Front Baffle screw access
jchang10
PostPosted: Fri Dec 11, 2009 3:52 pm    Post subject: Front Baffle screw access Reply with quote
This is my 3rd attempt. sorry for any repeat posts.
How did you guys get access to the screws that hold the front baffle, right underneath the prop governor? I am still trying to figure out how to drill it, let alone get a screw driver to it.
Hopefully, the image was attached okay below!
Also, are there any recommendations for exactly how to align the CB-1001A baffle in relation to the cowl? The plans don't give much info here. The plans also don't seem to indicate any baffle material for this area. I am wondering if I shoot for a tight fit or leave a gap for the cowl to come on and off?
Thanks!
Jae
40533
 Filesize:  52.43 KB
 Viewed:  2532 Time(s)
dlm46007(at)cox.net
PostPosted: Fri Dec 11, 2009 5:43 pm    Post subject: Front Baffle screw access Reply with quote
A 90 angle drill and short threaded drill bits. Why hot put SS cap screws in
there with an Allen wrench.
jesse(at)saintaviation.co
PostPosted: Fri Dec 11, 2009 6:23 pm    Post subject: Front Baffle screw access Reply with quote
I second the angle drill. Also, I use a #3 bolt & a universal socket.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
screws in
jchang10
PostPosted: Sat Dec 12, 2009 11:03 am    Post subject: Front Baffle screw access Reply with quote
ok, thanks for the replies. looks like i'll replace that screw with
something easier to access.
jae
40533
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
