flyboyedwards(at)yahoo.co Guest
Posted: Tue Dec 15, 2009 6:32 pm Post subject: Jacking up an RV Tail Dragger? |
Hello All,
I recently purchased a RV-4. I have been pondering about jacking the aircraft up, to grease the bearings. I just looked through the Aircraft Spruce catalog, and saw that they offer 2 different tools for doing this very thing. (P/N 12-01751 $120 OR P/N 12-00634 $46)
I'm wondering if anyone has either of these, and has any recommendations.
I have the angle iron, with the clamp, but I'm not very excited about clamping that to the gear leg.
I am an A&P, and I have access to "real wing jacks", but I am looking at "having my own" source. And I have heard that jacking these awesome little planes, at the tie down loop, causes them to be unstable. I know the remedy for that too............but I'm looking for efficiency.
Interested in the groups opinion.
Thanks in advance!!
Jason Edwards
RV-4 N8EW "Dream Chaser"
Richland Center, Wisconsin.
kboatright1(at)comcast.ne Guest
Posted: Tue Dec 15, 2009 7:12 pm Post subject: Jacking up an RV Tail Dragger? |
This is the one I've used for ~10 years. It works well for me:
http://www.averytools.com/p-181-rv-jack-stand.aspx
Essentially, you drill out a hole in the axle nut and a rod passes through it once you've removed the wheel pant (there is a an adapter that provides this access and still provides a hard point to mount the wheel pant). The rod has the funny looking jack stand assembly attached, and all you do is put a jack under the hard point. Once you've got things jacked, you unscrew the axle bolt and pull the wheel/brake outboard and off the axle. Then, you put wood blocks or something under the axle, remove the jack fixture and the wheel comes right off. It makes a lot of sense once you see it.
KB
rv6n(at)optonline.net Guest
Posted: Tue Dec 15, 2009 7:14 pm Post subject: Jacking up an RV Tail Dragger? |
I jack up my RV6 at the wing tie-down loop and have never had any unstable problems C maybe that is a problem for the A models E
6nbsp;
Bob
mr.sun
Posted: Tue Dec 15, 2009 10:27 pm Post subject: Jacking up an RV Tail Dragger? |
On my RV7 I made a jack by welding a 10" piece of 3/4" Steel solid rod to an old scissor jack from some import car. I block the tailwheel and the opposite main, then I carefully remove the axle nut after marking it with a magic marker so I can tighten it up exactly the same. Once the nut is removed, I quickly slide the steel rod into the axle tube hole so I leave enough room to get the tire/wheel off. I set it down on a wood block and pull the jack and wheel off. Obviously you need to pull the wheel pants and the brake shoe off first. This has worked for me over a dozen times although I take care not to move the airplane while the nut is off and weight is still on the wheels.
This is not an original idea. I got it on the list somewhere...
On Tue, Dec 15, 2009 at 7:13 PM, <rv6n(at)optonline.net (rv6n(at)optonline.net)> wrote:
[quote]I jack up my RV6 at the wing tie-down loop and have never had any unstable problems, maybe that is a problem for the A models.
Bob
_________________ Greg RV-7 |
johnd(at)wlcwyo.com Guest
Posted: Wed Dec 16, 2009 10:00 am Post subject: Jacking up an RV Tail Dragger? |
I just purchased a 18” long piece of ¾” or 5/8” (can’t remember) steel rod.
I drilled out the axle nut, placed the steel rod in the hole of the landing gear at the axle nut.
I then just used a floor jack and placed the pad of the floor jack under the steel rod (there is room) and jacked up the plane enough to remove the tire and wheel.
[b]John L. Danielson[/b]
Hello All,
Thanks in advance!!
Jason Edwards
| Quote: | | www.aeroelectric.comwww.buildersbooks.com | 012345678901234567
garrys(at)tampabay.rr.com Guest
Posted: Wed Dec 16, 2009 11:06 am Post subject: Jacking up an RV Tail Dragger? |
I must be missing something here. How do you get the wheel/tire assembly off the steel rod?
Garry Stout
| Quote: | Sent: Wednesday, December 16, 2009 11:30 AM
Subject: RE: Jacking up an RV Tail Dragger?
Hello All,
Thanks in advance!!
Jason Edwards
6 | [quote][b]
Jdaniel343(at)bresnan.net Guest
Posted: Wed Dec 16, 2009 1:15 pm Post subject: Jacking up an RV Tail Dragger? |
After the wheel tire is off the ground, remove the axle nut, slide wheel tire off axle, place block of wood under axle and lower jack, remove steel rod and wheel and tire.
Larry Bowen
Posted: Wed Dec 16, 2009 2:59 pm Post subject: Jacking up an RV Tail Dragger? |
Isn't there a bolt/nut plate in the center of the axle nut - the one
that the wheel fairing attaches to? What becomes of it?
On 12/16/09, John Danielson <johnd(at)wlcwyo.com> wrote:
| Quote: | I just purchased a 18" long piece of ¾" or 5/8" (can't remember) steel rod.
and wheel.
John L. Danielson
Hello All,
Thanks in advance!!
Jason Edwards
rsbooks.com>
m>
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Wed Dec 16, 2009 4:03 pm Post subject: Jacking up an RV Tail Dragger? |
That also needs to be removed just as in most of the expensive jacks offered.
John L. Danielson
timb
Joined: 16 Apr 2008 Posts: 77 Location: Frankston, Texas
There is a small U shaped bracket that goes back over that with a platenut
on it. The wheel pant bolts back the same as it was.
Tim
_________________ Tim Bryan
RV-6 Flying
N616TB |
Jess Guest
RV Wheel Lift
In a message dated 12/16/2009 3:01:08 P.M. Pacific Standard Time, larry(at)bowenaero.com writes:
| Quote: | --> RV-List message posted by: Larry Bowen <larry(at)bowenaero.com>
and wheel.
John L. Danielson
Hello All,
Thanks in advance!!
Jason Edwards
rsbooks.com>
m>
Larry ================================================nbsp; (And Get Some AWESOME FREE to find Gifts tric re b k you for p; -Matt Dralle, List ======================== ties Day ================================================ - MATRONICS WEB FORUMS ==================================================
2.27 MB |
15392 Time(s) |
altoq(at)cebridge.net Guest
Posted: Wed Dec 16, 2009 5:50 pm Post subject: Jacking up an RV Tail Dragger? |
Don't know where I got these pictures. Probably for sale somewhere, but looks easy enough to make.
John D.
Sent: Tuesday, December 15, 2009 8:29 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: Jacking up an RV Tail Dragger?
66.52 KB |
15385 Time(s) |
122.02 KB |
15385 Time(s) |
26.72 KB |
15385 Time(s) |
Gary.A.Sobek
Posted: Wed Dec 16, 2009 6:06 pm Post subject: Jacking up an RV Tail Dragger? |
For the past 12+ years C I have placed a stainless steel hose clamp on the landing gear leg and use a cheap car floor jack to jack the airplane up for tire changes. I place several 4 X 4 boards under the axle to support the airplane while I work.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell C [img]file:///T:/My%20Pictures/2008_Photos/DSCN0169.JPG[/img]
2 C338+ Flying Hours So. CA C USA
| Quote: | > Hello All C
> aircraft up C to grease the bearings. I just looked through the Aircraft
> Spruce catalog C and saw that they offer 2 different tools for doing this
> I'm wondering if anyone has either of these C and has any recommendations.
> I have the angle iron C with the clamp C but I'm not very excited about
> I am an A&P C and I have access to "real wing jacks" C but I am looking at
> planes C at the tie down loop C causes them to be unstable. I know the remedy
> Thanks in advance!!
> Jason Edwards
> Richland Center C Wisconsin.
Hotmail: Powerful Free ema2986/direct/01/' target='_new'>Get it now.
230.89 KB |
15383 Time(s) |
232.66 KB |
15383 Time(s) |
231 KB |
15383 Time(s) |
232.46 KB |
15383 Time(s) |
Posted: Wed Dec 16, 2009 8:25 pm Post subject: Jacking up an RV Tail Dragger? |
Thanks for all of the great ideas!!
I am so glad I bought my RV, not only is it a great airplane............it comes with a great family!
Merry Christmas to all!!!
Jason Edwards
Rv-4 N28EW "Dream Chaser"
Richland Center, WI
