Posted: Sat Apr 15, 2006 10:50 am Post subject: Test Flying |
| The programme is almost finished and I may actually get my hands on
the
| plane myself in the next couple of weeks.
| Cheers
| Pat
Patrick:
Here in the States we get to be our own test pilot for our own
aircraft.
Is there a requirement for a designated person to test your homebuilt
aircraft?
_________________ John Hauck
Titus, Alabama |
pj.ladd(at)btinternet.com Guest
Posted: Sun Apr 16, 2006 4:43 am Post subject: Test Flying |
Here in the States we get to be our own test pilot for our own aircraft.>>
Hi John,
for the normal annual C of A the pilot can fly his own stuff and just note
the readings on the official form.
In my case the Authorities decreed that Mick, as dealer, is the designated
test pilot because mine will be the first Xtra here fitted with a Jabi 4
stroke and VG`s and will consequently be the first to get `type approval`.
This means that any other planes, and there are several in the last stages
of building, with the same configuration will be automatically OK. They will
just need the certificates issued at intervals during building by the
inspector who monitors the standard of workmanship.
Mick is giving me a conversion and check out as I have not flown a tail
dragger for years. Roll on the good weather.
Cheers
Pat
planecrazzzy Guest
Posted: Sun Apr 16, 2006 4:58 am Post subject: Re: Test Flying |
Two essentials you should check before your FIRST TEST FLIGHT.....
Gotta Fly...
Mike in MN / N381PM
| Make sure you haven't lost "ALL" your Marbles... |
61.46 KB |
495 Time(s) |
| It helps if you have BALLS OF STEEL |
59.89 KB |
510 Time(s) |
Russ Kinne
Posted: Sun Apr 16, 2006 8:31 am Post subject: Test Flying |
Are you saying we may have lost our marbles??
On Apr 16, 2006, at 8:58 AM, planecrazzzy wrote:
planecrazzzy Guest
Posted: Sun Apr 16, 2006 9:44 am Post subject: Re: Test Flying |
Is that what I said.......Maybe read it again...
[quote="Russ Kinne"]Are you saying we may have lost our marbles??
kiwimick
Posted: Mon Apr 17, 2006 2:10 pm Post subject: Test Flying |
Sorry Pat,
G-CDFA was the first Xtra with Jab 2200 and VG's to gain full UK type
approval, G-PLAD is the next one though.
In the UK, ALL new kit built aircraft must initially be flown by a suitably
qualified test pilot and a final test programme conducted, then the A/C can
be issued with a full permit to fly. At each annual there after can be flown
by the owner.
Mike
_________________ Mike the kiwi Kolber in England....... |
Posted: Tue Apr 18, 2006 6:03 am Post subject: Test Flying |
Sorry Pat,
approval, G-PLAD is the next one though.>>
Hi Mike
something else I got wrong. Cant remember it working that way when I built
the Challenger. I think the dealers pilot just came and gave it a check
flight, about 30 minutes and I did the rest.
Regarding the recurring loss of power when I flew the other night. This
morning I drained and changed the fuel, emptied carb bowls, cleaned filters
and then spent 30 minutes at cruise revs tied to a farm gate post. Engine
ran faultlessly.
Someone else on my strip in a Cub lost their engine on the approach
yesterday. Very experienced ex commercial pilot who put it down to icing.
Perhaps that was my problem
Pat
