rveighta(at)comcast.net Guest
Posted: Wed Nov 18, 2009 4:44 am Post subject: Work Bench Cover |
Guys, on some of the RV websites I've noticed work benches covered with some sort of protective cover, which
I'm assuming is there to prevent scratches on metal parts. I would appreciate any input as to what is used and
where to get it.
Thanks, Walt Shipley
FisherPaulA(at)JohnDeere. Guest
Posted: Wed Nov 18, 2009 5:17 am Post subject: Work Bench Cover |
I used the liner material for tool boxes. You can buy it by the roll at Sears (as well as other places). Do a Google search for “tool drawer liner�. It’s typically to keep tools from sliding around inside the tool box, but it also helps keep parts from sliding around on the bench! Plus as you say, it helps keep scratches to a minimum.
I believe there are several styles available. Mine had small holes throughout it that helped separate the metal chips from part.
Hope that helps.
Paul A. Fisher
RV-7A N18PF ~60 hours since August
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rveighta(at)comcast.net
Sent: Wednesday, November 18, 2009 06:43
To: rv-list(at)matronics.com
Subject: RV-List: Work Bench Cover
where to get it.
chaskuss(at)yahoo.com Guest
Posted: Wed Nov 18, 2009 5:49 am Post subject: Work Bench Cover |
Walt,
I don't have a web page. I use carpeting scraps to prevent scratching of aluminum sheet parts. I usually place this on the work bench just prior to removing the plastic coating. This is usually for the dimpling process.
I simply go to my local carpet supplier and check out the dumpster behind his shop. Another material you can use is cork sheet. This is used under carpeting & laminate flooring. Home Depot carries it, in case you can't find any in the dumpster!
Charlie Kuss
--- On Wed, 11/18/09, rveighta(at)comcast.net <rveighta(at)comcast.net> wrote:
| Quote: | From: rveighta(at)comcast.net <rveighta(at)comcast.net>
Subject: Work Bench Cover
Date: Wednesday, November 18, 2009, 7:43 AM
#yiv2001607845 p
{margin:0;}Guys,
and
where to get it.
provided
Admin.
jfogarty(at)tds.net Guest
Posted: Wed Nov 18, 2009 1:04 pm Post subject: Work Bench Cover |
Walt, I have used the light weight rubber mats you can get at Fleet Farm or Home Depot, however, pine table tops are just fine or whatever material you have available. I'm moving my project to the hangar this week and making a few more tables. Good luck!
Jim Fogarty
RV9a Building
william(at)gbta.net Guest
Posted: Wed Nov 18, 2009 4:18 pm Post subject: Work Bench Cover |
Try short mesh carpet (I think they call it berber). That's what I use and it works great.
gcomfo(at)tc3net.com Guest
Posted: Wed Nov 18, 2009 5:41 pm Post subject: Work Bench Cover |
where to get it.
Old timers have used and I continue to use a corrugated cardboard bench cover. It's cheap, usually free, and heavier versions make a good surface for working on. The smooth surface does not retain particulates and a brushing followed by a bare handed wipe makes a clean enough area that you can slide aluminum around without scratching it. Gordon Comfort, N363GC. . | [b]
lsbrv7a(at)yahoo.com Guest
Posted: Wed Nov 18, 2009 6:31 pm Post subject: Work Bench Cover |
Walt,
Try kitchen drawer liner from Big Lots, perforated foam rubber, bright, soft and non slip.
Sherman Butler
RV-7a Wings
N497GS reserved
Carlsbad, NM
Date: Wednesday, November 18, 2009, 5:43 AM
#yiv1329106890 p {margin:0;} Guys, on some of the RV websites I've noticed work benches covered with some sort of protective cover, which
where to get it.
om
st
Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Wed Nov 18, 2009 8:53 pm Post subject: Work Bench Cover |
I built the EAA chapter 1000 work tables. About the same time, I found these 2X5' mats at Woodcrafters. They are thick rubber, made for standing on. Perfect fit for the benches. Firm but totally protect aluminum.
Michael Wynn
RV 8
San Ramon
In a message dated 11/18/2009 5:50:36 A.M. Pacific Standard Time, chaskuss(at)yahoo.com writes:
| Quote: | --> RV-List message posted by: Charles Kuss <chaskuss(at)yahoo.com>
Walt,
Charlie Kuss
#yiv2001607845 p
{margin:0;}Guys,
and
where to get it.
provided
Admin.
========================; nbsp; (And Get Some AWESOME FREE to find Gifts tric re b k you for p; -Matt Dralle, List ======================== ties Day ================================================ - MATRONICS WEB FORUMS ==================================================
_________________ Michael Wynn
RV 8
San Ramon, CA |
aerobubba(at)earthlink.ne Guest
Posted: Sat Nov 21, 2009 12:55 pm Post subject: Work Bench Cover |
I used non-skid rug underlayment. It appears to be like a fine mesh, knotted netting that has been dipped in a soft foam rubber material. The end result is a very flexible sheet of what looks like small beads stuck to each other. The softness cushions the wing skins, the non-skid aspect keeps your work from sliding around, and the gaps / holes in the material provide a place for drilling and deburring chips etc to go such that they can't scratch the aluminum. It can be gotten as drawer liner, but it is MUCH cheaper to get it as rug underlayment from Target, Wally world, or some such.
Glen Matejcek
