New style Nose Gear for the 701-801??
dons701
PostPosted: Sun Dec 13, 2009 10:19 am    Post subject: New style Nose Gear for the 701-801?? Reply with quote
It's a freezing rain Sunday hear in Pa and I found this surfing on the net. www.customflightsystems.com
I just sent an email to them today asking if they made any for the 701. I also asked if he tested any type of hydraulic dampening with his system. While the trailing link suspension is interesting are there any thoughts out there on this idea ? Pros, Cons ? I know that if care is taken the stock gear is fine but would this or something else be better ? Thank you for your thoughts. Don
Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop
NYTerminat(at)aol.com
PostPosted: Sun Dec 13, 2009 10:56 am    Post subject: New style Nose Gear for the 701-801?? Reply with quote
After looking at the video, it would appear that with a hard landing you would smash your prop right in the ground.
Bob Spudis CH701/912S
In a message dated 12/13/2009 1:20:31 P.M. Eastern Standard Time, burdon1(at)comcast.net writes:
lgold(at)quantum-associat
PostPosted: Sun Dec 13, 2009 11:13 am    Post subject: New style Nose Gear for the 701-801?? Reply with quote
Don,
Pls let us know what you find out about this gear for a 701 (like its weight, cost, and maximum vertical movement).
The action of the gear looks great, but watching the video you can see that the nose drops when you hit a bump. Having already "trimmed" the ends so of my Warpdrive prop unintentionally ($350 repair) I am a bit concerned about this. If I hold onto the breaks and power up, my 701 nose drops about 4". This gear looks like it may drop the nose even further.
If I were to get this gear, I would raise the nose-to-ground clearance. Since I already chucked my Carlisle 18" tires and installed 21"-diameter mains (see http://www.zenith.aero/profiles/blogs/testing-larger-bushwheel-tires), I could add about 3" and the plane would still look Ok on the ground.
Les
But Bob,
We never ever make hard landings in 701s. Right?
Les
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of NYTerminat(at)aol.com
Sent: Sunday, December 13, 2009 10:49 AM
Subject: Re: New style Nose Gear for the 701-801??
www.aeroelectric.com
PostPosted: Sun Dec 13, 2009 11:55 am    Post subject: New style Nose Gear for the 701-801?? Reply with quote
I wouldn't say never! I have been known to botch a few, especially in the beginning Smile
In a message dated 12/13/2009 2:14:21 P.M. Eastern Standard Time, lgold(at)quantum-associates.com writes:
But Bob,
Les
ggower_99(at)yahoo.com
PostPosted: Sun Dec 13, 2009 4:35 pm    Post subject: New style Nose Gear for the 701-801?? Reply with quote
Need to have enough clearence with the springs all compressed, or messured the clearence without the springs, then install them... Good idea.
Saludos
Gary Gower.
--- On Sun, 12/13/09, NYTerminat(at)aol.com <NYTerminat(at)aol.com> wrote:
From: NYTerminat(at)aol.com <NYTerminat(at)aol.com>
Date: Sunday, December 13, 2009, 1:48 PM
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Zenith701801-List
lvuman(at)gmail.com
PostPosted: Sun Dec 13, 2009 7:00 pm    Post subject: New style Nose Gear for the 701-801?? Reply with quote
Seems like a nice alternative to a pusher system but in really rough areas, I would guess it would dip too much and catch a prop tip on a 701.
On Sun, Dec 13, 2009 at 11:19 AM, dons701 <burdon1(at)comcast.net (burdon1(at)comcast.net)> wrote:
[quote]--> Zenith701801-List message posted by: "dons701" <burdon1(at)comcast.net (burdon1(at)comcast.net)>
Zenith 701 #76120
Jabiru 2200A #2456  55 hours
http://forums.matronics.com/viewtopic.php?p=277418#277418
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
dougsnash
PostPosted: Sun Dec 13, 2009 8:04 pm    Post subject: New style Nose Gear for the 701-801?? Reply with quote
Keep in mind that the nose wheel steering setup on a lot of the ultralight class pushers kind of makes the 701 strut look like the steering assembly for a Sherman tank. They really need better nose wheels.
Just like a lot of the people that have responded so far, I spent the whole video thinking "that sure looks like a good way to shorten a propellor blade or two."
I liked the tunes that were played during the video though.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
Sent: Sun, December 13, 2009 8:58:13 PM
The new Internet Explorer® 8 - Faster, safer, easier. Optimized for Yahoo! Get it Now for Free! [quote][b]
dons701
PostPosted: Mon Dec 14, 2009 2:58 pm    Post subject: Re: New style Nose Gear for the 701-801?? Reply with quote
Thanks to all who replied. When I receive an email from this company I will post it here.
I do understand that if anyone would install any type of different nose gear, they should test the clearance at maximum compression. I do remember reading about someone who was experimenting with a new type of gear, just wanted to possibly hear from them or anyone to see how it was coming along. Don
Zenith 701 #76120
john.marzulli(at)gmail.co
PostPosted: Mon Dec 14, 2009 3:23 pm    Post subject: New style Nose Gear for the 701-801?? Reply with quote
So with their setup on the Challanger... did it not have a suspension on the main part of the nose fork? With a normal bungie suspension too it seems like this would be a very bouncy ride.
I would think that this pivoting link is really just doing what the main bungie on our 701 is doing, but with much less resistance.
John Marzulli
http://www.GenevieveMarzulli.org/
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Mon, Dec 14, 2009 at 2:58 PM, dons701 <burdon1(at)comcast.net (burdon1(at)comcast.net)> wrote:
Zenith 701 #76120
http://forums.matronics.com/viewtopic.php?p=277529#277529
ber is the Annual List Fund Raiser.  Click on
-=     * AeroElectric www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
he Matronics List Features Navigator to browse
s.com/Navigator?Zenith701801-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
dons701
PostPosted: Mon Dec 14, 2009 4:45 pm    Post subject: Re: New style Nose Gear for the 701-801?? Reply with quote
Hi John, I did not see any additional spring on the main tube, just what looks like four valve springs stacked to provide the two step spring rate. Resistance of movement can provide some crude dampening on the 701, until the nylon wears away at least. Don
Zenith 701 #76120
PostPosted: Tue Dec 15, 2009 6:14 pm    Post subject: New style Nose Gear for the 701-801?? Reply with quote
Doug,
The 701 gear may look supper strong, but don’t think it can’t be improved. I know of an instance, on a short field landing during a new pilot’s check ride, that the nose gear collapsed on his new 701. The tube just bent back about 90-degrees just below the lower bearing. We looked very carefully and couldn’t find anything wrong with the construction. Ever since then I try very hard to come down easy on the nose and don’t mind looking at alternative gear.
Les
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of MacDonald Doug
Sent: Sunday, December 13, 2009 8:01 PM
Doug MacDonald
NW Ontario, Canada
dons701
PostPosted: Tue Dec 22, 2009 10:19 am    Post subject: Re: New style Nose Gear for the 701-801?? Reply with quote
For what it's worth, here below is the response to my request of info about the availability of the nose gear for the 701 from Custom Flight Systems.
The reason for my curiosity of alternate designs of nose gear (or anything else) is that while tried and true, any design or initial concept can be improved upon in time, especially when it comes to safety improvements. When looking at the incidents involving nose gear on the 701 and others, the bending of the axle allowing tire contact and lock-up, the "fold back" of the gear tube at or near the lower bearing contact area seem to be consistent issues when sufficient hard contact or"arrivals" are made. I read about thicker axles being made, even of solid stainless if i'm not mistaken. In looking at the axle wheel assembly I can understand that due to the requirement of the tire width versus the width of the bearing hub that there is not much support to deliver the force of impact from this bearing hub suspended in the middle of the shaft, back through the wheel fork doubler, then tube and bungee. Solution? If not stonger axles, how about a support brackets added to the axle shaft spacers that would deliver some of the impact back through the fork doubler. Or both.
When it comes to the nose gear tube folding back, perhaps having a much wider bearing contact area, (flange bearing ?), may help as this would spread the side (back) force to eliminate the pressure point effect of the 1/4" thick nylon lower bearing. This might eliminate the consequence of the initial denting to the side wall of the tube which weakens it's design strength, allowing the tube wall to collapse.
These are just my thoughts, please pick them apart, any and all comments are welcome for the safety of our sport.
Thanks in advance and Merry Ho Ho ......... Don
Hi Don,
We had a inquiry from a 701 owner in the past but no one has installed our nose gear on a 701 to date. The steering shaft is (OD 1-3/8 X .095 thk and 22” long) We can make some modifications if needed. A 1-7/8 X .250 thk 4130 tube cut into bushings will adapted our nose gear to the 2” tube. (PN 03-10600 McMaster Carr). We are using 4 springs with different spring rates instead of heavy and expensive hydraulic damping systems. The rebound has not been reported as an issue to date.
Thank you
Wade Custom Flight Systems.
Zenith 701 #76120
mksoucy(at)yahoo.com
PostPosted: Thu Dec 24, 2009 2:57 am    Post subject: New style Nose Gear for the 701-801?? Reply with quote
What I do not like about the 701 nose gear is the solid rudder pedal connection. I intend to set my up with a spring type connection like the tailwheel on my piet. Hopefully this way the tire can align itself (xwind landing ,etc.) if it has to eliminating stress.
Mike
Sent from my iPod
brackets added to the ax!
Hi Don,
Thank you
Zenith 701 #76120
http://forums.matronics.com/viewtopic.php?p 78589#278589
