ga23
Posted: Tue Nov 17, 2009 10:53 am Post subject: Rotax throttle |
Could anybody provide feedback on actually using this throttle?
http://www.mcfarlaneaviation.com/Details.aspx?ID=11744352&Article=199
What are the advantages? I find my current throttle (A-800 or similar number) from AS not easy to adjust and I wonder if you have found any improvements with the mcfarlane throttle. All I have seen so far is adds about the throttle but have not hear from anybody using it.
Greg
N701ZG
Flying
vgstol(at)bigpond.net.au Guest
Posted: Tue Nov 17, 2009 11:45 am Post subject: Rotax throttle |
I've been using the McFarlane throttle for quite awhile now, and really like it. No complaints at all. Nice smooth action. Solved all the problems of keeping carbs balanced.
JG
On Wed, Nov 18, 2009 at 4:53 AM, ga23 <ga2323(at)comcast.net (ga2323(at)comcast.net)> wrote:
[quote] --> Zenith701801-List message posted by: "ga23" <ga2323(at)comcast.net (ga2323(at)comcast.net)>
Greg
N701ZG
Flying
http://forums.matronics.com/viewtopic.php?p=273311#273311
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
n752ms(at)softcom.net Guest
Posted: Tue Nov 17, 2009 12:58 pm Post subject: Rotax throttle |
Greg.
I had nothing but trouble with the friction lock style. The 912 carb
springs are so strong that once you set the friction lock the instrument
panel is so thin, on the 701, that it gives enough to raise the rpm about
300 when you let go. I changed to the veneer type, fine adjustment when you
need it and full throttle is just a button push away.
Mark S.
701/912ULS 76 hours
Posted: Tue Nov 17, 2009 1:59 pm Post subject: Rotax throttle |
Good point. I put a 1.6mm doubler behind that corner of the panel.
JG
On Wed, Nov 18, 2009 at 6:57 AM, Mark Sherman <n752ms(at)softcom.net (n752ms(at)softcom.net)> wrote:
[quote]--> Zenith701801-List message posted by: "Mark Sherman" <n752ms(at)softcom.net (n752ms(at)softcom.net)>
Greg.
I had nothing but trouble with the friction lock style. The 912 carb springs are so strong that once you set the friction lock the instrument panel is so thin, on the 701, that it gives enough to raise the rpm about 300 when you let go. I changed to the veneer type, fine adjustment when you need it and full throttle is just a button push away.
Mark S.
701/912ULS 76 hours
lgold(at)quantum-associat Guest
Posted: Tue Nov 17, 2009 2:14 pm Post subject: Rotax throttle |
Greg,
Coming from an Ultralight background, I use a quadrant type throttle on the
left side just in front of the seat. I rest my hand on it comfortably, and
the friction lock seems to work well. To me, it's a good alternative to a
panel mounted throttle.
Les
ga23
Posted: Tue Nov 17, 2009 3:01 pm Post subject: Re: Rotax throttle |
Les,
Do you have a picture?
Greg
| lgold(at)quantum-associat wrote: | Greg,
Les
ggower_99(at)yahoo.com Guest
Posted: Tue Nov 17, 2009 5:36 pm Post subject: Rotax throttle |
I use the plans type of throttle, once you set the correct friction on the tube, they work perfect. About 270 hrs of simply fun and counting.
Saludos
Gary Gower
701 912S (about 270 hrs)
Flying from Chapala, Mexico.
--- On Tue, 11/17/09, Mark Sherman <n752ms(at)softcom.net> wrote:
Subject: Re: Rotax throttle
Date: Tuesday, November 17, 2009, 3:57 PM
Greg.
Mark S.
701/912ULS 76 hours
jpspencer(at)cableone.net Guest
Posted: Tue Nov 17, 2009 6:03 pm Post subject: Rotax Throttle |
I think I got the first Mcfarlane 2 in 1 throttle they made for the rotax...put in the order before they had it ready to sell anyway, and waited a while for it. I have tried a bunch of throttle setups and this is the first one I have found that keeps the carbs synched. I installed it and did a mechanical sync and checked it with the oil gauge and it was the closest I have ever gotten it, smoothest it's ever been and it's stayed that way...I didn't do any further adjustments. If I remember right, it was within about 2" of oil all the way thru the rpm range that I checked. I think that's hardly readable in mercury. JG knows what it equates to, I believe.
Highly recommended
Joe Spencer
dwilde(at)clearwire.net Guest
Posted: Wed Nov 18, 2009 8:23 am Post subject: Rotax throttle |
Gary Gower wrote:
| Quote: | I use the plans type of throttle, once you set the correct friction
I also use the plans throttle and it works well but does creep a little
at the lower rpms.
Dan Wilde
Posted: Wed Nov 18, 2009 9:32 am Post subject: Rotax throttle |
Greg, I'll take a pic and send it to you off-line in a few days.
Les
randy(at)rjhebertassoc.co Guest
Posted: Wed Nov 18, 2009 9:45 am Post subject: Rotax throttle |
Les
If you post it I would like to see it also
If not, can you send me a copy offline also.
Randall J Hebert
N7701P Reserved
Almost Finished, Yea right
