tomhanaway
Posted: Tue Nov 24, 2009 10:36 am Post subject: backup battery connected to two units |
Hope this comes through ok. This is a backup battery assembly for a trutrak ADI. Pins 1 and 6 are hardwired for normal operation. Pin 8 is switched on for backup battery. Switch illuminates in backup position.
I’d like to attach a second instrument (nominal draw of 0.45MA (at) 13.8 v illuminated) to take advantage of the availability of backup.
I understand and am not concerned about reduction in overall time of operation of backup if both units are on.
Can I just run the white/red power output to both units?
Do I need diodes in line with each unit in case one fails?
Other alternative arrangement?
Thanks in advance,
Tom Hanaway
<![endif]--><![if !vml]> [img]cid:image004.jpg(at)01CA6D0A.301D5650[/img] <![endif]>
<![endif]--><![if !vml]>[img]cid:image005.gif(at)01CA6D0A.301D5650[/img]<![endif]>
37.56 KB |
1413 Time(s) |
52.83 KB |
1413 Time(s) |
73 Bytes |
1413 Time(s) |
_________________ RV-10. Built and sold
RV-8a. Building |
