3/8" Insead of 5/16"
jbhart(at)onlyinternet.ne
PostPosted: Thu Apr 13, 2006 5:30 am    Post subject: 3/8" Insead of 5/16" Reply with quote
At 05:24 AM 4/13/06 -0700, you wrote:
Besides the wingtips, I am building new Vertical Stabilizer, Rudder, and Elevators.
The Plans show using 5/16" for most all of this. I could not find 5/16" 6061 T6 so I bought 3/8" instead.
What do you guys think? Will that be OK to use?
Thanks Chris
Chris,
Sure it is ok to use but you will building heavy and flying tail heavy forever.
Check out Wicks at: 1-800-221-9425 or at:
http://www.wicksaircraft.com
They have listed 6061-T6 listed.
OD WALL ID WGT P/FT PART NUMBER $/FOOT
5/16" .035 .243 .0366 R5/16X035-T6 1.29
5/16" .049 .215 .0477 R5/16X049-T6 1.13
Jack B. Hart FF004
Winchester, IN
Denny Rowe
PostPosted: Thu Apr 13, 2006 9:10 am    Post subject: 3/8" Insead of 5/16" Reply with quote
Would'nt the heavier tubing on the elevator and rudder make em more likely
to flutter?
Denny Rowe, Mk-3
ulflyer(at)verizon.net
PostPosted: Thu Apr 13, 2006 6:05 pm    Post subject: 3/8" Insead of 5/16" Reply with quote
>Thanks Chris
Chris,
heavy forever.
Jack B. Hart FF004
Winchester, IN
Here's another source:
http://shapirosupply.com/index.php?option=com_content&task=view&id=4&Itemid=5
DrHook
PostPosted: Fri Apr 14, 2006 2:15 am    Post subject: Re: 3/8 Reply with quote
Well, Allrighty then, Looks like I be orderin up some 5/16.
Got to get some other supplies and it looks like Wicks, pretty much has it all.
Thanks for the advice, Chris
Kolb Firestar owner, Rebuild-Recover job at hand.
