hcourier(at)cox.net Guest
Posted: Sat Nov 14, 2009 5:42 pm Post subject: AC-680FLP Hydraulic line problems |
Hello,
Had a small hydraulic line in the left wheel well break a while back. Had to land with no brakes, flaps, or steering. Got that fixed. Flew plane to the A&P location for an annual. Test flight after the annual, hydraulic leak in either the up or down line to the right main gear, actual line hasn't been isolated yet. My question...both hydraulic lines, on different side of the plane (comletely different lines also) have broken within 2 hours of flying time. Is there any hydraulic line history or trend for Commanders whereby hydraulic lines start to fail at the same time. In other words, is this going to be a problem in the next hours of flight or next years of flight. Does anyone have experience here?
Had to have new engine mounts and wastegates replaced during the annual. Paul Gendron in Ft Lauderdale, FL did a good job with the work. Corrosion on the mounts and manual wastegates were out of shape and quite thin at the elbows. Plane has been down over 4 months and now this hydraulic line problem.
Ray Mansfield
N91ES
850-217-5185
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
5.54 KB |
9733 Time(s) |
tfisher(at)commandergroup Guest
Posted: Sat Nov 14, 2009 10:02 pm Post subject: AC-680FLP Hydraulic line problems |
My hydraulic failure was due to a badly made replacement hard line in the right wheel well which put creases in the outside portion of a 90 degree curve.
Tom
formally C-GISS
680FLP (Mr.RPM)
5.54 KB |
9730 Time(s) |
cschuerm(at)cox.net Guest
Posted: Sun Nov 15, 2009 6:17 am Post subject: AC-680FLP Hydraulic line problems |
Ray Mansfield wrote:
| Quote: | In other words, is this going to be a problem in the next hours of
Ray,
If the line failed right at the flare, it was probably due to improper
fabrication. I've seen many cases where someone has made a line and
didn't know that aircraft aluminum lines use a different flare angle
than copper lines. The tool you'll find at your local hardware store to
flare line ends is for copper only and makes too sharp an angle for
aluminum. This causes cracks to form.
You also mentioned that you've been repairing corrosion in other areas.
The aluminum used for aircraft lines is fairly prone to corrosion. It
also "work hardens" from vibration and becomes more brittle with age.
You may simply be dealing with aging aircraft issues. During my
commander restoration, we ended up having to replace virtually every
hard line in the airplane for these reasons. I'd suggest a very careful
inspection of all your hard lines - especially the ones exposed in the
nacelles. Make sure they are well supported and that the adel clamps
are not loose or missing. If the lines are allowed to vibrate due to
old, worn-out supports, that can lead to rapid fatigue cracking. Clean
the lines carefully with scotch bright and look for corrosion pitting.
Even small pits lead to failure. Look for any areas where the lines are
chaffing (usually due to something coming loose) and address those areas
immediately. It's all just part of being the care-taker of a complex
old airframe.
good luck,
chris
dfalik(at)sbcglobal.net Guest
Posted: Sun Nov 15, 2009 6:48 am Post subject: AC-680FLP Hydraulic line problems |
I can relate a similar issue with my 500S. I had one line fail due to chafing in the baggage area. Boy was that a mess when the fluid erupted in the baggage compartment. Shortly thereafter another line failed just beyond the repaired one and it was due to an improper flare from a previous repair.
Don
Sent: Sun, November 15, 2009 9:15:52 AM
Subject: Re: AC-680FLP Hydraulic line problems
--> Commander-List message posted by: Chris <cschuerm(at)cox.net (cschuerm(at)cox.net)>
| Quote: | In other words, is this going to be a problem in the next hours of flight or next years of flight. Does anyone have experience here?
Ray,
If the line failed right at the flare, it was probably due to improper fabrication. I've seen many cases where someone has made a line and didn't know that aircraft aluminum lines use a different flare angle than copper lines. The tool you'll find at your local hardware store to flare line ends is for copper only and makes too sharp an angle for aluminum. This causes cracks to form.
You also mentioned that you've been repairing corrosion in other areas. The aluminum used for aircraft lines is fairly prone to corrosion. It also "work hardens" from vibration and becomes more brittle with age. You may simply be dealing with aging aircraft issues. During my commander restoration, we ended up having to replace virtually every hard line in the airplane for these reasons. I'd suggest a very careful inspection of all your hard lines - especially the ones exposed in the nacelles. Make sure they are well supported and that the adel clamps are not loose or missing. If the lines are allowed to vibrate due to old, worn-out supports, that can lead to rapid fatigue cracking. Clean the lines carefully with scotch bright and look for corrosion pitting. Even small pits lead to failure. Look for any areas where the lines are chaffing (usually due to something coming loose) and address those areas immediately. It's all just part of being the care-talectric www.aeroelttp://www.buildersbooks.com/" tHELP www.homebuip; &n===============
Posted: Sun Nov 15, 2009 7:01 am Post subject: AC-680FLP Hydraulic line problems |
In addition to the last failure two years before that the line entering the baggage compartment from the right wing root ruptured at a chaff point and pissed Skydrol all over the main wiring bundle which dissolved all the insulation on most of the wires. I had to replace almost all the wires in the bundle. Once that was done and paid for I wrapped the entire bundle in a Skydrol proof sheath so they would be protected from any other leaks that may occur in the future.
Tom
Formally C-GISS
680FLP (Mr.RPM)
tylorhall(at)mac.com Guest
Posted: Sun Nov 15, 2009 7:22 am Post subject: AC-680FLP Hydraulic line problems |
I am surprised to find out that the hydraulic lines in a aero commander are aluminum. I would have thought that 1000psi to 3000psi lines would be steel or SS. I manufacturer equipment that runs in this pressure range and we always use SS 1/4" tubing and compression fittings.It is easy to work, bends will with a tubing bender, would resist corrosion and lots of other good features.
Would it be a big deal with the FAA to change to SS tubing?
I am not an A&P.
Tylor Hall
On Nov 15, 2009, at 7:32 AM, Donald Falik wrote:
| Quote: | I can relate a similar issue with my 500S. I had one line fail due to chafing in the baggage area. Boy was that a mess when the fluid erupted in the baggage compartment. Shortly thereafter another line failed just beyond the repaired one and it was due to an improper flare from a previous repair.
Don
From: Chris <cschuerm(at)cox.net (cschuerm(at)cox.net)>
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Ray,
You also mentioned that you've been repairing corrosion in other areas. The aluminum used for aircraft lines is fairly prone to corrosion. It also "work hardens" from vibration and becomes more brittle with age. You may simply be dealing with aging aircraft issues. During my commander restoration, we ended up having to replace virtually every hard line in the airplane for these reasons. I'd suggest a very careful inspection of all your hard lines - especially the ones exposed in the nacelles. Make sure they are well supported and that the adel clamps are not loose or missing. If the lines are allowed to vibrate due to old, worn-out supports, that can lead to rapid fatigue cracking. Clean the lines carefully with scotch bright and look for corrosion pitting. Even small pits lead to failure. Look for any areas where the lines are chaffing (usually due to something coming loose) and address those areas immediately. It's all just part of being the care-talectricwww.aeroelttp://www.buildersbooks.com/" tHELP www.homebuip; &n===============
[/url]
[url=http://www.homebuilthelp.com/]
[/url] | Quote: |
color="#000000" face="courier new,courier">[url=http://www.aeroelectric.com]www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
yourtcfg(at)aol.com Guest
Posted: Sun Nov 15, 2009 8:44 am Post subject: AC-680FLP Hydraulic line problems |
The "hard lines" in all the Commanders are becoming the number one hyd issue. Inspect all of them and dont kid yourself. If they have any corrosion, change them out.
ALSO!!You landed with no brakes or steering and pulled it off, good on you! It is not necessary do that. PLEASE, PLEASE EVERYONE, LISTEN UP. AS SOON AS THE ENGINS ARE RUNNING PULL THE AUX HYD CIRCUIT BREAKER. DOING THIS ASSURES THAT THERE WILL BE ENOUGH FLUID FOR BRAKES AND STEERING. PLEASE, LETS STOP BEING STUBBORN ABOUT THIS BEFORE ANOTHER AIRPLANE IS LOST!! Thanks and good job with the landing!! jb
Posted: Sun Nov 15, 2009 8:47 am Post subject: AC-680FLP Hydraulic line problems |
We save a whole bunch when we go to modern electronics.
SS tubing is not that heavy. I will go look it up.
There is a question. How much tubing is in a Twin Commander?
How much tubing can we remove when the oil pressure and fuel pressure lines come out and are replace with electrical remote sensors?
Tylor Hall
On Nov 15, 2009, at 8:55 AM, Chris wrote:
I think I just detected Old Bob cringe at the thought of adding a couple hundred pounds of weight to an airplane
Stainless and carbon steel are both occasionally used, but aluminum is typical for light GA aircraft. Converting a Commander to all stainless lines would add an enormous amount of weight.
chris
Posted: Sun Nov 15, 2009 9:12 am Post subject: AC-680FLP Hydraulic line problems |
Thank goodness it wasn't Skydrol. The failure of the line in the baggage compartment was difficult to find because it was just a pin hole at the point that it was chafing against an adjacent line. The second failure shortly thereafter was out side of the compartment in the wing root and just dumped the fluid outside along the fuselage. That was the one due to an improper flare. The mechanic showed it to me.
Sent: Sun, November 15, 2009 10:00:17 AM
Subject: Re: Commander-List: AC-680FLP Hydraulic line problems
DIV { MARGIN:0px;} In addition to the last failure two years before that the line entering the baggage compartment from the right wing root ruptured at a chaff point and pissed Skydrol all over the main wiring bundle which dissolved all the insulation on most of the wires. I had to replace almost all the wires in the bundle. Once that was done and paid for I wrapped the entire bundle in a Skydrol proof sheath so they would be protected from any other leaks that may occur in the future.
Tom
Formally C-GISS
680FLP (Mr.RPM)
Posted: Sun Nov 15, 2009 9:34 am Post subject: AC-680FLP Hydraulic line problems |
SS 1/4" tubing is 0.08 lbs per foot, and Alum 1/4" tubing is 0.453 lb. per foot.300 feet of tubing exchanged out would be 13.50 lb. added to the empty weight.
Tylor Hall
On Nov 15, 2009, at 10:12 AM, Donald Falik wrote:
[quote]Thank goodness it wasn't Skydrol. The failure of the line in the baggage compartment was difficult to find because it was just a pin hole at the point that it was chafing against an adjacent line. The second failure shortly thereafter was out side of the compartment in the wing root and just dumped the fluid outside along the fuselage. That was the one due to an improper flare. The mechanic showed it to me.
From: Tom Fisher <tfisher(at)commandergroup.bc.ca (tfisher(at)commandergroup.bc.ca)>
Tom
Formally C-GISS
680FLP (Mr.RPM)
[quote]---
Posted: Sun Nov 15, 2009 10:35 am Post subject: AC-680FLP Hydraulic line problems |
Tylor Hall wrote:
| Quote: | SS 1/4" tubing is 0.08 lbs per foot, and Alum 1/4" tubing is 0.453 lb.
per foot.
Tylor,
Can you provide a reference for those numbers please? My materials
quick reference guide shows that stainless tube is aprox. three times
*heavier* than aluminum.
chris
blorber(at)southwestcirru Guest
Posted: Sun Nov 15, 2009 12:52 pm Post subject: AC-680FLP Hydraulic line problems |
http://www.swagelok.com/downloads/webcatalogs/EN/MS-01-153-scs.pdf
- 6061 is a medium strength alloy used for most general-purpose applications. it is more corrosion-resistant than 2024. It is also easier to weld than 2024.
- 2024 is a high-strength alloy most often used in aerospace applications. It has a yield strength that is roughly 10 percent higher and an ultimate strength of roughly 50 percent higher than 6061.
I got this quote off Onlinemetals.com. I did not find a difference in the weight of 6061 VS 2024. Does any one have the right alloy? Looks like the 2024 is the aerospace version? Chris or JimBob, could an owner substitute SS for Alum? I buy it in 20' lengths.
Tylor Hall
Two charts that show up in a quick search:
http://www.webcoindustries.com/tubing/stainless/weight.cfm
http://www.airpartsinc.com/products/Aluminum-tubing-round-6061-t6.htm
Apples to oranges, but similar OD and thickness (1/4" and .035) gives .028 lbs/ft for aluminum and .082 for stainless.
Posted: Sun Nov 15, 2009 1:49 pm Post subject: AC-680FLP Hydraulic line problems |
Tylor Hall wrote:
| Quote: | <http://www.swagelok.com/downloads/webcatalogs/EN/MS-01-153-scs.pdf>
Tylor,
A lot of my books are still packed in boxes from moving so I don't have
much definitive information available. I checked AC43.13 and it doesn't
mention anything about substitution. Actually, the version I have
doesn't mention stainless at all although I know there is an aircraft
approved 316L SS tube.
There are several different alloys used for alum. 3003-0 is used for
low pressure applications (mainly instrument stuff). 5052-0 is medium
pressure (hydraulic, fuel, oil). I think the high pressure apps used
2024-T3 (which is a typical alloy for aircraft structures and skin)
For my two cents, I'd replace aluminum with aluminum. If you're in a
corrosive environment, paint the tubes with zinc chromate.
chris
nico(at)cybersuperstore.c Guest
Posted: Sun Nov 15, 2009 3:08 pm Post subject: AC-680FLP Hydraulic line problems |
Tylor,
Aluminum is 5 times heavier than SS? I guess wall-thickness will have something to do with it, right?
Nico
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tylor Hall
Sent: Sunday, November 15, 2009 9:23 AM
SS 1/4" tubing is 0.08 lbs per foot, and Alum 1/4" tubing is 0.453 lb. per foot. 300 feet of tubing exchanged out would be 13.50 lb. added to the empty weight.
Tylor Hall
| Quote: | Thank goodness it wasn't Skydrol. The failure of the line in the baggage compartment was difficult to find because it was just a pin hole at the point that it was chafing against an adjacent line. The second failure shortly thereafter was out side of the compartment in the wing root and just dumped the fluid outside along the fuselage. That was the one due to an improper flare. The mechanic showed it to me.
Tom
Formally C-GISS
680FLP (Mr.RPM)
| Quote: | ----- Original Message -----
Sent: Sunday, November 15, 2009 6:32 AM
Don
Ray,
[/url]
[/url]www.aerow.buildersbooks.com/" rel=nofollow target=_blank>www.buildersbooks.comhttp://www.matronronics.com/Navigator?Commander-List" rel=nofollow target=_blank>http://htt========================
[/url][url=http://forums.matronics.com/] | [/url]
[/url]
[url=http://forums.matronics.com/] | Quote: |
color="#000000" face="courier new,courier">www.aeroelectric.com
Posted: Sun Nov 15, 2009 3:33 pm Post subject: AC-680FLP Hydraulic line problems |
NICO,NO, SS is twice the weight per foot as Aluminum. .080 VS .0453
Typo error.
Tylor Hall
On Nov 15, 2009, at 4:07 PM, nico css wrote:
| Quote: | Tylor,
Nico
From: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com) [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tylor Hall
Tylor Hall
Tom
Formally C-GISS
680FLP (Mr.RPM)
Don
Ray,
[/url]
[/url]
Posted: Sun Nov 15, 2009 6:20 pm Post subject: AC-680FLP Hydraulic line problems |
OK, thanks, Tylor.
Sent: Sunday, November 15, 2009 3:27 PM
NICO, NO, SS is twice the weight per foot as Aluminum. .080 VS .0453
Typo error.
Tylor Hall
| Quote: | Tylor,
Nico
Tylor Hall
Tom
Formally C-GISS
680FLP (Mr.RPM)
Don
Ray,
[/url]
[/url]
Posted: Sun Nov 15, 2009 6:53 pm Post subject: AC-680FLP Hydraulic line problems |
Aluminum is just fine as a replacement. After all original lasted 40+ years!!
wjrhamilton(at)optusnet.c Guest
Posted: Mon Nov 16, 2009 3:59 am Post subject: AC-680FLP Hydraulic line problems |
Folks,
Just make certain you use the right grade of Al. pipe.
If anybody wants to use stainless, the grades are as used in larger aircraft, but I would also suggest that, where possible, you use 1.5 degree taper compression fittings from Stratoflex or Aeroquip, again as per what has been used on 3000 psi systems since the '60's.
I can guarantee you will never have a leaking union at 1500psi ever again.
The shortcoming of the AN (37.5 degree) or SAE (45 degree as per autos) is that first surfaces to touch are the sealing surfaces, which works OK with soft material (most Al, annealed copper) but not so good steel, stainless or otherwise.
Re. corrosion of Al tubes, it is not always from the outside in, in my 500A, I have had two failures (pinholes) in low pressure return lines, at the fluid/air interface where a line is not always either full or empty.
I would also suggest that most flexibles be replaced with teflon hose, ALL my fuel lines are stainless/teflon, overkill maybe, but they will never fail in normal service. This does not even require a 337 to do the substitute, they all meet the appropriate Mil. Spec ( or the new standard) for an application where rubber hose is used.
In reality, Aero Commanders have had quite a few hydraulic problems over the years, we should be careful of the rose colored glasses, and even more careful with thorough routine inspections.
Here's one for thought, how far should you go in dismantling where there is no sign of failure, to inspect under Adel clamps, or fretting under a a union nut. I don't know the answer, I will watch the discussion with much interest.
Bill Hamilton.
years!!
