andrew.bridget(at)telus.n Guest
Posted: Fri Nov 27, 2009 7:57 am Post subject: Question on Aircraft Cowl Openings |
Hello everybody,
Happy Thanksgiving to all those from the US.
I wonder if one of you could help me, please... On the cowl of a piston engine aircraft, on either side of the prop hub there are usually two openings that allow air into the cowl to cool the engine. What are those openings called? Do they have a name?
Thanks in advance!
God bless,
Andrew
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
dongirod
Posted: Fri Nov 27, 2009 8:21 am Post subject: Question on Aircraft Cowl Openings |
That is where my filters for the air intakes are as well as the cooling.
Does the term "hole" come to mind
From: andrew.bridget(at)telus.net (andrew.bridget(at)telus.net)
Sent: Friday, November 27, 2009 10:55 AM
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Subject: Question on Aircraft Cowl Openings
Hello everybody,
Thanks in advance!
God bless,
Andrew
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
Release Date: 11/27/09 02:58:00
rcdettmer(at)charter.net Guest
Posted: Fri Nov 27, 2009 8:28 am Post subject: Question on Aircraft Cowl Openings |
There are 3 on my engine nacelles – 1 in the middle for the oil cooler, and 1 on either side of the spinner for the cylinder heads. I call them “air inlet opening thingies”. Happy holidays..!!
Randy Dettmer, AIA, NCARB
680F / N6253X
Dettmer Architecture
663 Hill Street
San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
www.dettmerarchitecture.com
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of dongirod
Sent: Friday, November 27, 2009 8:21 AM
Subject: Re: Commander-List: Question on Aircraft Cowl Openings
Hello everybody,
Thanks in advance!
God bless,
Andrew
| Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.comhref="http://www.buildersbooks.com">www.buildersbooks.comhref="http://www.homebuilthelp.com">www.homebuilthelp.comhref="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">http://forums.matronics.com |
Release Date: 11/27/09 02:58:00 0123456789 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 0 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 1 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 2 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 3 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 4 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 5 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 6 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 7 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 8 | Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com | 9 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 0 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 1 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 2 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 3 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 4 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 5 | Quote: | | href="http://www.buildersbooks.com">www.buildersbooks.com | 6
2.9 KB |
6195 Time(s) |
dongirod
Posted: Fri Nov 27, 2009 8:58 am Post subject: Question on Aircraft Cowl Openings |
Andrew, I'm looking, but thought maybe a little humor in the mean time, might work.
So far under "Aircraft Technical" this is what they say "v=induction system The engine receives ram air through an intake in the lower front portion of the engine cowling. An air filter is placed at the intake end of the duct. " which lacks a lot, calling it only an intake. But will keep looking.
Sent: Friday, November 27, 2009 11:29 AM
Subject: Re: Question on Aircraft Cowl Openings
I guess I was looking for something a little more precise and/or technical - "D ducts", maybe?
God bless,
Andrew
dongirod
Posted: Fri Nov 27, 2009 8:59 am Post subject: Question on Aircraft Cowl Openings |
OH, forgot to mention, on my Commander, the term "Birdhouse" describes it very well in the summer time.
God bless,
Andrew
Posted: Fri Nov 27, 2009 9:10 am Post subject: Question on Aircraft Cowl Openings |
Thanks, Don, I knew you were kidding.
What I found was this on a Diamond aircraft service bulletin: (http://www.diamondaircraft.com/library/10/11/Enlarged_cowl.pdf)
"The engine cooling air inlets in the upper cowling may be enlarged to reduce engine temperatures for operators who regularly fly at high outside air temperatures. This change is compatible with the Two Stage Winter Kit (SB DAC1-71-03)."
I guess they are "engine cooling air inlets"...
Thanks!
God bless,
Andrew
BobsV35B(at)aol.com Guest
Posted: Fri Nov 27, 2009 9:40 am Post subject: Question on Aircraft Cowl Openings |
How about engine cooling air intake?
My Stearman ain't got none!
Happy Skies,
Old Bob
In a message dated 11/27/2009 10:22:12 A.M. Central Standard Time, dongirod(at)bellsouth.net writes:
| Quote: | That is where my filters for the air intakes are as well as the cooling.
Hello everybody,
Thanks in advance!
God bless,
Andrew
dongirod
Posted: Fri Nov 27, 2009 10:33 am Post subject: Question on Aircraft Cowl Openings |
I have been on Google, FAA, and Airman Information Manual, for over an hour and don't find a thing, so sounds good to me.
Don
Sent: Friday, November 27, 2009 12:39 PM
Happy Skies,
Old Bob
In a message dated 11/27/2009 10:22:12 A.M. Central Standard Time, dongirod(at)bellsouth.net (dongirod(at)bellsouth.net) writes:
Hello everybody,
Thanks in advance!
God bless,
Andrew
Posted: Fri Nov 27, 2009 11:19 am Post subject: Question on Aircraft Cowl Openings |
Thanks, Don & Bob.
