Phil White
Joined: 10 Jan 2006 Posts: 45 Location: Downers Grove, IL
Posted: Wed Nov 25, 2009 11:36 am Post subject: AGM batteries question |
I am building an RV with Mazda rotary engine that is electric-dependent,
so I will have 2 batteries, and probably 2 alternators. It came time to
purchase batteries, and I presumed I would use the Odyssey PC-680 16AHr
AGM units. A web search didn't find any bargains (lowest was $118 each,
if memory serves).
A search for AGM batteries led me to Gruber Power Systems, who make
an 18 AHr unit nearly identical in size and capacity to the Odyssey 680,
but only $42 each. I have purchased a pair, and am in process of
mounting and wiring them, but I wonder if anyone has experience with or
has tested Gruber batteries, or others like them, to determine if they
are well suited to aircraft use.
I did notice that the terminals are noticably thinner than what one
sees on the Odysseys, being a half inch tall and wide, but only 1/16"
thick protruding up from the battery top. Makes me wonder if these
batteries won't supply the high current needed for starting an engine,
only having long life in lower current demand applications.
Any experience you can share?
Phil in IL
Posted: Thu Nov 26, 2009 9:30 am Post subject: AGM batteries question |
At 01:29 PM 11/25/2009, you wrote:
electric-dependent, so I will have 2 batteries, and probably 2
alternators. It came time to purchase batteries, and I presumed I
would use the Odyssey PC-680 16AHr AGM units. A web search didn't
find any bargains (lowest was $118 each, if memory serves).
make an 18 AHr unit nearly identical in size and capacity to the
Odyssey 680, but only $42 each. I have purchased a pair, and am in
process of mounting and wiring them, but I wonder if anyone has
experience with or has tested Gruber batteries, or others like
them, to determine if they are well suited to aircraft use.
ANY reasonable battery is suited to aircraft use IF your
system is designed and crafted for failure tolerance.
In other words, assuming your system is designed such
that failure of a battery brings you to an unplanned
arrival with the earth, then NO battery (or its accessory
connection hardware) can offer at 100.00% level of
certainty for no unhappy days in the cockpit.
First, set up design goals that include conducing
failure mode effects analysis on your proposed system.
You need to KNOW than no single failure of any fragile
or wearing component will present a hazard. If such
components are identified, they are (1) increased in
robustness to achieve reliability of prop-bolts or
(2) backed up by a plan-b. In the case of wearing
components (like batteries, tires, oil, alternator
belts, etc.) you craft a preventative maintenance plan
that identifies and replaces a sub-standard component
long before its ability to deliver to design goals
is compromised.
| Quote: | I did notice that the terminals are noticably thinner than what
one sees on the Odysseys, being a half inch tall and wide, but only
1/16" thick protruding up from the battery top. Makes me wonder if
these batteries won't supply the high current needed for starting
an engine, only having long life in lower current demand applications.
Starting the engine is the LEAST of your concerns.
Battery sizing (energy stored in a NEW battery)
and performance tracking (energy stored in a USED
battery) are the drivers for your battery selection
and maintenance activities.
| Quote: | Any experience you can share?
Be wary of anecdotal experiences. There are many, MANY
combinations of condition and stress that drive the
performance of a battery. Some combinations can make
a platinum plated super-battery look like a brick of
lead while other conditions induce owners to heap praises
upon their bargain-barn battery.
If selected, installed and maintained with rudimentary
knowledge of requirements to meet design goals ANY
battery (including your $42 find) is a candidate
for exploration.
You will have to judge for yourself whether your
choice has performed to satisfactory cost-of-ownership
values. You won't have that answer for several years.
In the mean time, be VERY wary of those who extol
the virtues of their own choices: "My Excalibur 1000
cranking-amp battery has been spinning my engine for
6 years now . . . best battery I've ever owned."
Ask that fellow how long that battery runs his
electro-whizzies if the alternator quits. It's
almost a sure bet he can't tell you.
See:
http://www.aeroelectric.com/Mfgr_Data/Batteries/Concorde/owner_manual_new.pdf
http://www.aeroelectric.com/articles/battery.pdf
http://www.aeroelectric.com/articles/rg_bat.html
http://www.aeroelectric.com/articles/allelect.pdf
http://www.aeroelectric.com/articles/bat_thd.pdf
http://www.aeroelectric.com/articles/neveragain/neveragain_2.html
The short answer to your question is: Yeah, that battery
should be included in your suite of choices. Plan
on doing periodic capacity and load-dump testing to
insure continued flight-worthiness in concert with
your design goals.
See chapter 17 of:
https://matronics.com/aeroelectric/Catalog/pub/pub.html#P-Book
In the mean time, what are you building? What's your
proposed electrical system architecture look like?
Have you done a load analysis of all the electro-whizzies
on your airplane to size your energy requirements
for normal and abnormal operating conditions?
