thesupe(at)hotmail.com Guest
Posted: Thu Nov 12, 2009 8:53 pm Post subject: Kitfox 2 ? on ebay |
Hi all C did anyone else see this plane on ebay C Supposed to be a Kitfox 2. What do you think. I couldn't resist and sent a few questions to him. Item # is 290368872471
Take care C Jim Chuk Avids C Kitfox 4 Mn
Bing brings you maps C menus C and reviews organized in one place. Try it now. [quote][b]
Fox5flyer Guest
Posted: Fri Nov 13, 2009 4:02 am Post subject: Kitfox 2 ? on ebay |
That doesn't look like any Kitfox I've ever seen. Sounds like some sort of scam.
Deke
rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Fri Nov 13, 2009 5:07 am Post subject: Re: Kitfox 2 ? on ebay |
Wow, that could get the award for "most modified".
Could report is as fraud I suppose. There is a category for "misleading title" under the policy violations drop-down.
_________________ Kitfox IV-1200
Indianapolis, IN |
akflyer
Posted: Fri Nov 13, 2009 5:45 am Post subject: Re: Kitfox 2 ? on ebay |
I just did a quick N# search and it is a Terral Olen C T-2. Pics of it are in the data base. I sent the seller a nice little question...
There is NOTHING Kitfox about that plane. Looks more like a modded volks plane or a himax.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Aerobatics(at)aol.com Guest
Posted: Fri Nov 13, 2009 5:46 am Post subject: Kitfox 2 ? on ebay |
I think I saw a bolt on it similar to the one on my Kitfox 2 but I could be wrong.....
Dave
KF2 500 hrs and going strong.
In a message dated 11/13/2009 7:11:20 A.M. Central Standard Time, rawheels(at)yahoo.com writes:
| Quote: | --> Kitfox-List message posted by: "rawheels" <rawheels(at)yahoo.com>
Ryan Wheeler
Kitfox IV-1200
Indianapolis, IN
http://forums.matronics.com/viewtopic.php?p=272666#272666===============================================
_nbsp; (And Get Some AWESOME FREE to find Gifts tric re b k you for p; -Matt Dralle, List ======================== the ties Day ================================================ - MATRONICS WEB FORUMS ==================================================
henrysfork1(at)msn.com Guest
I built and fly a Kitfox II C don't know what kind of unit that is but it sure isn't a Kitfox II. Some one is going to get hosed if they buy thinking its a Kitfox. The ID plate looks like something a kid made.
Dee Young
Model II
N345DY
Windows 7: Unclutter your desktop. Learn more. [quote][b]
matronics(at)bob.brennan. Guest
Posted: Fri Nov 13, 2009 5:49 am Post subject: Kitfox 2 ? on ebay |
The FAA reports the N number as "ATTENTION! This aircraft's registration
status may not be suitable for operation" and then at
http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt 165Q
that the number is also assigned to a Cessna 185.
The aircraft model is registered as "T-2" and no mention of Kitfox. I
reported it as possibly fraudulant on eBay, let's see what they do about
it...
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade GSC prop
Wrightsville Pa
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Fri Nov 13, 2009 5:56 am Post subject: Re: Kitfox 2 ? on ebay |
It's a "T-2" what ever that is, according to the FAA registration.
Link to Registration
FAA also states that the registration status is "in Question", meaning all of the paperwork is not in order.
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
clozzzer
Posted: Fri Nov 13, 2009 2:25 pm Post subject: Re: Kitfox 2 ? on ebay |
I am the seller of this item. I am not a scamer, but mearly a novice at this hobby. Before you said say things, you should ask me directly.
THe faa paperwork clearly shows kitfox. model t2. THat is all I can say.
So watch your mouth.
Steve
mike(at)mikegibbard.com Guest
Posted: Fri Nov 13, 2009 2:28 pm Post subject: Kitfox 2 ? on ebay |
I had a model 2 and this plane does not look like mine. Mike
Mike Gibbard
PO Box 542
Central Lake, MI 49622
http://www.mikegibbard.com ---Real Estate
mike(at)mikegibbard.com ---Email
231-544-5241 Home
231-676-3788 Cell [quote] --
akflyer
Posted: Fri Nov 13, 2009 2:55 pm Post subject: Re: Kitfox 2 ? on ebay |
| clozzzer wrote: | I am the seller of this item. I am not a scamer, but mearly a novice at this hobby. Before you said say things, you should ask me directly.
Steve |
Dear akflyer-2000,
not a scam. bid or go away. I have the faa paper work to prove it.
- clozzzer001
your reply to my question on ebay.
This is not a kitfox. It does not have flaperons, the tail group, the fuselage or any other thing related to kitfox.
I provided the registration info that the FAA has in the data base and nothing states it is a kitfox.
The yellow and white plane is a kitfox II, the yellow and blue is a kitfox III
They look nothing like you plane. The pictures on ebay show a wooden fuselage, the kitfox is tube and fabric.
180.55 KB |
24382 Time(s) |
88.23 KB |
24382 Time(s) |
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
akflyer
Posted: Fri Nov 13, 2009 3:15 pm Post subject: Re: Kitfox 2 ? on ebay |
here are pics of the kitfox lite and kitfox lite squared as you are now reporting it as on ebay. as you can see, it is neither of these.
40.98 KB |
24397 Time(s) |
22.2 KB |
24397 Time(s) |
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Paul A. Franz, P.E.
Posted: Fri Nov 13, 2009 3:41 pm Post subject: Kitfox 2 ? on ebay |
On Fri, November 13, 2009 2:25 pm, clozzzer wrote:
Not that I can find. Searching the FAA database directly for N2165Q
<http://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt 165Q>
"This aircraft's registration status may not be suitable for operation.
Please contact the Aircraft Registration Branch as 1-866-762-9434 for additional
information."
And searching the Landings database
<http://www.landings.com/evird.acgi?pass=144766799&ref=-&mtd=41&cgi=%2Fcgi-bin%2Fnph-search_nnr&var=0&buf=66&src=_landings%2Fpages%2Fsearch_nnr.html&nnumber 165q>
N-number : N2165Q
Aircraft Serial Number : 5871
Aircraft Manufacturer : TERRAL OLEN C
Model : T-2
Engine Manufacturer : VOLKSWAGEN
Model : CONVERSION
Aircraft Year : 1991
Owner Name : REGISTRATION PENDING
Owner Address : PO BOX 1174
ARIZONA CITY, AZ, 85223-1174
Type of Owner : Individual
Registration Date : Not Specified
Airworthiness Certificate Type : Experimental
Approved Operations : Amateur Built
There is no reference to it being a Kitfox at all. The aircraft pictured in your
advertisment on eBay is not a Kitfox.
Would you mind providing some background information on the aircraft? Are you the
current owner? It would appear that the aircraft is not registered at all. Would you
explain the status? A little history of the aircraft would be nice starting with the
builder who looks to be Olen C. Terral.
Paul Franz
425.440.9505 (O)
425.241.1618 (C)
One of the lessons of history is that nothing is often a good thing to do and always a
clever thing to say.
-- Will Durant
_________________ Paul A. Franz, P.E.
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
andynfultz(at)bellsouth.n Guest
Posted: Fri Nov 13, 2009 5:00 pm Post subject: Kitfox 2 ? on ebay |
Steve,
Since you are "mearly a novice at this hobby", maybe you should "watch
your mouth" and listen to those who obviously know much much more than you
do. What you have pictured on ebay is in no way a Kitfox, no matter what
you say your paperwork says. Maybe you got hosed when you bought it, but
please don't try to pass that thing off as a Kitfox.
Andy
akflyer
Posted: Sat Nov 14, 2009 7:20 am Post subject: Re: Kitfox 2 ? on ebay |
One of the guys on the Yahoo avid group figured it out. This is a Fisher FP 606.
Steve, open your eyes, do a google search for FP 606, then relist your add. There is noting even close between the two aircraft other than the fact that they both fly...
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Fox5flyer Guest
Posted: Sat Nov 14, 2009 9:46 am Post subject: Kitfox 2 ? on ebay |
I have just one question, Steve. Now that you know that the airplane you
are selling is not a Kifox, why would you continue to run it on Ebay trying
to pass it off as something it's clearly not? Instead you act with
aggression toward those who point it out to you. In my very humble opinion
if you are an honorable person you would either remove the ad or change it
so that someone doesn't end up buying something they later find out is
bogus.
Deke
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item 90368872471&viewitem=&sspagename=STRK%3AMEWAX%3AIT
Steve
jcorner(at)shaw.ca Guest
Posted: Sat Nov 14, 2009 10:45 am Post subject: Kitfox 2 ? on ebay |
I have taken the time to report the item to Ebay customer support
team, reporting the item as fraudulent. Their reply says they will
investigate within 72hours. Interesting to note that the listing
matures in 3 days 1 hr.
Hopefully they will remove the item in time.
Jim Corner
Model 2, 582,. Ivo med !FA, 1100 hrs
Model 5, 0-235 --110 hrs.
Calgary, AB
akflyer
Posted: Sat Nov 14, 2009 11:38 am Post subject: Re: Kitfox 2 ? on ebay |
I sent the guy another reply on ebay, and he has now updated the listing under the questions. He talked to J. Mc Bean (I guess cause we are all so stupid) and he now knows it is not a KF II. He stated that it is now believed to be, or "emulates" the Fisher FP 606.
Wonder where the bidding will go now... I would hope that guys bidding on it would have known it was not a KF of any type.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Boilermaker2000
Joined: 14 Apr 2009 Posts: 11 Location: West Lafayette, IN
Posted: Sat Nov 14, 2009 12:13 pm Post subject: Re: Kitfox 2 ? on ebay |
The specs are completely different between these planes. 950lbs gross weight listed vs 500lbs actual is pretty serious. Guess the winner's widow won't have any problem taking all of Steve's money.
clozzzer
Posted: Sun Nov 15, 2009 11:36 am Post subject: Re: Kitfox 2 ? on ebay |
To all User's on this Forum:
I have posted an update on the ad. I can't change the listing info once a bid has been placed. Therefore, all I can do is update the listing with information, as I have done. The title is not able to be changed either. I have done my best to advise the bidders of the correct information. I am not sure of the kits origin, nor spec's of the kit. I would like to post the specs of the fisher 606, but am hesitant, as this may not be the plane.
To cancel the listing would cost me over $50.00 in listing fee's.
The faa paper does show kitfox t-2 on it. I believe t-2, may signify the builders last name, "t" and "2" for the second aircraft built by him. Again, not sure. Kitfox may have been a nickname applied by the builder.
I have nothing to hide, and will provide all of you my phone #. If you would like to chat, call me (at) 520-483-1310. My name is Steve.
Gentlemen, I urge you to focus your precious lives on something more important than Ebay.
Steve
