More "Nets"
zsmith3rd(at)earthlink.ne
PostPosted: Tue Nov 24, 2009 10:15 am    Post subject: More "Nets" Reply with quote
Another possible source for netting, and other items not easily sewed on the typical home Singer,
(especially by the typical rivet puller) is your local "trucker's supply".
In most areas dump trucks, rock haulers, gravel haulers, etc, are required to put netting over their loads.
Usually some guy has a big industrial sewing machine and a selection of netting, some very long work tables (leveled) and giant sissors. These firms make nets-to-order.
Also, consider awning merchants. They cut & sew canvas, belting material, etc, and likely have the expertise to custom-fit your idea.
Be cautious about mentioning the word "airplane" as the price usually goes up.
Regards.
Zed
raymondj(at)frontiernet.n
PostPosted: Tue Nov 24, 2009 4:23 pm    Post subject: More "Nets" Reply with quote
Get a net shuttle and make your own! I've made several for my boat.
Very easy to do.
Raymond Julian
Kettle River, MN.
Regards.
Zed
edleg
PostPosted: Sat Jan 09, 2010 10:28 am    Post subject: Re: More Reply with quote
What is a "net shuttle"? and where does one get it? I did a google search and came up with nada.
edleg
PostPosted: Sat Jan 09, 2010 10:29 am    Post subject: Re: More Reply with quote
PostPosted: Sat Jan 09, 2010 11:46 am    Post subject: More "Nets" Reply with quote
My wife informs me the correct term is "netting shuttles".
Here's one source:
http://halcyonyarn.com/weaving_shuttles.html
Here's one page I happened across:
http://www.lafishmag.com/nets.html
Hope this helps.
Raymond Julian
Kettle River, MN.
http://forums.matronics.com/viewtopic.php?p 80818#280818
frank.goodnight(at)att.ne
Hi all,
Strictly a 1/2 educated guess.---could be the tool that fishermen use
to repair holes in gill nets-
Frank Goodnight
On Jan 9, 2010, at 12:28 PM, edleg wrote:
<ed_legault(at)yahoo.com>
carlossa52(at)gmail.com
Isn't it the device where one spools the yarn used for making the net?
If it is, it probably received that name because it gets thrown form one side to another during the process.
Found this: http://www.nmai.si.edu/searchcollections/results.aspx?objtype=Weaving+tools%2fequipment&objid=Net+shuttle
also
http://en.wikipedia.org/wiki/Shuttle_%28weaving%29
Carlos
CH601-HD, plans
2010/1/9 edleg <ed_legault(at)yahoo.com (ed_legault(at)yahoo.com)>
[quote]--> Zenith701801-List message posted by: "edleg" <ed_legault(at)yahoo.com (ed_legault(at)yahoo.com)>
Terry Phillips
PostPosted: Sat Jan 09, 2010 12:12 pm    Post subject: More "Nets" Reply with quote
Ed
I presume what you are interesting in doing in making a net, IIRC, netting is the correct verb.
I used to have a book on how to net, and many years ago I made a few small nets. They make great shopping bags.
The net shuttle is just a handy device to hold a nice quantity of string (or whatever you are making the net from) while you maneuver the string and tie the knots to make up the net.
I made some shuttles out of plastic (like the sides of an empty antifreeze jug) similar to the ones shown in Carlos' link. The plastic wasn't stiff enough and they didn't work very well. I had better luck making them out of coat hanger wire, something like the attached dwg. Size is somewhat arbitrary, depending on the thickness of the string and the size of the mesh and the net dimensions.
Terry
also
Carlos
CH601-HD, plans
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Balancing the ailerons and working on the wings
http://www.mykitlog.com/N47TP/ [quote][b]
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
Terry Phillips
PostPosted: Sat Jan 09, 2010 12:36 pm    Post subject: More "Nets" Reply with quote
Whoops! Forgot the attach.
Ed
Terry
also
Carlos
CH601-HD, plans
ttp44~at~rkymtn.net
Corvallis MT
Netting_Shuttle.pdf
 Filename:  Netting_Shuttle.pdf
 Filesize:  24.95 KB
 Downloaded:  663 Time(s)
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
n4546v(at)mindspring.com
PostPosted: Sat Jan 09, 2010 5:16 pm    Post subject: More "Nets" Reply with quote
NET SHUTTLE SET
Shuttles are a required tool for net making and net repair. Shuttles
are used to store and dispense the twine as it woven through the net and
knots are tied. Shuttle size is determined by the size of twine you are
using and the mesh size of your net. Set includes 8 different sizes of
shuttles capable of a minimum 1/2 inch mesh up to a 4 inch turtle trap mesh.
Catalog # 971900
In Stock
$5.95 / EACH
http://www.jannsnetcraft.com/Search/shuttle.aspx
There you go...........
Randy, Las Vegas
 Filesize:  2 KB
 Viewed:  15370 Time(s)
