ChangDriver
Posted: Thu Dec 03, 2009 11:40 am Post subject: Hobbs Meter |
I am interested in changing how the Hobbs meter in my plane is wired (it is currently wired to the radio master - not the best place for it) and don't want to install an oil pressure switch. I know I read in the EAA magazine many months back of alternative ways of doing so, but can't find the article.
What other ways have been done? I think the writer of the EAA article used the field for the alternator.
Any suggestions?
Craig
longg(at)pjm.com Guest
Posted: Thu Dec 03, 2009 12:03 pm Post subject: Hobbs Meter |
Craig,
Go wireless. There are units available now that work on vibration. No
fussing about with wires. BTW - I have an old wired job if someone wants
a challenge. New in box. Free for asking but don't let me see it on
eBay. If you don't have a need for it right now, don't ask.
Glenn
BobsV35B(at)aol.com Guest
Posted: Thu Dec 03, 2009 12:25 pm Post subject: Hobbs Meter |
Good Afternoon Craig,
It all depends on what you want to record.
For a certificated flying machine, the FAA only requires that we log the actual flying time. Taxiing to the gas pumps, maintenance runups, and taxiing to the runway do not have to be recorded. If you want to use the time for pilot logging purposes, all time from the time when the engine is started for the purpose of flight to the engine shut down following a flight counts. Kinda tricky if you want to taxi to the gas pump without logging time!
The easiest way to get only flight time is with a ground reference strut switch.
Another suitable method is with an air pressure operated switch in the pitot line Some folks use a simple air operated vane on a strut, wing, belly, or elsewhere
We formerly operated a fleet of Helicopters. For maintenance purposes, we had a Hobbs hooked up to a switch on the collective, It only recorded time when the collective was off the stop. For charging the customer, we had a Hobbs on the Master switch. It recorded time from the moment the master switch went on until it was turned off.
As Always, It All Depends! <G>
Happy Skies,
Old Bob
AKA' Bob Siegfried
Downers Grove, Illinois
Stearman N3977A
In a message dated 12/3/2009 1:42:57 P.M. Central Standard Time, capav8r(at)gmail.com writes:
| Quote: | --> AeroElectric-List message posted by: "Craig Winkelmann" <capav8r(at)gmail.com>
Any suggestions?
Craig
http://forums.matronics.com/viewtopic.php?p=276010#276010===============================================
_nbsp; (And Get Some AWESOME FREE to find Gifts tric re b k you for p; -Matt Dralle, List ======================== = Use utilities Day ================================================ - MATRONICS WEB FORUMS ==================================================
ChangDriver
Posted: Thu Dec 03, 2009 7:28 pm Post subject: Re: Hobbs Meter |
In my experimental plane with a radial engine, the hobbs was wired to the radio master by the prior owner with the thought that the radios are on when flying. However, there is time the radios are on when the engine is not running (testing equipment, checking atis, etc).
Since the tach does not track "engine time" I am in need of a good way to track something close to it (Hobbs time) so I have a reminder when to change the oil.
My thought was the field on the alternator. The plane has an EI Superclock that can track time from when power is applied to one lead.
Craig
ulflyer(at)verizon.net Guest
Posted: Fri Dec 04, 2009 6:56 pm Post subject: Hobbs Meter |
Hi Craig,
It's time to rally the troops. I recalling in one of the recent
(last couple years) aviation magazines of a vibration switch for use
with a hobbs meter for the purpose you have addressed. If I recall
it was around $12-$18. Any one recall seeing that. The Tiny Tach is
another alternative - you have to get the correct model depending
upon what engine type you have (single or double high voltage pulse
per rev. The are dual function, Tach and engine hour meter - attach
by wrapping a lead around the high voltage lead of one of the plugs.
If your using it for tracking hours for oil change, you should use
the tach hours if you have a recording tach, since that reflects
actual engine operation hours. The hobbs were added by rental
aircraft operators to base time for flight instruction. Second
function was for recording PIC time for log books.
jerb
At 11:40 AM 12/3/2009, you wrote:
Any suggestions?
Craig
http://forums.matronics.com/viewtopic.php?p 76010#276010
Posted: Fri Dec 04, 2009 7:03 pm Post subject: Hobbs Meter |
Check this link out.
http://store.wagaero.com/product_info.php?products_id=12390
Any suggestions?
Craig
Posted: Sat Dec 05, 2009 6:24 am Post subject: Hobbs Meter |
At 08:58 PM 12/4/2009, you wrote:
That's pretty slick. It would be interesting to
put it side-by-side with another meter to see
how discriminating it is with respect to vibration
from an engine and other potential "noises". Does
anyone on the List have one of these installed?
lists(at)stevet.net Guest
Posted: Sat Dec 05, 2009 6:58 am Post subject: Hobbs Meter |
I was looking at the manufacturers site and notice that they offer 4 different mounting methods for this meter. Wag Aero and Aircraft Spruce do not tell you which mounting they have offered. See:
http://tinyurl.com/yhhxn53
Steve Thomas
________________________________________________________________________
Gilles.Thesee(at)ac-greno Guest
Posted: Sat Dec 05, 2009 9:29 am Post subject: Hobbs Meter |
Steve Thomas a écrit :
Here's a link to the manufacturer data sheet :
http://www.enmco.com/pdf/675.PDF
Wag Aero's products seems to be the T54C1 'Rectangle Panel Mount w/ 2
Holes'.
Most interesting. No wire, no connection, no nothing
Best regards,
Gilles
http://contrails.free.fr
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Sat Dec 05, 2009 10:05 am Post subject: Hobbs Meter |
I had a look at these items, and they all have a 8 year battery life, but
cannot be replaced - does anyone not think this could be a problem !!!
Regards: John
rob(at)hyperion-ef.com Guest
Posted: Sat Dec 05, 2009 10:17 am Post subject: Hobbs Meter |
To quote the data sheet: "Internal Lithium Battery 8 years plus
non-replaceable." That makes it a bit difficult to measure total time on
the airframe, or for an average private pilot, the engine.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
Posted: Sat Dec 05, 2009 10:20 am Post subject: Hobbs Meter |
JOHN TIPTON a écrit :
<jmtipton(at)btopenworld.com>
You have a point here, but is replacing a 35-45 $ item every eight year
or so really a problem ?
How many batteries, hoses, filters, brake pads mechanical parts will we
have to replace before that time ?
Just thinking.
Best regards,
Gilles
Posted: Sat Dec 05, 2009 10:29 am Post subject: Hobbs Meter |
Rob Housman a écrit :
the airframe,
Like with any other hourmeter, just enter the total time and date of
replacement in the airframe or engine logbook.
Best regards,
Gilles
Posted: Sat Dec 05, 2009 11:46 am Post subject: Hobbs Meter |
Actually I had in mind Reagan's famous "Trust but verify."
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
mrspudandcompany(at)veriz Guest
Posted: Sat Dec 05, 2009 11:47 am Post subject: Hobbs Meter |
the airframe,
Sounds to me like it is more hassle than benefit. Many
mechanics don't read all log entries for past years thus it gets forgotten.
Is there an alarm on the unit to indicate low battery, or does it just quit
and allow you to keep on flying without logging time??
Roger
winmail.dat |
3.38 KB |
663 Time(s) |
Joined: 28 Mar 2008 Posts: 1948 Location: Riley TWP Michigan
