Worked on the plane today
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> FEWMustang-List
uh-1driver(at)earthlink.n
PostPosted: Mon Nov 16, 2009 8:12 pm    Post subject: Worked on the plane today Reply with quote
Huzzah!
With the shop projects winding down, I finally got to work on the plane. The wing construction table, after two moves, had become pretty rickety, so I had plans to rebuild the table. I had installed an electric hoist over the wing to raise and lower the wing panel during the construction. This time, I used it to raise the entire wing off the table. The saddles had only been marginally done, were improved. I painted epoxy in the saddle and trowled in some epoxy with micro. I then lowered the wing back onto the table. This will make the saddles to be exactly shaped to the curve of the upper wing surface. Tomorrow, I plan to rework the center box of the wing table.
More to follow.
Darren Henley
FEW P-51D Mustang
Demon Caller
- The Matronics FEWMustang-List Email Forum -
http://www.matronics.com/Navigator?FEWMustang-List
PostPosted: Mon Nov 16, 2009 8:16 pm    Post subject: Worked on the plane today Reply with quote
Huzzah!
More to follow.
Darren Henley
FEW P-51D Mustang
Demon Caller
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> FEWMustang-List All times are GMT - 8 Hours
