jdmcbean(at)kitfoxaircraf Guest
Posted: Fri Dec 11, 2009 2:54 pm Post subject: Skis required |
This may be a little pre-mature.. but we have a new set of wheel penetrating skis becoming available.. They are Composite and are currently setup of the Grove gear (will be for tube shortly) Total weight is approximately 14 lbs per ski and can be setup for 600-6, 800-6 or 8.50-6 tires. Give a call for more info.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
182.05 KB |
6351 Time(s) |
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Fri Dec 11, 2009 3:44 pm Post subject: Re: Skis required |
$$ How much? $$
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
dave
Posted: Sat Dec 12, 2009 1:51 am Post subject: Re: Skis required |
THose look like the one a guy makes here in Canada and if so about 1500$ or so.
http://www.turbulence.ca/an/skisan.html#History
Here is used ones for 450 a pair.
http://rotaxaircraft.com/forum/viewtopic.php?f=27&t=155
I have 4130 Skis available. You send the specs and size wanted for other than 3/4 " axle size on Standard tube gear.
8 to 12 " wide and 48 to 60" long.
Prices starting at 850$ for straight skis with UHMW bottoms.
Considering Wheels Skis for King fox and other 21 " tires as they seem the most popular tire going.
21 " tires available for 35 $ each
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
davedawe(at)msn.com Guest
msm_9949(at)yahoo.com Guest
Posted: Sun Dec 13, 2009 5:47 pm Post subject: Skis required |
Dave,
Could you send pics and specs? I assume you bought them for your model 2. Did you use them? How did they work out?
I'm interested.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
Hersey, Michigan
--- On Sat, 12/12/09, David Dawe <davedawe(at)msn.com> wrote:
Subject: RE: Re: Skis required
To: "kitfox-list(at)matronics.com" <kitfox-list(at)matronics.com>
Date: Saturday, December 12, 2009, 7:10 AM
Hi
I have a fiberglass set (3) new, asking $350
Dave
Kitfox ll
Get a great deal on Windows 7 and see how it works the way you want. See the Windows 7 offers now. | Quote: |
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
el=nofollow target=_blank>http://www.matronics.com/Navigator?Kitfox-List
dave
Posted: Tue Dec 15, 2009 3:22 am Post subject: Re: Skis required |
Marco, pics and videos are all posted .
Dave
21 " tires available for 35 $ each |
[quote="msm_9949(at)yahoo.com"]Dave,
I'm interested.
Marco Menezes N99KX
Hersey, Michigan
--- On Sat, 12/12/09, David Dawe <davedawe> wrote:
To: "kitfox-list(at)matronics.com" <kitfox>
Hi
Dave
Kitfox ll
dave
Posted: Mon Jan 18, 2010 5:04 am Post subject: Re: Skis required |
Pictures posted here and videos to follow
http://rotaxaircraft.com/forum/viewtopic.php?f=27&t=167
Kitfox Skis
4130 tube 12 x 48 "
2 main skis with UHMW bottoms $850.00
Tail ski with UHMW $150.00
These come unpainted. Powder coated add 150$ for a set of three.
You rig the cables, if you want the cables and bungees all ready for you to bolt on add $75 a ski
you will get 1/8" crust cutter cable, safety cables , mil spec bungees. Bolts and tabs to bolt on.
The skis in pics I can ship out same day for $1100.00 plus crate and shipping. IN Ontario that will be about 150 $ or so.
Or you can Pick up Near London Ontario.
Down payment today and your skis will be ready within a week.
Custom made skis for most planes.
