backup battery connected to two units
tomhanaway
PostPosted: Tue Nov 24, 2009 10:36 am    Post subject: backup battery connected to two units Reply with quote
Bob,
Hope this comes through ok. This is a backup battery assembly for a trutrak ADI. Pins 1 and 6 are hardwired for normal operation. Pin 8 is switched on for backup battery. Switch illuminates in backup position.
I’d like to attach a second instrument (nominal draw of 0.45MA (at) 13.8 v illuminated) to take advantage of the availability of backup.
I understand and am not concerned about reduction in overall time of operation of backup if both units are on.
Can I just run the white/red power output to both units?
Do I need diodes in line with each unit in case one fails?
Other alternative arrangement?
Thanks in advance,
Tom Hanaway
<![endif]--><![if !vml]> [img]cid:image004.jpg(at)01CA6D0A.301D5650[/img] <![endif]>
<![endif]--><![if !vml]>[img]cid:image005.gif(at)01CA6D0A.301D5650[/img]<![endif]>
 Filesize:  37.56 KB
 Viewed:  1446 Time(s)
 Filesize:  52.83 KB
 Filesize:  73 Bytes
RV-10. Built and sold
RV-8a. Building
