In Flight HD Videos
robin1(at)mrmoisture.com
PostPosted: Sat Nov 21, 2009 3:43 pm    Post subject: In Flight HD Videos Reply with quote
Anyone out there recording in flight HD videos? I recall seeing a tail mounted bullet camera and some semi-wide angle video that was fantastic.
I want to record in flight videos in a similar way. I thought about mounting a HD bullet camera in the fiberglass section of the vertical stabilizer but I cannot find any 12V HD DVR’s that are an acceptable size and weight. Most of them are low resolution Security DVR’s.
A second fly in the ointment is I want to pull the audio in from the audio panel vs. just an open air mic. There seem to be some combination choices like these:
Really Small but not HD and no audio input.
Or this one:
1080P but no external audio feed. This is an all in one unit so no remote mounting as you have to have access to turn on/off
The nice part about this is it’s movable
Same with this unit:
Now I made a BIG mistake by mounting two DVD players in my RV-10 when portable ones would have been a much better choice due to advances in technology but I figured mounting an HD camera is not that big a deal as the most important part is the capture device (DVR) but as I can’t find any (except the Sony for $3,000) maybe the helmet style is best.
I believe this is another example of something I want/need now but the market has not quite caught up with my requirements.
Any guidance would be appreciated.
Robin
 Filesize:  81.04 KB
 Viewed:  1036 Time(s)
 Filesize:  54.85 KB
 Filesize:  83.87 KB
 Filesize:  238.89 KB
