Overhead Console
rleffler
PostPosted: Mon Nov 23, 2009 3:44 pm    Post subject: Overhead Console Reply with quote
Geoff Combs (Aerosport Products) stopped by today with my new carbon fiber overhead console. I must say that I was rather impressed with the quality and fit. It fits perfectly, so I won't have to do all the sanding and filling that others have done with the fiberglass overheads. It's also significantly lighter than the fiberglass overheads too. Since it's hot off the press, or should I say vacuum bag, the access panels, air vents, and clothes hangar haven't been installed yet.
 Filesize:  53.63 KB
 Viewed:  9283 Time(s)
 Filesize:  61 KB
 Filesize:  63.77 KB
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
ricksked(at)embarqmail.co
PostPosted: Mon Nov 23, 2009 4:19 pm    Post subject: Overhead Console Reply with quote
Bob
It ain't the overhead console that needs all the filling and sanding.....its the CABIN TOP!!!!
Rick Sked
N246RS
Sent via BlackBerry by AT&T
dmaib@me.com
PostPosted: Mon Nov 23, 2009 4:36 pm    Post subject: Re: Overhead Console Reply with quote
Bob,
Wow! That looks fantastic. My memories of fitting the overhead console that came with my air conditioning kit are pretty grim.
David Maib
RV-10 #40559
New Smyrna Beach, FL
MauleDriver(at)nc.rr.com
PostPosted: Mon Nov 23, 2009 4:39 pm    Post subject: Overhead Console Reply with quote
So is the pink top a little better finished than the green one?
Bob
Rick Sked
N246RS
msausen
PostPosted: Mon Nov 23, 2009 4:54 pm    Post subject: Overhead Console Reply with quote
Based on mine crappy green one, it certainly seems to be.
Michael
jeff(at)westcottpress.com
PostPosted: Mon Nov 23, 2009 5:19 pm    Post subject: Overhead Console Reply with quote
You, sir, are doing a disservice to the word crap.
Do Not Archive.
Michael
rleffler
PostPosted: Mon Nov 23, 2009 6:52 pm    Post subject: Overhead Console Reply with quote
Actually, there isn't much to do on the pink cabin cover. At least nothing
that the headliner won't cover easily. Granted, I've not done the doors or
windows yet. I've only seen one of the green ones and pink ones are quite
an improvement.
What I was referring to, but didn't articulate well, was the fit of the
overhead to the various compound curves around the hinge area, the big lip
just behind the doors, and the aft bulkhead area. One the fiberglass
overhead that I saw, it required quite a bit of tweaking and filling to get
it to fit well. Also, because it's carbon fiber, there is less of a
transition to fill between the top and the overhead. If you are going to
put in a head liner, you probably won't have to worry about that either.
Bob Leffler
N410BL - Phase I
rv10flyer
PostPosted: Mon Nov 23, 2009 6:59 pm    Post subject: Re: Overhead Console Reply with quote
Nice job on the overhead Geoff. My new pink cabin top and cowling looks really good even if it is not a manly color. Finishing up inventory and will start on empennage tomorrow. So far only one bag of hardware missing after inventory of finish and fuselage kit. DB Schenker delivered 5 crates in perfect condition! Van's did a great job on the crates, packaging, parts counts.
Wayne G.
dlm46007(at)cox.net
PostPosted: Mon Nov 23, 2009 8:13 pm    Post subject: Overhead Console Reply with quote
For the builders with the pin hole problem you might want to try a product
called Spread and Spray made by Pittsburg paint. It is used by Piper because
their fiberglass cowls are pretty rough. It was suggested by our paint shop
for use prior to the first flight or engine start.
jdriggs49(at)msn.com
PostPosted: Mon Nov 23, 2009 8:45 pm    Post subject: Overhead Console Reply with quote
So C how much are they?
Subject: Overhead Console
Date: Mon C 23 Nov 2009 18:45:29 -0500
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal C .ExternalClass li.ecxMsoNormal C .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri' C'sans-serif';} .ExternalClass a:link C .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p.ecxMsoAcetate C .ExternalClass li.ecxMsoAcetate C .ExternalClass div.ecxMsoAcetate {margin-bottom:.0001pt;font-size:8.0pt;font-family:'Tahoma' C'sans-serif';} .ExternalClass span.ecxEmailStyle17 {font-family:'Calibri' C'sans-serif';color:windowtext;} .ExternalClass span.ecxBalloonTextChar {font-family:'Tahoma' C'sans-serif';} .ExternalClass .ecxMsoChpDefault {;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
Geoff Combs (Aerosport Products) stopped by today with my new carbon fiber overhead console. I must say that I was rather impressed with the quality and fit. It fits perfectly C so I won't have to do all the sanding and filling that others have done with the fiberglass overheads. It's also significantly lighter than the fiberglass overheads too. Since it's hot off the press C or should I say vacuum bag C the access panels C air vents C and clothes hangar haven't been installed yet.
Bing brings you maps C menus C and reviews organized in one place. Try it now.
 Filesize:  53.63 KB
 Viewed:  9250 Time(s)
 Filesize:  61 KB
 Filesize:  63.77 KB
rleffler
PostPosted: Tue Nov 24, 2009 3:42 am    Post subject: Overhead Console Reply with quote
You’ll need to give Geoff Combs a call. (614) 834-8659.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Monday, November 23, 2009 11:44 PM
Subject: RE: Overhead Console
So, how much are they?
Bob Leffler
N410BL - Phase I
Eric_Kallio
PostPosted: Tue Nov 24, 2009 5:58 am    Post subject: Re: Overhead Console Reply with quote
That looks a whole lot easier than the work I have put into fitting the Accuracy overhead to a green top. They don't line up, the contours don't match, not a good time. Too bad this wasn't available when I got mine.
Eric
johngoodman
PostPosted: Tue Nov 24, 2009 7:30 am    Post subject: Re: Overhead Console Reply with quote
I did a search on the web for it and can't find it. Another name, perhaps?
John
Strasnuts
PostPosted: Tue Nov 24, 2009 7:48 am    Post subject: Re: Overhead Console Reply with quote
I am interested in it too. I found it on a Sherwin Williams website.
http://cfm.swaerospace.com/product_information/data_pages/480922_Spot_Primer.pdf
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
roxianmike(at)msn.com
PostPosted: Tue Nov 24, 2009 4:50 pm    Post subject: Overhead Console Reply with quote
pricing is on the aerosport website
Subject: RE: RV10-List: Overhead Console
Date: Mon C 23 Nov 2009 22:43:32 -0600
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} So C how much are they?
Subject: RV10-List: Overhead Console
 Filesize:  53.63 KB
 Viewed:  9190 Time(s)
 Filesize:  61 KB
 Filesize:  63.77 KB
PostPosted: Tue Nov 24, 2009 7:11 pm    Post subject: Overhead Console Reply with quote
Looked it up...........$995.............even though I already made one up from a blazer console I am considering going for the whole package of his products..........hello Santa!...........hello Santa?.........are you there?...........(so hopefully my wife will read the emails tonight)
 Filesize:  53.63 KB
 Viewed:  9175 Time(s)
 Filesize:  61 KB
 Filesize:  63.77 KB
