side baffles side
rv10builder(at)verizon.ne
PostPosted: Sat Nov 21, 2009 7:44 am    Post subject: side baffles side Reply with quote
I am leaning toward using a single piece side baffle on both sides
versus the 3 piece that comes with the VAN's kit. Any one see any issues
with doing so? I know the industry standard is three (one per
cylinder)and I gather there is a reason for that (movement of cylinders)
so not sure if having a single piece will cause any issues..
Thanks!
P
Tim Olson
PostPosted: Sat Nov 21, 2009 8:24 am    Post subject: side baffles side Reply with quote
You wouldn't like it if it came time to remove a cylinder.
You'd have a LOT more work to do.
Tim Olson - RV-10 N104CD
Thanks!
P
partner14
PostPosted: Sat Nov 21, 2009 9:04 am    Post subject: side baffles side Reply with quote
Tim, how is it more work to do,,,, Only 7 screws holding it on the side, a few in fromt, and a few in back.  And the ones in the front and back are there no matter how many pieces the baffle is made from.... and also, help me out here.... is removing a cylinder something that I'm going to have to do very often?
Thanks, Don McDonald
--- On Sat, 11/21/09, Tim Olson <Tim(at)myrv10.com> wrote:
Subject: Re: side baffles side
Date: Saturday, November 21, 2009, 8:23 AM
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Pascal wrote:
--> RV10-List message posted by: Pascal <rv10builder(at)verizon.net (rv10builder(at)verizon.net)>
so not sure if having a single piece will cause any = this year's Terrific Free Incentive Gifts provided
matronics.com/contribution" &nbsp href="http://www.matronics.com/Navigator?RV10-List" target=_blank>httpbsp; --> h
Don A. McDonald
40636
deej(at)deej.net
PostPosted: Sat Nov 21, 2009 9:35 am    Post subject: side baffles side Reply with quote
Depends...
<http://aero-news.net/index.cfm?ContentBlockID=420682ed-fa3d-46bc-82bd-e84403417e8a&>
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
jesse(at)saintaviation.co
PostPosted: Sat Nov 21, 2009 9:49 am    Post subject: side baffles side Reply with quote
It's enough work getting the front & back assemblies on as it is without having them tied together. Why add the fabrication work of making it all 1 piece?
Jesse SaintSaint Aviation
352-427-0285
On Nov 21, 2009, at 12:02 PM, Don McDonald <building_partner(at)yahoo.com (building_partner(at)yahoo.com)> wrote:
[quote]Tim, how is it more work to do,,,, Only 7 screws holding it on the side, a few in fromt, and a few in back. And the ones in the front and back are there no matter how many pieces the baffle is made from.... and also, help me out here.... is removing a cylinder something that I'm going to have to do very often?
--- On Sat, 11/21/09, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
From: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
--> RV10-List message posted by: Tim Olson <[url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)[/url]>
Pascal wrote:
--> RV10-List message posted by: Pascal <[url=mailto:rv10builder(at)verizon.net]rv10builder(at)verizon.net (rv10builder(at)verizon.net)[/url]>
matronics.com/contribution" href="http://www.matronics.com/Navigator?RV10-List" target=_blank>httpbsp; --> h
[/url]
[url=http://forums.matronics.com/]
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
ricksked(at)embarqmail.co
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> As much as your flying Don....yes. Your due for a cylinder change very soon. Smile
Sent via BlackBerry by AT&TFrom: Don McDonald <building_partner(at)yahoo.com>
Date: Sat, 21 Nov 2009 09:02:00 -0800 (PST)
Subject: Re: RV10-List: side baffles side
Tim, how is it more work to do,,,, = Only 7 screws holding it on the side, a few in fromt, and a few in back.&n= bsp; And the ones in the front and back are there no matter how many pieces= the baffle is made from....  and also, help me out here.... is removi= ng a cylinder something that I'm going to have to do very often?
--- On Sat, 11/21/09, Tim Olson [i]<Tim(at)myrv10.com></= I> wrote:
Subject= : Re: RV10-List: side baffles side
Date: = Saturday, November 21, 2009, 8:23 AM
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
You wouldn't l= ike it if it came time to remove a cylinder.
You'd have a LOT more work = to do.
&g= t;
I am leaning toward using a single piece side baffle on both si= des
versus the 3 piece that comes with the VAN's kit. Any one see a= ny issues
with doing so? I know the industry standard is three (one= per
cylinder)and I gather there is a reason for that (movement of = cylinders)
so not sure if having a single piece will cause any =3D   this year's Terrific Free Incentive Gifts provided
= matronics.com/contribution"                     &nbsp= href=3D"http://www.matronics.com/Navigator?RV10-List" target=3D_blank>http= bsp; --> h=
=0A=0A [quote][b]
PostPosted: Sat Nov 21, 2009 10:54 am    Post subject: side baffles side Reply with quote
Thank you for the reply.
While I am flying however, would there be any issue with a single sided
baffle. I am thinking does the baffle need to move at all, is there a
heat expansion issue that having three separate pieces would allow for
expansion and contraction, etc..
Thanks!
P
> Thanks!
> P
pitts_pilot(at)bellsouth.
PostPosted: Sat Nov 21, 2009 12:23 pm    Post subject: side baffles side Reply with quote
You'll wind up with three pieces sooner or later anyway. Starting out
with three pieces means you get to pick where the cracks go.
Linn
Thanks!
P
Kellym
PostPosted: Sat Nov 21, 2009 2:25 pm    Post subject: side baffles side Reply with quote
IIRC, TCM lifters come out without splitting the case, however if the
cam is damaged the engine will have to come out entirely to send back to
TCM for repair. On new Lycoming engines you should not have any cam or
lifter distress with the roller cam, but if you do, it is still pull the
engine and tear it down, not a cylinder removal. Only ring, piston,
valve, and piston pin plug problems are likely to cause a cylinder
removal by itself.
Depends...
-Dj
Kelly McMullen
KCHD
partner14
PostPosted: Sat Nov 21, 2009 5:22 pm    Post subject: side baffles side Reply with quote
Jesse, because I built a plenum, I also built the side panels so I could simply screw/bolt the plenim directly to the top of the side baffles.  It's all on cadcam and we just run it out to the shop where it gets punched out just like Van's does... then over to the brake to put a 90 degree 3/4" lip on the top.... so it's already setup.... I'm going to make Pascal a set, and he/we were just trying to find out if there were any additional issues.
Linn, as to your statement about them ending up in 3 pieces anyway.... I use a floating system whereas the screws tighten down on stainless shims, thicker than the baffles, thereby letting the aluminum baffle float. So far 90 hours, no issues.
Thanks guys, Don
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Saturday, November 21, 2009, 9:41 AM
Jesse Saint Saint Aviation
352-427-0285
On Nov 21, 2009, at 12:02 PM, Don McDonald <building_partner(at)yahoo.com> wrote:
Pascal wrote:
--> RV10-List message posted by: Pascal <rv10builder(at)verizon.net>
[/url]
_blank rel=nofollow>www.aeroelectric.com
/" target=_blank rel=nofollow>www.buildersbooks.com
=_blank rel=nofollow>www.homebuilthelp.com
blank rel=nofollow>http://www.matronics.com/contribution
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
 Filesize:  1.9 MB
 Viewed:  5060 Time(s)
 Filesize:  1.76 MB
Don A. McDonald
40636
indigoonlatigo(at)msn.com
PostPosted: Sat Nov 21, 2009 9:33 pm    Post subject: side baffles side Reply with quote
With an engine that pretty C how do you justify a cowling.
John
Date: Sat C 21 Nov 2009 17:11:46 -0800
Jesse C because I built a plenum C I also built the side panels so I could simply screw/bolt the plenim directly to the top of the side baffles.  It's all on cadcam and we just run it out to the shop where it gets punched out just like Van's does... then over to the brake to put a 90 degree 3/4" lip on the top....  so it's already setup.... I'm going to make Pascal a set C and he/we were just trying to find out if there were any additional issues.
Linn C as to your statement about them ending up in 3 pieces anyway... I use a floating system whereas the screws tighten down on stainless shims C thicker than the baffles C thereby letting the aluminum baffle float.  So far 90 hours C no issues.
Thanks guys C Don
Date: Saturday C November 21 C 2009 C 9:41 AM
352-427-0285
On Nov 21 C 2009 C at 12:02 PM C Don McDonald <building_partner(at)yahoo.com> wrote:
Tim C how is it more work to do C C C C  Only 7 screws holding it on the side C a few in fromt C and a few in back.  And the ones in the front and back are there no matter how many pieces the baffle is made from....  and also C help me out here.... is removing a cylinder something that I'm going to have to do very often?
Thanks C Don McDonald
Date: Saturday C November 21 C 2009 C 8:23 AM
[/url]
partner14
PostPosted: Sat Nov 21, 2009 10:18 pm    Post subject: side baffles side Reply with quote
Thanks John, tried it without, but it doesn't cool very well!
--- On Sat, 11/21/09, John Gonzalez <indigoonlatigo(at)msn.com> wrote:
Subject: RE: side baffles side
To: "RV 10 group" <rv10-list(at)matronics.com>
Date: Saturday, November 21, 2009, 9:32 PM
With an engine that pretty, how do you justify a cowling.
John
Date: Sat, 21 Nov 2009 17:11:46 -0800
Thanks guys, Don
352-427-0285
[/url]
Don A. McDonald
40636
PostPosted: Sun Nov 22, 2009 4:29 am    Post subject: side baffles side Reply with quote
Well, I was hoping to avoid admitting that I 'had a better idea' when I
rebuilt my baffles on my Pitts. I didn't want to rivet the plates that
capture the adjacent part .... so did it in one piece. I bolted the
single part on .... and about 1 year on the new part .... it started to
crack. Stop-drilled the crack didn't keep it from migrating. Over
about 4 years .... I had 6 pieces .... with the capture plates riveted
on. When I got cracking from the mounting holes I rebuilt with 3 pieces.
Maybe having them float would have prevented the cracking.
Linn
Thanks guys, Don
partner14
PostPosted: Sun Nov 22, 2009 9:49 am    Post subject: side baffles side Reply with quote
Thanks Linn for the input.... that's what Pascal and I were looking for.... I am hoping that by being able to float on the screws, it will avoid the cracking issue.
Don McDonald
Flying, and lovin it.
Date: Sunday, November 22, 2009, 4:27 AM
--> RV10-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
Well, I was hoping to avoid admitting that I 'had a better idea' when I rebuilt my baffles on my Pitts. I didn't want to rivet the plates that capture the adjacent part .... so did it in one piece. I bolted the single part on .... and about 1 year on the new part ... it started to crack. Stop-drilled the crack didn't keep it from migrating. Over about 4 years .... I had 6 pieces .... with the capture plates riveted on. When I got cracking from the mounting holes I rebuilt with 3 pieces. Maybe having them float would have prevented the cracking.
Linn
Don McDonald wrote:
Jesse, because I built a plenum, I also built the side panels so I could simply screw/bolt the plenim directly to the top of the side baffles. It's all on cadcam and we just run it out to the shop where it gets punched out just like Van's does... then over to the brake to put a 90 degree 3/4" lip on the top.... so it's already setup.... I'm going to make Pascal a set, and he/we were just trying to find out if there were any additional issues. Linn, as to your statement about them ending up in 3 pieces anyway.... I use a floating system whereas the screws tighten down on stainless shims, thicker than the baffles, thereby letting the aluminum baffle float. So far 90 hour========================http://www.matronicsp; -Matt Drathe r?RV10-List" target=_blank>http://www.matronics.com/Navigator?RV10-List
 Filesize:  60.77 KB
 Viewed:  5033 Time(s)
Don A. McDonald
40636
