yiv1278893964 #yiv2008558399 .ExternalClass .ecxhmmessage P {padding:0px;} #yiv1278893964 #yiv2008558399 .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} I recall that that I needed to flip the hinges, basically the high end goes on the back end of the front hinge and the forward end of the back hinge.
P
Mike Lefever
RV-10 "finish" kit
lectric.com
ebuilthelp.com
p.com
ronics.com
40636 |
Kelly McMullen
Posted: Tue Dec 22, 2009 6:05 am Post subject: Door Hinges |
Hmm, not sure you sent the pics you intended..they are the same images
as your first message.
On Mon, Dec 21, 2009 at 10:26 PM, Don McDonald
I made up about 40 sets of these.... because it was just as easy to make 40 as it was 4. I had them painted prior to installation... that way the hinges underneath were also totally painted. Don't have any pics of what they look like afterward.... maybe I'll shoot those tomorrow. If anybody wants a set of 4, let me know....send me an address... cost... $20 including shipping.... again not trying to make money here, just get some parts out there to my fellow 10 guys.
Don McDonald
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Tue Dec 22, 2009 6:53 am Post subject: Door Hinges |
These pics got me to thinking ..... actually a bad idea
So what's the downside to glassing over the hinge on the top? Why would you need to remove the hinge from the top when you can remove the door? A thin cover glassed over the top side could be removed easily if/when it became necessary. Anyone done that???
As a side question: Any of the flying guys seen rust from the hinges??? What do you do to prevent it??
Comments anyone???
Linn
--- On Sun, 12/20/09, Don McDonald <building_partner(at)yahoo.com> (building_partner(at)yahoo.com) wrote:
From: Don McDonald <building_partner(at)yahoo.com> (building_partner(at)yahoo.com)
pilotdds(at)aol.com Guest
Posted: Tue Dec 22, 2009 8:52 am Post subject: Door Hinges |
Don I would love a set-thanks jim
partner14
Posted: Tue Dec 22, 2009 9:45 am Post subject: Door Hinges |
--- On Tue, 12/22/09, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Subject: Re: Fw: RE: Door Hinges
Date: Tuesday, December 22, 2009, 6:33 AM
These pics got me to thinking ..... actually a bad idea WHY????
As a side question: Any of the flying guys seen rust from the hinges??? What do you do to prevent it?? Paint Them
Comments anyone???
Linn
40636 |
partner14
Posted: Tue Dec 29, 2009 3:45 pm Post subject: Door Hinges |
Jim Rore..... I need an address...
For the rest of you guys that wanted a set..... they're on the way.... Patrick, from Australia,,, it's gonna take a while to get there!
Date: Tuesday, December 22, 2009, 8:49 AM
40636 |
Posted: Tue Dec 29, 2009 4:54 pm Post subject: Door Hinges |
sometimes the good things in life take time.. those hinges are nice for sure and worth the wait.
Don; you should start a webpage with all the great upgrades you have made for the RV-10, the axle extensions, the front axle nut tool, the hinges and headset brackets.. all very nice work that you should offer to the new builders who missed the group deals before.
Sent: Tuesday, December 29, 2009 3:29 PM
--- On Tue, 12/22/09, pilotdds(at)aol.com (pilotdds(at)aol.com) <pilotdds(at)aol.com (pilotdds(at)aol.com)> wrote:
From: pilotdds(at)aol.com (pilotdds(at)aol.com) <pilotdds(at)aol.com (pilotdds(at)aol.com)>
-----Original Message-----
Sent: Sun, Dec 20, 2009 10:37 pm
Don McDonald
--- On Sun, 12/20/09, Roxanne and Mike Lefever <roxianmike(at)msn.com (roxianmike(at)msn.com)> wrote:
From: Roxanne and Mike Lefever <roxianmike(at)msn.com (roxianmike(at)msn.com)>
#yiv1962610365 #AOLMsgPart_3_eafa0d00-6015-4db2-8540-45a7f7b8bc1d td{color:black;}#yiv1962610365 #AOLMsgPart_3_eafa0d00-6015-4db2-8540-45a7f7b8bc1d #yiv2008558399 .hmmessage P{margin:0px;padding:0px;}#yiv1962610365 #AOLMsgPart_3_eafa0d00-6015-4db2-8540-45a7f7b8bc1d #yiv2008558399 {font-size:10pt;font-family:Verdana;} Thanks!
From: rv10builder(at)verizon.net (rv10builder(at)verizon.net)
#yiv1962610365 #AOLMsgPart_3_eafa0d00-6015-4db2-8540-45a7f7b8bc1d td{color:black;}#yiv1962610365 #AOLMsgPart_3_eafa0d00-6015-4db2-8540-45a7f7b8bc1d #yiv2008558399 .ExternalClass .ecxhmmessage P{padding:0px;}#yiv1962610365 #AOLMsgPart_3_eafa0d00-6015-4db2-8540-45a7f7b8bc1d #yiv2008558399 .ExternalClass body.ecxhmmessage{font-size:10pt;font-family:Verdana;} I recall that that I needed to flip the hinges, basically the high end goes on the back end of the front hinge and the forward end of the back hinge.
P
Mike Lefever
RV-10 "finish" kit
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
w target=_blank>www.howtocrimp.com
=nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
