NevEyre(at)aol.com Guest
Posted: Fri Apr 14, 2006 7:15 am Post subject: Monowheel Jacking |
Hi Jon,
Safe to hoist the plane up from the undercarriage frame, take the plenum off
if you have a 912, other wise, no problems.
Put padded saw horses under the wings, padded with pillows / cushions, where
the the spars are , in front of the outriggers, to check the roll, if you
are going to get in for gear retraction.
Cheers,
Nev.
hagargs(at)earthlink.net Guest
Posted: Fri Apr 14, 2006 10:58 am Post subject: Monowheel Jacking |
Jon:
I just did this about 3 weeks ago. Attach an engine hoist just behind the
engine like you mentioned. I used a shackle and some nylon webbing. Don't
worry about having a lot of weight suspened from a single point. The plane
is not supposed to be heavy any way, right. Don't try to support any
amount of weight with the wings and stands unless you have a very large
bearing surface to lay on. Keep the weight off of the wings and on the
engine mount. Just put some items under the wings to stop them from
rotating and having the wingtips hit the ground. I was able to sit inside
and rotate the gear on the engine stand. Have someone outside by the stand
while you are doing this. Depending on how far your boom is out the stand
might tend to rotate. Adjust the boom or have your buddy stand on the
hoist
Steve Hagar
A143
Mesa, AZ
Steve Hagar
| Quote: | [Original Message]
Date: 4/14/2006 5:52:10 AM
Subject: Monowheel Jacking
Hi all, Sorry to "raise" this subject yet again - but I'd just like to
ask people's opinion...
| Quote: | Is it considered safe practice to lift a fully rigged monowheel for the
retraction test/ inspection using a hoist?
| Quote: | In the past I've always messed around with jacks and trestles under the
wing spars which works fine, if a little precarious! A friend though has a
hydraulic engine hoist which seems ideal and much easier - I was just
worried that there would be a lot of weight suspended from a single point
on the airframe.
| Quote: | Where is the best place to attach the strap? I've heard talk about using
the undercarriage mounting frame just behind the engine mounts??
| Quote: | If someone could reassure me - or otherwise - I'd be most grateful!
Best Regards,
Jon
tony.bale(at)virgin.net Guest
Posted: Sun Apr 16, 2006 2:17 pm Post subject: Monowheel Jacking |
John,
We have now raised '336' 3 times for various reasons, once with
a hoist and twice with a forklift. When using the hoist take care, the
aircraft will roll a long way forward when you lift it, it will also be
unstable and drop wings etc. We were fortunate to be building on a farm so
had access to a big forklift, this is much easier and cleaner if you have
the option. We found the hoist very restrictive, and easy to damage the
fuselage so protect it and the wings - however you may not have the option.
One word of caution (and this is very obvious in hindsight) - leave the
retraction tests as late as possible and dont work around the flap / gear
mechanism afterwards unless you have to. We simply fitted a small stowage
box in the rear luggage shelf and found out on the flight test it restricted
undercarriage dropping - and we had tested the gear 50+ times prior to
flight.
We lifted from the undercarriage / engine mount without problems, but if you
use a hoist remeber to add your weight to the aircrafts to make sure you
have sufficient capacity (aircraft weight circa 800 lb depending on build)
and get the longest arm possible.
ATB
Tony.
100 hours up and planning to fit the Airmaster, just preparing for the first
annual and working on the C of G mods (battery etc).
